Armbianmonitor
ROCKPro64
1 1 1.5k
  • @tkaiser hat dafür gesorgt, das der Armbianmonitor jetzt in den Images vom Ayufan mit drin ist.
    Eine kleine Hilfe beim Stresstesten ☺
    sudo memtester 3072 1
     memtester version 4.3.0 (64-bit)
     Copyright (C) 2001-2012 Charles Cazabon.
     Licensed under the GNU General Public License version 2 (only).
     pagesize is 4096
     pagesizemask is 0xfffffffffffff000
     want 3072MB (3221225472 bytes)
     got  3072MB (3221225472 bytes), trying mlock ...locked.
     Loop 1/1:
       Stuck Address       : ok
       Random Value        : ok
       Compare XOR         : ok
       Compare SUB         : ok
       Compare MUL         : ok
       Compare DIV         : ok
       Compare OR          : ok
       Compare AND         : ok
       Sequential Increment: ok
       Solid Bits          : ok
       Block Sequential    : ok
       Checkerboard        : ok
       Bit Spread          : ok
       Bit Flip            : ok
       Walking Ones        : ok
       Walking Zeroes      : ok
       8-bit Writes        : ok
       16-bit Writes       : ok
     Done.
    Armbianmonitor findet ihr unter /usr/local/sbin
    rock64@rockpro64:/usr/local/sbin$ ./armbianmonitor
    Usage: armbianmonitor [-h] [-c $path] [-f] [-l] [-L] [-m] [-u] [-v]
     Use armbianmonitor for the following tasks:
     armbianmonitor -c /path/to/test performs disk health/performance tests
     armbianmonitor -f tries to fix detected corrupt packages
     armbianmonitor -l outputs diagnostic logs to the screen via less
     armbianmonitor -L outputs diagnostic logs to the screen as is
     armbianmonitor -m provides simple CLI monitoring
     armbianmonitor -n provides simple CLI network monitoring
     armbianmonitor -u tries to upload diagnostic logs for support purposes
     armbianmonitor -v tries to diagnose corrupt packages and files
    Die Leistungsaufnahme beim Stresstest: ca. 11 Watt
  • Images 0.11.x
    Images linux rockpro64
    524 Aufrufe
    0.11.2: gitlab-ci-linux-build-187 released 0.11.2: Update OMV install (to also be able to run OMV6)
  • TwisterOS
    Images twisteros armbian rockpro64
    310 Aufrufe
  • ROCKPro64 - Debian Bullseye Teil 1
    ROCKPro64 debian linux rockpro64
    17
    17 Beiträge
    Durch diesen Beitrag ist mir mal wieder eingefallen, das wir das erneut testen könnten Also die aktuellen Daten von Debian gezogen. Das Image gebaut, könnt ihr alles hier im ersten Beitrag nachlesen. Da die eingebaute Netzwerkschnittstelle nicht erkannt wurde, habe ich mal wieder den USB-to-LAN Adapter eingesetzt. Bus 005 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet Die Installation wollte ich auf einem NVMe Riegel installieren. Die Debian Installation durchgezogen und nach erfolgreicher Installation neugestartet. Und siehe da, ohne das man alles möglich ändern musste, bootete die NVMe SSD Eingesetzter uboot -> 2020.01-ayufan-2013...... Die nicht erkannte LAN-Schnittstelle müsste an nicht freien Treibern liegen, hatte ich da irgendwo kurz gelesen. Beim Schreiben dieses Satzes kam die Nacht und ich konnte noch mal drüber schlafen. Heute Morgen, beim ersten Kaffee, dann noch mal logischer an die Sache ran gegangen. Wir schauen uns mal die wichtigsten Dinge an. root@debian:~# ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 62:03:b0:d6:dc:b3 brd ff:ff:ff:ff:ff:ff 3: