ROCKPro64 - USB3 Probleme
ROCKPro64
1 1 926
  • Nehmen wir einen uralten USB2-Stick, Größe 8GB und flashen Kamil's letztes Image drauf. Ab in den USB3-Port und starten.
    USB2-Stick am USB3-Port
    System
    rock64@rockpro64:~$ uname -a
    Linux rockpro64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
    lsusb
    rock64@rockpro64:~$ lsusb
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 002: ID 090c:1000 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) Flash Drive
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    fdisk
     Disk /dev/sda: 7.5 GiB, 8022654976 bytes, 15669248 sectors
     Units: sectors of 1 * 512 = 512 bytes
     Sector size (logical/physical): 512 bytes / 512 bytes
     I/O size (minimum/optimal): 512 bytes / 512 bytes
     Disklabel type: gpt
     Disk identifier: 2C9A4A22-7AA8-4A1B-815E-0C3E2E7065E6
     Device      Start      End  Sectors  Size Type
     /dev/sda1      64     8063     8000  3.9M Linux filesystem
     /dev/sda2    8064     8191      128   64K Linux filesystem
     /dev/sda3    8192    16383     8192    4M Linux filesystem
     /dev/sda4   16384    24575     8192    4M Linux filesystem
     /dev/sda5   24576    32767     8192    4M Linux filesystem
     /dev/sda6   32768   262143   229376  112M Microsoft basic data
     /dev/sda7  262144 15669214 15407071  7.4G Linux filesystem
    dmesg
    rock64@rockpro64:~$ sudo dmesg | grep -i usb
    [    0.506700] usbcore: registered new interface driver usbfs
    [    0.506756] usbcore: registered new interface driver hub
    [    0.506852] usbcore: registered new device driver usb
    [    0.909861] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply from device tree
    [    0.909874] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
    [    0.910150] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up vbus-supply from device tree
    [    0.910161] phy phy-ff770000.syscon:usb2-phy@e460.0: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
    [    0.910174] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS supply regulator
    [    0.910358] phy phy-ff770000.syscon:usb2-phy@e460.1: Looking up phy-supply from device tree
    [    0.910440] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e460.1 err -2
    [    0.912857] phy phy-ff800000.phy.4: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
    [    1.044647] usbcore: registered new interface driver udl
    [    1.151977] usbcore: registered new interface driver cdc_ether
    [    1.152585] usbcore: registered new interface driver rndis_host
    [    1.155022] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
    [    1.161158] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
    [    1.163433] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.169174] ehci-platform fe3c0000.usb: EHCI Host Controller
    [    1.169931] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
    [    1.170823] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
    [    1.177217] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
    [    1.178021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    1.178666] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.179363] usb usb1: Product: EHCI Host Controller
    [    1.179823] usb usb1: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 ehci_hcd
    [    1.180631] usb usb1: SerialNumber: fe3c0000.usb
    [    1.181678] hub 1-0:1.0: USB hub found
    [    1.183295] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    1.185080] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
    [    1.185923] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
    [    1.186791] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
    [    1.242415] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
    [    1.243045] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.243742] usb usb2: Product: Generic Platform OHCI controller
    [    1.244307] usb usb2: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 ohci_hcd
    [    1.245104] usb usb2: SerialNumber: fe3e0000.usb
    [    1.246158] hub 2-0:1.0: USB hub found
    [    1.249659] usbcore: registered new interface driver iforce
    [    1.250247] usbcore: registered new interface driver xpad
    [    1.251035] usbcore: registered new interface driver usbtouchscreen
    [    1.294313] fusb302 4-0022: GPIO lookup for consumer int-n
    [    1.294325] fusb302 4-0022: using device tree for GPIO lookup
    [    1.294366] of_get_named_gpiod_flags: parsed 'int-n-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
    [    1.294400] fusb302 4-0022: GPIO lookup for consumer vbus-5v
    [    1.294410] fusb302 4-0022: using device tree for GPIO lookup
    [    1.294442] of_get_named_gpiod_flags: parsed 'vbus-5v-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]' - status (0)
    [    1.294473] fusb302 4-0022: GPIO lookup for consumer vbus-other
    [    1.294482] fusb302 4-0022: using device tree for GPIO lookup
    [    1.294494] of_get_named_gpiod_flags: can't parse 'vbus-other-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
    [    1.294505] of_get_named_gpiod_flags: can't parse 'vbus-other-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
    [    1.294515] fusb302 4-0022: using lookup tables for GPIO lookup
