FAN control OMV Auyfan 0.10.12: gitlab-ci-linux-build-184, Kernel 5.6
12 3 1.5k 1
  • Hey,
    I will do it in english, hope it is okay. Thanks, for very informative forum.
    My question is, is it possible to control the FAN in the newest OMV Auyfan 0.10.12: gitlab-ci-linux-build-184, Kernel 5.6?
    The install was very easy no problems at all, the only problem is i did try some different commands to reach the fan, but was not able to get it going. Do somebody know how? Thanks.
    Best Regards.
    Soeren
  • Hi Soeren,
    I have this succesfully running.
    Kind Regards
    Martin
  • Hi Soeren,
    Kind Regards
    Martin
    @mabs sagte in FAN control OMV Auyfan 0.10.12: gitlab-ci-linux-build-184, Kernel 5.6:
    Hi Soeren,
    Kind Regards
    Martin
    Thanks, i will try the fan tool again. I'm almost sure i did try without luck, have you edited something in the fan tool conf..?
  • Hi,
    I only played with two parameters.
    I have two rockpro64 boards, currently one has a small fan and the other one has a large fan.
    Therefore I changed PROFILE_NR accordingly.
    Also I have ALWAYS_ON on true on the one with the large fan, but don't see a difference. The fan goes on and off still, maybe I misinterpreted the parameter.
    Also I just noticed now that the CTL settings of the version on github changed slightly, but I think this only improved the detection depending of the kernel settings.
  • @mabs
    With the new OMV kernel 5.6 image from Auyfan, i can't get the FAN to spin - If the fan spins it runs really slow, no sound from the fan.
    With the FAN tool the master installation "failed" and with the release installation it did report "active"..
    I have installed a 92mm FAN inside the NAS case, it runs on Armbian with kernel 5.4.32
    I will open op the case later today to be sure. Thanks.
  • Hi,
    Now i did find the fan, here it goes "nano /sys/devices/platform/pwm-fan/hwmon/hwmon3/pwm1" it is at "0" can be controlled to "255"
    Best Regards.
  • Yes that is basically the way ATS is doing the changing as well I think, as those /sys entries are in the _CTL variables.
    good that you got it working, or are you only half way?
  • @mabs
    The tool works on all image under 5.4 or so for me. But yes i am at the finish line, just wanted the fan to be always on. Just wanted to share, if someone will run in the same problems. Thanks.
  • Helpful Thread!
    But, ATS don't work for me on kernel 5.6 with ayufan release. Only this command works.
    Thanks @soerenderfor for the hint.
  • Ok, problem in ATS is this?
    -- FAN Control[ String ]
    	PWM_CTL		= {
    			"/sys/class/hwmon/hwmon0/pwm1",
    			"/sys/devices/platform/pwm-fan/hwmon/hwmon0/pwm1",
    			"/sys/devices/platform/pwm-fan/hwmon/hwmon1/pwm1"
    	PWM_CTL		= {
    @FrankM - did you try fix the ATS tool, if yes. Will it Work?
    Best Regards.
  • Hi,
    since I'm currently change my rockpro64 setup I came across this.
    With the kernel from ayufan you need to set PWM_CTL to
    for my self compiled one I need
    But I got it only working with one entry for PWM_CTL e.g.
    PWM_CTL		= "/sys/devices/platform/pwm-fan/hwmon/hwmon0/pwm1",
    after that you need to start ats again
    sudo systemctl stop ats
    sudo systemctl start ats
    initially the fan should start immediately for a short period of time.
    In case it is even a different one on your kernel you can find the right one using this command.
    sudo find /sys -name pwm1 | grep hwmon
    So far I'm not sure which kernel parameter or modul changes this.
    Martin
  • AI Bots aussperren
    Linux linux block-ai nginx
    245 Aufrufe
    Wir können das noch für eine sanfte Methode erweitern, das ist die Datei robots.txt, wo man sich in alten Zeiten mal dran hielt. Einige Bots machen das, andere nicht. Praktisch, das o.g. Projekt bietet diese Datei auch an. Dann werden wir das kurz mal mit einbauen. ai-block.sh #!/bin/bash # Script um AI-Bots zu blocken # https://github.com/ai-robots-txt/ai.robots.txt/tree/main mkdir /root/AI-test cd /root/AI-test ## Daten holen curl -O https://raw.githubusercontent.com/ai-robots-txt/ai.robots.txt/master/nginx-block-ai-bots.conf curl -O https://raw.githubusercontent.com/ai-robots-txt/ai.robots.txt/master/robots.txt ## Daten in nginx einbauen mv nginx-block-ai-bots.conf /etc/nginx/blocklists/ mv robots.txt /var/www/html ## NGINX neustarten systemctl restart nginx.service Damit das in nginx funktioniert. Den Server Block um folgendes erweitern. # Serve robots.txt directly from Nginx location = /robots.txt { root /var/www/html; try_files $uri =404; } Kurzer Test https://<DOMAIN>/robots.txt Ergebnis