  • 18 Stimmen
    tal@lemmy.todayT
    In the past five years, India’s imports of rare earths from China have gone up 60 to 80 per cent, and the government is now trying to cut this reliance by increasing local production. In March it announced a liberalised scheme allowing private companies to explore minerals and rare earth elements and opened some 13 acreages up for auction. Under this policy, the government will also reimburse half the exploration costs in areas where no minerals are discovered. I don't think that India needs extraction so much as processing, where China is really dominant.
  • Programming languages
  • 84 Stimmen
    12 Beiträge
    2 Aufrufe
    cupcakezealot@lemmy.blahaj.zoneC
    i like how ask photos is not just a dumb idea but it's also a dumb name
  • 6 Stimmen
    Oh I agree. I just think is part of the equation perhaps the thinner and lighter will enable for better processor? Not an AR guy , although I lived my oculus until FB got hold of it. Didn't use it ever again after that day.
  • 27 Stimmen
    14 Beiträge
    R
    Tech execs when the shortage hits: I just had a brilliant idea! Let's just give untrained junior vibe-coding engineers the power of senior engineers, and even more AI tools. Problem solved forever, bonus please!
    2 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
  • *deleted by creator*
    2 Aufrufe
    G
    Wow... Just learned about that NOW. I wanted to play some games today and wondered why my account doesnt work nor the "forgot password"-Function... Fuck Meta. Fuck Oculus... Fuck this whole Enshittification that is going on lately... Is there ANY Way, to get my CV1 to run Without an account?!
