Live testing of remote categories
@julian we have recently rewritten the addressing logic and it seems mapping the mentions to
to
for public toplevel posts has fallen short. After fixing this it seems to work fine now: #^https://community.nodebb.org/topic/cbbf1640-2295-4fc5-b86f-5b1fd259cccb/test2
@Scott M. Stolzschrieb am 1. Apr. 2025, 11:53 zuletzt editiert von@mario@hub.somaton.com that's wonderful to hear! Thank you so much.
schrieb am 2. Apr. 2025, 20:46 zuletzt editiert von
Some of the remote categories appear to be broken now.
These are the Flipboard magazines NodeBB is currently aware of when searching "flipboard" in the search page:
- [Tech News by @theverge@flipboard.com](https://community.nodebb.org/category/tech-news-theverge@flipboard.com)
- [Musik News by @musikexpressde@flipboard.com](https://community.nodebb.org/category/musik-news-musikexpressde@flipboard.com)
- [Gear by @engadget@flipboard.com](https://community.nodebb.org/category/gear-engadget@flipboard.com)
However, that very first one (tech news by The Verge) does not work; going to it gives a 404 page instead.
Something else appears to have happened to the Vivaldi Blog remote category (a WordPress blog). A week ago it was working fine, but now, searching for it lists it twice in the search page. Each listing indicates a completely different number of posts and topics for the remote category.
Even weirder though most of the topics that are correctly slotted into it, they are not actually in the category page, e.g. https://community.nodebb.org/topic/a85b0eff-5219-46ba-9ad4-a5d417a7bec5/minor-update-2-for-vivaldi-desktop-browser-7.3
Screenshots
Screenshots
schrieb am 2. Apr. 2025, 21:31 zuletzt editiert vonActually, I think I know what's going on with the Vivaldi blog group actor - it's not necessarily NodeBB's fault.
Inspecting the AP objects coming from vivaldi.com/blog, all the English-written blog posts have their
as:audience
field set tohttps://vivaldi.com/?author=0
.Meanwhile, every other blog post that is written in a different language instead have it set to
https://vivaldi.com//?author=0
, so for Japanese blog posts, for example, it ishttps://vivaldi.com/ja/?author=0
.And all these URLs link to different group actors, but all of them have the same value on the
preferredUsername
andwebfinger
properties:blog
, andblog@vivaldi.com
EDIT: Actually this also appears to be all actor objects coming from vivaldi.com/blog. E.g. if you start typing
[@ruari@vivaldi.com](https://community.nodebb.org/user/ruari%40vivaldi.com)
or search for it, you can see it be suggested twice too.So my guess is that there are two person actors that NodeBB knows of that are claiming to be
ruari@vivaldi.com
:https://vivaldi.com/?author=46
andhttps://vivaldi.com/ja/?author=46
.This is probably a bug with the WPML+ActivityPub plugin combination they have going on.
Screenshots
as:audience
preferredUsername
andwebfinger
properties:blog
ruari@vivaldi.com
Screenshots
schrieb am 3. Apr. 2025, 15:11 zuletzt editiert von@AltCode okay! Thanks for reporting, it sounds like there are two issues going on:
- Categories losing their handle-to-id association
- Frustratingly, this read very similarly to #13283, and both remote users and categories share similar logic. I have so far not been able to reproduce it at all on local development.
- Separate users (different IDs) sharing the same
preferredUsername
.- This is an interesting one, and I am not entirely sure where the fault lies. I wonder how other software handles it?
schrieb am 3. Apr. 2025, 15:25 zuletzt editiert von
@AltCode I forked this out to a new topic. I think it's time to loop @pfefferle@mastodon.social into the conversation (at the very least so this could be potentially escalated).
Mattias, it seems that when the WPML and ActivityPub plugins are enabled together, notes federated out by the blog user in another language have different
id
s but the samepreferredUsername
.e.g.
ruari@vivaldi.com: https://vivaldi.com/?author=46
NodeBB interprets this as two different users. Curiously, Mastodon does not, the second ID explicitly does not resolve.
So there can be two solutions here:
- The underlying issue can be fixed by WordPress, the solution of which is out of scope (for me at least)
- NodeBB can adopt whatever mechanism Mastodon is using... which is most likely that Mastodon does a two-way when asserting an ID, and ensures that the webfinger resource points to the ID.
schrieb am 3. Apr. 2025, 15:28 zuletzt editiert von
The remaining questions here are:
- whether
preferredUsername
is meant to be unique to the instance (in which case having multipleid
s point to an identicalpreferredUsername
would be a violation), and - what exactly AP software should do when it encounters this situation... store a list of "known alias" IDs? There are potential security issues to doing so.
- whether
schrieb am 3. Apr. 2025, 15:33 zuletzt editiert von
@AltCode all three flipboard remote categories seem to be working now
schrieb am 22. Apr. 2025, 09:30 zuletzt editiert von
This is getting out of hand! Now, there are six of them!
schrieb am 22. Apr. 2025, 19:13 zuletzt editiert von@AltCode This should be fixed in the upcoming v4.3.0.
Actor assertion should not proceed if passed-in ID does not pass a webfinger query · Issue #13352 · NodeBB/NodeBB
I think NodeBB checks that the ID exists, and then proceeds with a full actor assert/update if it doesn't find it. Which leads to weird stuff as discovered by @altcode@community.nodebb.org where: One user with id: https://vivaldi.com/?au...
GitHub (github.com)
It won't proactively remove the duplicates, but they'll be pruned out within ~7 days.
schrieb am 29. Apr. 2025, 14:57 zuletzt editiert von
Bit of a thought experiment here as to how to handle these duplicate accounts.
(tl;dr two federated accounts with different IDs report the same webfinger handle, what do?)
Let's say @ruario@social.vivaldi.net posts an English article under his account (and then is federated), and posts a translated Japanese one that is also federated, but under the Japanese ID.
What should NodeBB do when encountering the latter? Currently, it will try to assert the actor, fail the webfinger backreference check, and probably drop the post. Not so good.
One could adjust the actor to the former (canonical ID), but that's not technically right either.
That also opens up potential account impersonation possibilities, so that is something that would need addressing as well.
schrieb am 29. Apr. 2025, 19:03 zuletzt editiert von
@pfefferle@mastodon.social just wanted to poke you about this issue again.
The latest updates to NodeBB now do a webfinger backcheck to ensure that the actor has a valid webfinger entry for their purported handle. If it does not, then the user is not properly created. Mastodon also does this. This check is probably for security as well as for preventing handle collisions.
The multilingual plugin in conjunction with the ActivityPub plugin creates users that share the same handle, and that causes issues with federated content.
For example, this article by @jonvt@vivaldi.com will load up just fine in Mastodon, but this japanese article by @akira@vivaldi.com will not, because that second article's
attributedTo
ishttps://vivaldi.com/ja/?author=176
, which fails that check (the author's ID is actually https://vivaldi.com?author=176 as per the handle backcheck)cc @AltCode
