schrieb am 5. Juni 2025, 21:41 zuletzt editiert vonI've seen newer cars turn the headlight off while the turn indicator is on, so you get a sort of double-blink effect
Those are typically DRLs. Chrysler did this for a while in the 2000s-2010s (maybe still, idk), where the high beam - in DRL mode - turns off while the turn signal is doing it's thing. Other manufacturers do this with dedicated DRLs, sometimes integrating the DRLs and turn signals into one multicolored unit (Kia Telluride, for example).
No manufacturer shuts off a headlight for a turn signal when the headlights are intentionally turned on (whether by light sensors at night, or by the driver).
schrieb am 5. Juni 2025, 21:50 zuletzt editiert vonThere are a couple situations where it's annoying and I turn it off. My truck has the "steer back into lane" style assist, but it's tried to push me off the road before while I was towing a trailer on some narrow 1-lane roads. Some of the corners it's just not possible to get around without touching the center line.
The vast majority of the time it stays on though and is quite helpful.
There was an EU rule about ten years ago that stipulated that rear lights are no longer mandatory in daylight. The reasoning being to save on fuel. Which is a ridiculous reason, even more so with today's LED lights.
All cars in Sweden used to have the rear lights turned on at all time, even if the light switch was in the off position, but that changed around the same time.schrieb am 5. Juni 2025, 21:57 zuletzt editiert von felixcress@lemmy.world 6. Mai 2025, 23:59that stipulated that rear lights are no longer mandatory in daylight.
I don't believe these were ever mandatory in the EU? UK never had such requirement.
Edit:
What I mean is there are EU countries where lights are still mandatory and countries where it isn't so I cannot see how it could be linked to EU requirements either way.
schrieb am 5. Juni 2025, 21:59 zuletzt editiert vonI see a lot of those on trucks here in the south. Good for when you are towing shit so people can see around all your junk in the trailer.
schrieb am 5. Juni 2025, 22:00 zuletzt editiert vonColorblind person here. If we're talking about limited visibility differentiation of front and back, the color of light is way less noticeable than whether we're looking at headlights or not (based on intensity). There would be no issue telling whether we're looking at a front brake light or a back brake light so long as the front brake light has headlights around it.
https://www.youtube.com/watch?v=U0YW7x9U5TQschrieb am 5. Juni 2025, 22:09 zuletzt editiert vonYeah my electric 208 is kinda like that (if I remember the video well, watched it a while ago) but since it's Europe there actually is a regulation about how much a car can decelerate before break lights come on, so instead of making the system turn the lights on they throttle how much it can decelerate for recharge and still makes you use the break to use full regen (and eventually the actual brakes, of course). So it's not a real "one pedal driving".
Edit for consistency
schrieb am 5. Juni 2025, 22:11 zuletzt editiert vonI think some cars also turn on the hazards automatically if you really hammer the breaks.
schrieb am 5. Juni 2025, 22:18 zuletzt editiert vonOkay Verstappen calm down there
schrieb am 5. Juni 2025, 22:24 zuletzt editiert vonSince we're all throwing random ideas out here, I want to equip my vehicle with an annoyingly loud external speaker so that when someone near me does something dumb, I can personally shame them.
schrieb am 5. Juni 2025, 22:45 zuletzt editiert vonThere's this idea I've been considering for a long time.
Imagine putting a remote controlled firework smoke bomb under the tailpipe, hidden from sight. At best a really stinky one that smells like burned rubber or something.
When someone follows to closely, just fake an engine issue or something by activating the smoke bomb and fill their AC air intake with the smell of burned rubber for weeks. Just to teach them to not follow too closely again.
schrieb am 5. Juni 2025, 22:46 zuletzt editiert von90% of the things that Japan introduced according to comment sections on the internet never happened (or never made it past the prototype stage) and the rest was actually introduced in Korea, not in Japan.
The Japanophilia is strong with a lot of people on the internet.
schrieb am 5. Juni 2025, 22:55 zuletzt editiert vonThat could probably be implemented in most existing vehicles, and at least it would provide more information.
schrieb am 5. Juni 2025, 22:59 zuletzt editiert vonI suspect because there's no consistency in the brightness of vehicle lights. But that's one of the reasons why I think an incremental light bar would be better, there's no variation between vehicles. You could even make it more informative by flashing the whole bar when you first brake, so someone behind you can more easily see how much of the bar is being lit up.
schrieb am 5. Juni 2025, 23:06 zuletzt editiert vonI suspect a lot of that has to do with the entitled way people are driving these days. If you leave a car length gap, some kid will wrecklessly attempt to cram their way in because your lane momentarily moved slightly faster.
schrieb am 5. Juni 2025, 23:11 zuletzt editiert vonDoes your state not require good lights on the trailers? I just built a new trailer last year, I was required to have full working brake and turn signals along with running lights, but I went the extra step and included more brake/turn lights on the front and rear of the fenders, along with reverse lights plus four marker lights along each side. Trailers are hard enough to see, I didn't want to make it harder for anyone by just sticking with the bare minimum.
schrieb am 5. Juni 2025, 23:11 zuletzt editiert vonCounterpoint: the dumb people could have them as well.
schrieb am 5. Juni 2025, 23:18 zuletzt editiert vonEvery car needs proximity chat so traffic becomes like a COD lobby.
schrieb am 5. Juni 2025, 23:37 zuletzt editiert vonNow there's a Black Mirror episode with true horror!
schrieb am 5. Juni 2025, 23:55 zuletzt editiert vonPlenty of cars flash their brake lights when ABS(/ESP?) engages, which is reasonable and should be a legal requirement IMO.
There's lots of room to give additional info in between that and "brake light is on because the driver doesn't understand that they can do mild adjustments by letting off the gas / stupid bitch-ass VW PHEV computer thinks using cruise control downhill with electric regen requires the motherfucking brake lights". It's like no-one realizes or cares that brake lights lose all purpose if they're on when the car isn't meaningfully decelerating. ARGH.
schrieb am 6. Juni 2025, 00:07 zuletzt editiert vonThere's a programmable flasher relay that does exactly this. It's specific to certain Toyota/Lexus and Subarus from the 2000s to mid-2010s, but it's something. I have one in my 2008 Sienna - the "emergency flasher" part is programmed to strobe, kinda like a tow truck. I like it.
Meta said it supports proposals for an EU-wide age of digital adulthood, below which minors would need parental consent to use social media
Technology337 vor 25 Tagen4. Juli 2025, 07:531
Republican National Convention Sued for Sending Unhinged Text Messages Soliciting Donations to Donald Trump’s Campaign and Continuing to Text Even After Trying to Unsubscribe.
Technology 16. Juni 2025, 17:481
Salt Lake City, plans to implement AI-assisted 911 call triaging to handle ~30% of about 450K non-emergency calls per year
Technology 14. Juni 2025, 18:481
Meo: AI Girlfriend Sparks Debate Over Digital Intimacy and Emotional Ethics
Technology 12. Juni 2025, 19:511
