I’m kind of surprised he made absolutely no mention of manual gearbox vehicles. Some of the problems he’s describing predate EVs and adaptive cruise. I have a manual car and motorcycle. I pretty regularly apply just enough to the brakes to turn the light on without engaging them during engine braking. Engine braking depending on gear choice can be pretty strong. Likely not as aggressive as a regenerative braking system but more than enough to cause issues. I’m certain I’d have been rear ended if I didn’t make the lights turn on while just slowing down, not coming to a full stop.
schrieb am 6. Juni 2025, 05:30 zuletzt editiert vonI feel like if your car is doing anything to actively slow itself down (as in apart from just cruising) it should turn the brake lights on.
Yeah my electric 208 is kinda like that (if I remember the video well, watched it a while ago) but since it's Europe there actually is a regulation about how much a car can decelerate before break lights come on, so instead of making the system turn the lights on they throttle how much it can decelerate for recharge and still makes you use the break to use full regen (and eventually the actual brakes, of course). So it's not a real "one pedal driving".
schrieb am 6. Juni 2025, 05:31 zuletzt editiert vonOne pedal driving just sounds like motion sickness city.
sliding light or arrows
schrieb am 6. Juni 2025, 05:31 zuletzt editiert vonHow would that work? If you look from the side you suddenly don't see anything again, or an arrow point forwards or backwards?
If you look from the front, current turn signals work for that already.
schrieb am 6. Juni 2025, 05:33 zuletzt editiert vonAbsolutely, but that doesn't solve the problem that's talked about here (seeing the turn signal from the other side of the vehicle). It might be clearer what the turn signal is, but if you look at the right side of a vehicle, you won't be able to see the left headlight, even when it's massive.
okay, pick a different color then. it's a solvable problem.
schrieb am 6. Juni 2025, 05:41 zuletzt editiert vonIt's not that easy I think (and you had by far the best idea in this thread now).
Can't make them red or orange, they'd be just turn signals.
Can't make them green, that wouldn't work for color blind people, and since you actually need the color for understanding what signal you get (unlike traffic lights) you actually have to make it work
And arguably you can't really make them white, because you can't see a white blinking light inside a headlight and couldn't differentiate it from the back light. Same with light blue.
Which leaves darker shades of blue, which are really hard to see in daylight.
schrieb am 6. Juni 2025, 05:47 zuletzt editiert vonI am not trying to brake check people and get in an accident but I would very much like a signal for "Please remove your car from my butthole, it's getting uncomfortable."
agreed, I don't think the blinker switch should be removed, but a late indicator is better than no indicator.
schrieb am 6. Juni 2025, 05:50 zuletzt editiert vonHow would that work? On the highway, a slight nudge on a straight means you'll cross a lane, meaning turn signals on.
A kilometer later, the exact same slight nudge could mean it's just a light turn in the road, meaning signals off.
Now you could mandate cameras in all vehicles, which analyze your driving and turn on the turn signals when it thinks you're making a turn. Now who's responsible in a false positive if someone else dodges you and crashes because you suddenly turned on the signals without turning? Except it wasn't you, but your car. Oh and also you made entry level cars 10k more expensive, making them way more inaccessible if you aren't rich.
CB radios often had a "PA" switch that sent your microphone audio to a loudspeaker under the hood.
I'd prefer a "FlameThrower" button next to the horn.
schrieb am 6. Juni 2025, 05:59 zuletzt editiert vonCB radios often had a "PA" switch that sent your microphone audio to a loudspeaker under the hood
We used to roll those back in the day. A friend gave my very drunk self a lift home one evening and I used it to give commentary to a group of revellers on the side of the road... who threw a beer bottle at us, and then chased the car which luckily didn't get stopped at the traffic light nearby.
Good times.
schrieb am 6. Juni 2025, 06:20 zuletzt editiert von aesthelete@lemmy.world 6. Juni 2025, 08:20These exist. I used to deliver pizza and one of my coworkers installed one of these on their car.
Don't worry, my fellow americans, we'll still manage to fuck it up.
schrieb am 6. Juni 2025, 06:24 zuletzt editiert vonThey'll likely give those front brake lights an amber color
schrieb am 6. Juni 2025, 06:27 zuletzt editiert vonYes, and an oil slick button that drops some oil on the road for the hard of hearing tail rider.
schrieb am 6. Juni 2025, 06:43 zuletzt editiert vonNah not at all tbh, you can get very smooth deceleration with it and it doesn't feel floaty or whatever, it does take a tiny adjustment to how you drive, you don't coast anymore but rather you can finely control your deceleration by how much you lift the accelerator, it's quite nice to be honest I always drive it in that mode (even if it's not real one pedal).
Good luck transporting a couch on a motorbike.
schrieb am 6. Juni 2025, 06:54 zuletzt editiert von -
No. I want to make my voice loud enough for me to stop at a red light and ask the guy behind me if there is a proctology emergency or if they could stop riding my ass, and savor their expression as it dawns on them what is happening.
schrieb am 6. Juni 2025, 06:59 zuletzt editiert vonThis is definitely a thing. I had a friend in high-school who put a loud speaker in his 69 Tempest. He was funny too. He would say the silliest things to people.
Motorcycle rider here. Yes, families with children will rent a truck anytime they want to purchase groceries, and when it’s raining. It’s not practical.
This is a stupid thread.
schrieb am 6. Juni 2025, 07:02 zuletzt editiert von fnrir@lemmy.blahaj.zone 6. Juni 2025, 09:04The maybe use public transport? If you REALLY need to use buy car - buy one.
Also: families were not mentioned before in this thread.
Is driving around with your partner and 5 kids and a couch a daily occasion? -
schrieb am 6. Juni 2025, 07:05 zuletzt editiert vonLiknks or didn't happen
Study from TU Graz Reveals Front Brake Lights Could Drastically Diminish
The concept of a front brake light has been floating around the automotive industry for some time now. However, no vehicle manufacturer has yet embraced the idea and turned it into a reality on the roads. Recently, a research team led by Ernst Tomasch from the Institute of Vehicle Safety at Graz University of
BIOENGINEER.ORG (bioengineer.org)
schrieb am 6. Juni 2025, 07:19 zuletzt editiert vonWouldn’t better driving education and testing work just as well, if not better?
schrieb am 6. Juni 2025, 07:22 zuletzt editiert vonMaybe introducing driving lessons on the read and done by professionals all over the world would already change a lot. That and the introduction of better road systems like roundabouts, reducing road traffic by adding public transport and walkable/bikeable area's etc.
schrieb am 6. Juni 2025, 07:58 zuletzt editiert vonShut up nerd
schrieb am 6. Juni 2025, 08:10 zuletzt editiert vonI've never done it, but I wonder if turning on the rear fog lights would work. You're not braking, but they might think you are. I don't know what the legality of that would be
Jeff Bezos taps former Amazon Alexa head to lead $10 billion Earth fund
Technology 15. Juli 2025, 17:431
Bluesky finally got Activity Notifications, you can now follow news and accounts with it.
Technology 7. Juli 2025, 21:512
Ways the Trump Administration Has Sabotaged America’s Broadband Future
Technology 23. Juni 2025, 22:491
Scientists Discover That Feeding AI Models 10% 4Chan Trash Actually Makes Them Better Behaved
Technology 9. Juni 2025, 12:361
Community Notes vanishes from X feeds, raising 'serious questions' amid ongoing EU probe
Technology 28. Mai 2025, 17:011
