Quartz64 - Model B
Angeheftet Verschoben Quartz64 - B
10 1 1.2k
    Bildquelle: https://www.pine64.org/quartz64b/
    5V-Stromversorgung!
    SoC and Memory Specification
    CPU Architecture
    • Quad-core ARM Cortex-A55@1.8GHz
    • AArch32 for full backwards compatibility with ARMv7
    • ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
    • Includes VFP hardware to support single and double-precision operations
    • ARMv8 Cryptography Extensions
    • Integrated 32KB L1 instruction cache and 32KB L1 data cache per core
    • 512KB unified system L3 cache
    • TrustZone technology support
    Graphic Process Unit GPU Capability
    • Mali-G52 2EE Bifrost GPU@800MHz
    • 4x Multi-Sampling Anti-Aliasing (MSAA) with minimal performance drop
    • 128KB L2 Cache configurations
    • Supports OpenGL ES 1.1, 2.0, and 3.2
    • Supports Vulkan 1.0 and 1.1
    • Supports OpenCL 2.0 Full Profile
    • Supports 1600 Mpix/s fill rate when at 800MHz clock frequency
    • Supports 38.4 GLOP/s when at 800MHz clock frequency
    Neural Process Unit NPU Capability
    • Neural network acceleration engine with processing performance of up to 0.8 TOPS
    • Supports integer 8 and integer 16 convolution operations
    • Supports the following deep learning frameworks: TensorFlow, TF-lite, Pytorch, Caffe, ONNX, MXNet, Keras, Darknet
    System Memory
    • RAM Memory Variants: 2GB - 8GB LPDDR4.
    • SPI Flash: 128Mbit / 16MByte
    Network
    • 10/100/1000Mbps Ethernet
    • WiFi 802.11 b/g/n/ac with Bluetooth 5.0 (optional on model A, build in on model B)
    Storage
    • microSD - bootable, supports SDHC and SDXC, storage up to 2TB
    • USB - 2 ports on model B, 3 ports on model A USB 2.0 Host port, 1 USB 3.0 Host port
    • one native SATA 3.0 6Gb/s Port (only on model A, shared with USB 3.0 host port)
    • optional eMMC module from 16GB up to 128GB
    Expansion Ports
    • eDP - 4 lanes of 2.7Gbps, up to 2560x1600@60Hz (only on model A)
    • DSI - Display Serial Interface, 4 lanes MiPi, up to 1440P on model A, 2 lanes MiPi, up to 1080p on model B
    • CSI - CMOS Camera Interface, 4 lanes MiPi up to 8 mega pixel on model A, 2 lanes MiPi up to 5 mega pixel on model B
    • TP - Touch Panel Port, SPI with interrupt on model A
    • RTC - Real Time Clock Battery Connector
    • VBAT - Lithium Battery Connector with temperature sensor input on model A
    • Wifi/BT Module Header - SDIO 3.0 and UART on model A, build in Wifi/BT Module on model B
    • 2x20 pins "Pi2" GPIO Header on model B, 2x10 pins GPO header on model A
    • PCIe x4 open ended slot on model A, m.2 slot on model B, one Gen2 lane due to SoC constraints
    Quartz64 board Information, Schematics, and Certifications
    Quelle: https://wiki.pine64.org/wiki/Quartz64
  • Neuigkeiten zum WiFi-Modul, was auf dem Model B verbaut ist.
    <@tl_lim> The Quartz64 model B product version will comes with BL602 module instead of AP6255.
    Das macht nur 2,4 GHz 😞
    Dokumentation
  • FrankMF FrankM hat am auf dieses Thema verwiesen
  • FrankMF FrankM hat dieses Thema am angepinnt
  • Da mein Model B ja bestellt ist, bin ich gerade über einen Post gestolpert.
    <CounterPillow> "Model A" is the big form factor, "Model B" the small form factor. Model A boards generally use 12V, Model B boards use 5V.
    Da sollte man also höllisch aufpassen, wenn man beide auf dem Schreibtisch liegen hat. Da ist schnell mal ein B gegrillt, wenn man das falsche Netzteil erwischt.