enx000acd26e2c8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether 00:0a:cd:26:e2:c8 brd ff:ff:ff:ff:ff:ff inet 192.168.3.208/24 brd 192.168.3.255 scope global dynamic enx000acd26e2c8 valid_lft 42567sec preferred_lft 42567sec inet6 fd8a:6ff:2880:0:20a:cdff:fe26:e2c8/64 scope global dynamic mngtmpaddr valid_lft forever preferred_lft forever inet6 2a02:908:1260:13bc:20a:xxxx:xxxx:xxxx/64 scope global dynamic mngtmpaddr valid_lft 5426sec preferred_lft 1826sec inet6 fe80::20a:cdff:fe26:e2c8/64 scope link valid_lft forever preferred_lft forever Ok, er zeigt mir die Schnittstelle eth0 ja an, dann kann es an fehlenden Treibern ja nicht liegen. Lässt dann auf eine fehlerhafte Konfiguration schließen. Nächster Halt wäre dann /etc/network/interfaces Das trägt Debian ein # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # The loopback network interface auto lo iface lo inet loopback # The primary network interface allow-hotplug enx000acd26e2c8 iface enx000acd26e2c8 inet dhcp # This is an autoconfigured IPv6 interface iface enx000acd26e2c8 inet6 auto Gut, bei der Installation hat Debian ja nur die zusätzliche Netzwerkschnittstelle erkannt, folgerichtig ist die auch als primäre Schnittstelle eingetragen. Dann ändern wir das mal... # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). source /etc/network/interfaces.d/* # The loopback network interface auto lo iface lo inet loopback # The primary network interface #allow-hotplug enx000acd26e2c8 allow-hotplug eth0 #iface enx000acd26e2c8 inet dhcp iface eth0 inet dhcp # This is an autoconfigured IPv6 interface #iface enx000acd26e2c8 inet6 auto iface eth0 inet6 auto Danach einmal alles neu starten bitte systemctl status networking Da fehlte mir aber jetzt die IPv4 Adresse, so das ich einmal komplett neugestartet habe. Der Ordnung halber, so hätte man die IPv4 Adresse bekommen. dhclient eth0 Nachdem Neustart kam dann das root@debian:/etc/network# ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 62:03:b0:d6:dc:b3 brd ff:ff:ff:ff:ff:ff inet 192.168.3.172/24 brd 192.168.3.255 scope global dynamic eth0 valid_lft 42452sec preferred_lft 42452sec inet6 fd8a:6ff:2880:0:6003:b0ff:fed6:dcb3/64 scope global dynamic mngtmpaddr valid_lft forever preferred_lft forever inet6 2a02:908:1260:13bc:6003:xxxx:xxxx:xxxx/64 scope global dynamic mngtmpaddr valid_lft 5667sec preferred_lft 2067sec inet6 fe80::6003:b0ff:fed6:dcb3/64 scope link valid_lft forever preferred_lft forever 3: enx000acd26e2c8: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 00:0a:cd:26:e2:c8 brd ff:ff:ff:ff:ff:ff Fertig, eth0 läuft. Nun kann man den zusätzlichen Adapter entfernen oder halt konfigurieren, wenn man ihn braucht. Warum der Debian Installer die eth0 nicht erkennt verstehe ich nicht, aber vielleicht wird das irgendwann auch noch gefixt. Jetzt habe ich erst mal einen Workaround um eine Installation auf den ROCKPro64 zu bekommen.
  • SATA - Booten jetzt möglich
    ROCKPro64 rockpro64
    303 Aufrufe
  • ROCKPro64 - Booten von USB3
    ROCKPro64 rockpro64
    472 Aufrufe
    Yeah, genau das worauf ich auch warte. Wenn ich das richtig mitbekommen habe, könnte das Kamil's nächster Punkt auf seiner Liste sein.
  • ROCKPro64 - WLan-Antennen
    Hardware rockpro64
    320 Aufrufe
  • Wichtig!
    Verschoben Archiv rockpro64
    785 Aufrufe
  • Shop-Bestellung
    ROCKPro64 rockpro64
    10
    10 Beiträge
    V
    @FrankM besten Dank für die ausführliche Infos.
