I got tired of asking my family to download yet another app. Went iPhone at this point.
schrieb am 22. Juni 2025, 22:23 zuletzt editiert vonHow many apps did you ask them to download?
Personally, I only asked for this one, and everyone who is of importance to me chose to do it.
This post did not contain any content.schrieb am 22. Juni 2025, 22:45 zuletzt editiert von
Don't ask me for a phone number and I'll use it.
I will use the opportunity to remind that Signal is operated by a non-profit in the jurisdiction called "the US". This could have implications.
A somewhat more anarchist option might be TOX. There is no single client, TOX is a protocol, you can choose from half a dozen clients. I personally use qTox.
Upside: no phone number required. No questions asked.
Downside: no servers to store and forward messages. You can talk if both parties are online.
schrieb am 22. Juni 2025, 22:46 zuletzt editiert von ikidd@lemmy.worldPhone number is required for registration, after that you can move to a username. So you're being tracked.
My wishlist is an app which is not linked to a phone number, is multi platform and has a web app. It should be none US and open source. That isn’t too many requirements and yet nothing seems to full fit the bill? Anyway good luck trying to get school parent’s groups to use something other than WhatsApp.
schrieb am 22. Juni 2025, 22:49 zuletzt editiert vonMatrix and Element. Run your own server if you want or use a server that's not in the US.
schrieb am 22. Juni 2025, 22:55 zuletzt editiert vonWhen did WhatsApp start allowing signups without a phone number?
schrieb am 22. Juni 2025, 22:57 zuletzt editiert vonNo clue. Never even tried to use it since it's a Meta product. I was referring to Signal's phone # requirement being a non-starter.
Molly is in f-droid, though it's technically third party. Looks identical though.
schrieb am 22. Juni 2025, 23:09 zuletzt editiert vonI was looking at Molly.im and it has its own f-droid repo. There are two options: with and without Google servicios.
Does it really matter who made it if you can see the source code? You don't have to trust them.
schrieb am 22. Juni 2025, 23:10 zuletzt editiert vonThat’s kind of a core tenet of libre/open software, innit? Independently verifiable software that you can change at your pleasure.
schrieb am 22. Juni 2025, 23:14 zuletzt editiert vonCan you though? Can I build the apk myself and use their services?
Anyone know why the Signal app isn't available on F-Droid? Isn't it supposed to be open source?
schrieb am 22. Juni 2025, 23:28 zuletzt editiert vonYou can install and update it through Obtainium directly from GitHub.
schrieb am 22. Juni 2025, 23:39 zuletzt editiert vonYes, you can use their exact build environment straight from GitHub. You can also use Molly.im which is another app that i think is a fork? Im still investigating it.
schrieb am 22. Juni 2025, 23:45 zuletzt editiert vonSo what do you use now?
schrieb am 23. Juni 2025, 00:02 zuletzt editiert von tym@lemmy.worldThe irony of you posting this on lemmy, which won't allow posting from a VPN or masked email addresses is not lost on me.
The amount of hoops I had to jump through to make this comment and maintain some semblance of privacy is infuriating but at least it's not reddit I guess?
But do go on about your security standards...
Edit: BTW, you can set signal to hide your number completely. Combined with FOSS-based encryption keys on-device makes signal the only choice for trying to maintain freedom of expression globally.
Nothing will protect anyone from messaging with a snitch who knows how to screenshot though. Food for thought.. get to know your neighbors now.
schrieb am 23. Juni 2025, 00:16 zuletzt editiert vonI use Element.
schrieb am 23. Juni 2025, 01:27 zuletzt editiert vonYou're using the wrong lemmy server then, no problem with mine
I use Element.
schrieb am 23. Juni 2025, 01:30 zuletzt editiert vonI use both and have been happy with both, but note that Element / Matrix have recently announced the intent to add paid service tiers.
schrieb am 23. Juni 2025, 02:13 zuletzt editiert vonIt doesn't matter if you hide the number; at some point they deanonymized you when you signed up.
Want to be a dick about "hoops"? Get a number that isn't traceable. It can be done, but it's tough. I doubt its possible in the countries that really need anonymity of association.
schrieb am 23. Juni 2025, 02:27 zuletzt editiert vonIf you're reading this comment, I posted it from proton vpn
The founder of SimpleX is out of his mind. Check yourself: https://xcancel.com/epoberezkin
schrieb am 23. Juni 2025, 04:03 zuletzt editiert von fireiced@lemmy.super.ynh.frIt doesn’t look good indeed…
Sadly, that’s what we have to work with. The app is pretty good though
TIL the founder is a transphobic and conservative piece of shit
I believe in it,... for now.
I moved my family group to xmpp to have more personal control over our chats. Signal seems benevolent, but I've seen this play out before. Will it stay that way? We treat online forums with the idea that federstion works to stop enshittificstion. I believe XMPP is a good model for federating secure chatrooms for the same reason: People should control the voices of the people, not companies.
schrieb am 23. Juni 2025, 04:33 zuletzt editiert vonI am so excited to see people embracing xmpp! I’ve been using it since 2010 and I was really bummed when my company got swallowed up by a huge conglomerate and we were forced to use their shitty proprietary one.
Microsoft CFO calls for 'intensity' in an internal memo, after blowout earnings
Technology235 vor 8 Tagenvor 10 Tagen1
PARP Inhibitors Market - Current Impact to Make Big Changes by 2035
Technology235 vor 23 Tagenvor 23 Tagen1
Anthropic, tasked an AI with running a vending machine in its offices, sold at big loss while inventing people, meetings, and experiencing a bizarre identity crisis
Technology 2. Juli 2025, 00:391