    Blödsinn! Beim Quartz64 - Modell A ist der Stecker
    DC 12V @ 3A 5.5mmOD/2.1mmID center-positive Barrel DC Jack connector
    beim Quartz64 - Modell B
    DC 5V @ 3A 3.5mmOD/1.35mmID center-positive Barrel DC Jack connector
    Passt also nicht, also alles safe 🙂
    Der Schaltplan soll nächste Woche veröffentlicht werden.
    CounterPillow hat mal nachgemessen
    <CounterPillow> just checked with with multimeter, it is center positive
  • Da schreibt mich das Sales Team von pine64.org an teilt mir mit, das meine PLZ falsch ist. Ja, ein scheiß Tippfehler....... Er wäre schon da 😞
  • Das ging diesmal flott. Nachricht von FedEx, Lieferung soll bis zum 02.06 da sein 🤓
  • Er ist angekommen.
    Leider funktioniert der UART Adapter nicht, jede Menge Artefakte 😞
    Ein paar Neue sind bestellt und hoffentlich morgen da. Das alte Spielkind, konnte es aber nicht lassen und musste unbedingt schauen ob der M2-Slot funktioniert.
    Ok, das macht natürlich NULL Spaß, also geht es morgen weiter...
  • FrankMF FrankM verschob dieses Thema von Hardware am
  • Heute die Zollrechnung von FedEx 16,47€
  • Quartz64 - Modell B - Temperaturen
    Quartz64 - B quartz64
    156 Aufrufe
  • Kernel 5.19-rc1
    Quartz64 linux quartz64
    245 Aufrufe
    Man kann dann den aktuell Kernel [root@frank-pc ~]# uname -a Linux frank-pc 5.17.0-3-MANJARO-ARM-Q64 #1 SMP PREEMPT Sat Jun 4 14:34:03 UTC 2022 aarch64 GNU/Linux mit diesem Befehl aktualisieren sudo pacman -S linux-rc linux-rc-headers Man wechselt dann vom Zweig linux-quartz64 auf linux-rc. Der Zweig linux-rc entspricht dem Mainline Kernel. Achtung! Zum Zeitpunkt der Erstellung des Beitrages crasht das Eure Installation!! Ursache ist, das es aktuell diesen Kernel linux-rc-5.18.rc7-7-aarch64 installiert, dieser enthält aber keine Unterstützung für das Modell B. Und zum Nachschauen, ob schon was Neues da ist [root@frank-pc ~]# pacman -Ss linux-rc linux-rc-headers core/linux-rc-headers 5.18.rc7-7 Header files and scripts for building modules for linux kernel - AArch64 multi-platform (release candidate)
  • Quartz64 - Modell B - UART
    Angeheftet Quartz64 - B quartz64
    327 Aufrufe
    Um das hier zu komplettieren, habe ich mich gerade gefragt "Wo speichert er die Settings?" Ok, ich habe sie gefunden. /root/.minirc.dfl Inhalt # Diese Datei ist maschinell erzeugt. Bitte verwenden Sie das # Einstellungs-Menü im minicom-Programm, um die Einstellungen # zu ändern. pu rtscts No Jetzt habe ich ausreichend hier dokumentiert, falls ich da nochmal Probleme mit habe.
  • Quartz64 Model B im Shop bestellbar
    Verschoben Quartz64 quartz64
    473 Aufrufe
  • QuartzPro64
    Allgemeine Diskussionen quartzpro64 pine64
    192 Aufrufe
  • Quartz64 - Jumper BAT ON/OFF
    Angeheftet Verschoben Quartz64 - A quartz64 pine64
    240 Aufrufe
  • Quartz64 - SPI
    282 Aufrufe
    Bitte unbedingt beachten! https://forum.frank-mankel.org/topic/1042/quartz64-missing-spi
  • Quartz64 - Modell A lieferbar
    Verschoben Quartz64 quartz64 pine64
    446 Aufrufe
    Durch den Zoll ist es auch... [image: 1624464737019-aa906c24-2e67-404d-aad2-69fe1832229b-grafik.png]