User-agent: AI2Bot User-agent: Ai2Bot-Dolma User-agent: Amazonbot User-agent: anthropic-ai User-agent: Applebot User-agent: Applebot-Extended User-agent: Brightbot 1.0 User-agent: Bytespider User-agent: CCBot User-agent: ChatGPT-User User-agent: Claude-Web User-agent: ClaudeBot User-agent: cohere-ai User-agent: cohere-training-data-crawler User-agent: Crawlspace User-agent: Diffbot User-agent: DuckAssistBot User-agent: FacebookBot User-agent: FriendlyCrawler User-agent: Google-Extended User-agent: GoogleOther User-agent: GoogleOther-Image User-agent: GoogleOther-Video User-agent: GPTBot User-agent: iaskspider/2.0 User-agent: ICC-Crawler User-agent: ImagesiftBot User-agent: img2dataset User-agent: imgproxy User-agent: ISSCyberRiskCrawler User-agent: Kangaroo Bot User-agent: Meta-ExternalAgent User-agent: Meta-ExternalFetcher User-agent: OAI-SearchBot User-agent: omgili User-agent: omgilibot User-agent: PanguBot User-agent: Perplexity-User User-agent: PerplexityBot User-agent: PetalBot User-agent: Scrapy User-agent: SemrushBot-OCOB User-agent: SemrushBot-SWA User-agent: Sidetrade indexer bot User-agent: Timpibot User-agent: VelenPublicWebCrawler User-agent: Webzio-Extended User-agent: YouBot Disallow: /
  • Update 1.30.2 released
    Vaultwarden vaultwarden linux
    151 Aufrufe
  • Raspberry Pi5 - Netzteil
    RaspberryPi raspberrypi linux
    579 Aufrufe
  • Debian Buster 10.8 released
    Linux debian linux
    252 Aufrufe
  • Kopia - Mounten einer Sicherung
    Verschoben Kopia kopia linux
    246 Aufrufe
  • Wireguard - Client installieren
    Wireguard linux wireguard
    968 Aufrufe
    Ich kann dir nicht ganz folgen. Mein Wireguard Server ist eine VM im Netz. Mein Smartphone baut zu diesem eine Verbindung auf und ich habe mal eben nachgeschaut, was da so geht. Mein Smartphone ist aktuell im meinem WLan angemeldet. [image: 1586458461693-6e0016dc-7e11-41e1-bba2-e52a3f1348df-image-resized.png] iperf3 -s -B 10.10.1.1 ----------------------------------------------------------- Server listening on 5201 ----------------------------------------------------------- Accepted connection from 10.10.1.10, port 44246 [ 5] local 10.10.1.1 port 5201 connected to 10.10.1.10 port 44248 [ ID] Interval Transfer Bitrate [ 5] 0.00-1.00 sec 4.98 MBytes 41.7 Mbits/sec [ 5] 1.00-2.00 sec 5.52 MBytes 46.3 Mbits/sec [ 5] 2.00-3.00 sec 4.80 MBytes 40.3 Mbits/sec [ 5] 3.00-4.00 sec 4.17 MBytes 35.0 Mbits/sec [ 5] 4.00-5.00 sec 5.04 MBytes 42.3 Mbits/sec [ 5] 5.00-6.00 sec 5.43 MBytes 45.6 Mbits/sec [ 5] 6.00-7.00 sec 5.75 MBytes 48.3 Mbits/sec [ 5] 7.00-8.00 sec 5.70 MBytes 47.8 Mbits/sec [ 5] 8.00-9.00 sec 5.73 MBytes 48.1 Mbits/sec [ 5] 9.00-10.00 sec 5.65 MBytes 47.4 Mbits/sec [ 5] 10.00-10.04 sec 206 KBytes 46.5 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate [ 5] 0.00-10.04 sec 53.0 MBytes 44.3 Mbits/sec receiver ----------------------------------------------------------- Server listening on 5201 ----------------------------------------------------------- Accepted connection from 10.10.1.10, port 44250 [ 5] local 10.10.1.1 port 5201 connected to 10.10.1.10 port 44252 [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 4.80 MBytes 40.2 Mbits/sec 0 253 KBytes [ 5] 1.00-2.00 sec 14.7 MBytes 123 Mbits/sec 181 379 KBytes [ 5] 2.00-3.00 sec 9.68 MBytes 81.2 Mbits/sec 58 294 KBytes [ 5] 3.00-4.00 sec 8.88 MBytes 74.5 Mbits/sec 1 227 KBytes [ 5] 4.00-5.00 sec 7.76 MBytes 65.1 Mbits/sec 0 245 KBytes [ 5] 5.00-6.00 sec 8.88 MBytes 74.5 Mbits/sec 0 266 KBytes [ 5] 6.00-7.00 sec 9.81 MBytes 82.3 Mbits/sec 0 289 KBytes [ 5] 7.00-8.00 sec 7.82 MBytes 65.6 Mbits/sec 35 235 KBytes [ 5] 8.00-9.00 sec 5.59 MBytes 46.9 Mbits/sec 4 186 KBytes [ 5] 9.00-10.00 sec 6.64 MBytes 55.7 Mbits/sec 0 207 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.04 sec 84.6 MBytes 70.6 Mbits/sec 279 sender ----------------------------------------------------------- Server listening on 5201 ----------------------------------------------------------- ^Ciperf3: interrupt - the server has terminated Im zweiten Teil ist der Wireguard Server der Sender. Bis jetzt hatte ich eigentlich nie Probleme, auch nicht unterwegs. Aber, ich gehe davon aus, das ich dich nicht 100% verstanden habe
  • mdadm
    Verschoben Linux linux
    539 Aufrufe
    Nachdem ich die SATA-Karte gewechselt habe, sind meine Probleme verschwunden. Mein NAS läuft seit Monaten einwandfrei. rock64@rp64v_2_1_NAS:~$ uptime 21:57:50 up 73 days, 4:44, 1 user, load average: 0,00, 0,00, 0,00 https://forum.frank-mankel.org/topic/299/sata-karte-marvell-88se9230-chipsatz/16
  • Node.js auf dem Raspberry3 B+ installieren
    RaspberryPi nodejs raspberrypi linux
    852 Aufrufe