    [    1.294525] fusb302 4-0022: lookup for GPIO vbus-other failed
    [    1.294536] fusb302 4-0022: GPIO lookup for consumer discharge
    [    1.294546] fusb302 4-0022: using device tree for GPIO lookup
    [    1.294556] of_get_named_gpiod_flags: can't parse 'discharge-gpios' property of node '/i2c@ff3d0000/fusb30x@22[0]'
    [    1.294567] of_get_named_gpiod_flags: can't parse 'discharge-gpio' property of node '/i2c@ff3d0000/fusb30x@22[0]'
    [    1.294576] fusb302 4-0022: using lookup tables for GPIO lookup
    [    1.294586] fusb302 4-0022: lookup for GPIO discharge failed
    [    1.294794] fusb302 4-0022: Can't get property of role, set role to default DRP
    [    1.304027] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_NONE
    [    1.311598] usbcore: registered new interface driver uvcvideo
    [    1.312130] USB Video Class driver (1.1.1)
    [    1.323011] usbcore: registered new interface driver bfusb
    [    1.323622] usbcore: registered new interface driver btusb
    [    1.402019] usbcore: registered new interface driver usbhid
    [    1.402547] usbhid: USB HID core driver
    [    1.406726] usbcore: registered new interface driver snd-usb-audio
    [    1.635272] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up phy-supply from device tree
    [    1.635280] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
    [    1.635486] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up vbus-supply from device tree
    [    1.635492] phy phy-ff770000.syscon:usb2-phy@e450.5: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
    [    1.635501] phy phy-ff770000.syscon:usb2-phy@e450.5: Failed to get VBUS supply regulator
    [    1.636465] phy phy-ff770000.syscon:usb2-phy@e450.6: Looking up phy-supply from device tree
    [    1.636532] vcc5v0_host: could not add device link phy-ff770000.syscon:usb2-phy@e450.6 err -2
    [    1.637072] phy phy-ff7c0000.phy.8: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
    [    2.002312] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 3
    [    2.005009] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.005732] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.006494] usb usb3: Product: xHCI Host Controller
    [    2.007009] usb usb3: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
    [    2.007904] usb usb3: SerialNumber: xhci-hcd.5.auto
    [    2.008827] hub 3-0:1.0: USB hub found
    [    2.010665] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 4
    [    2.011522] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    2.012453] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
    [    2.013164] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.013932] usb usb4: Product: xHCI Host Controller
    [    2.014454] usb usb4: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
    [    2.015351] usb usb4: SerialNumber: xhci-hcd.5.auto
    [    2.016257] hub 4-0:1.0: USB hub found
    [    2.018942] usb usb4: USB disconnect, device number 1
    [    2.044906] xhci-hcd xhci-hcd.5.auto: USB bus 4 deregistered
    [    2.046163] usb usb3: USB disconnect, device number 1
    [    2.047960] xhci-hcd xhci-hcd.5.auto: USB bus 3 deregistered
    [    2.056668] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 3
    [    2.059352] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.060063] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.060827] usb usb3: Product: xHCI Host Controller
    [    2.061348] usb usb3: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
    [    2.062244] usb usb3: SerialNumber: xhci-hcd.6.auto
    [    2.063232] hub 3-0:1.0: USB hub found
    [    2.076328] xhci-hcd xhci-hcd.6.auto: new USB bus registered, assigned bus number 4
    [    2.086994] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
    [    2.097798] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
    [    2.108306] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.114105] usb usb4: Product: xHCI Host Controller
    [    2.119391] usb usb4: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 xhci-hcd
    [    2.125089] usb usb4: SerialNumber: xhci-hcd.6.auto
    [    2.131514] hub 4-0:1.0: USB hub found
    [    2.144513] ehci-platform fe380000.usb: EHCI Host Controller
    [    2.149510] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
    [    2.154292] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000
    [    2.164358] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
    [    2.168907] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.173322] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.177741] usb usb5: Product: EHCI Host Controller
    [    2.181911] usb usb5: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 ehci_hcd
    [    2.186427] usb usb5: SerialNumber: fe380000.usb
    [    2.191426] hub 5-0:1.0: USB hub found
    [    2.199780] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
    [    2.204285] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
    [    2.208254] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000
    [    2.266912] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
    [    2.285507] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.303922] usb usb6: Product: Generic Platform OHCI controller
    [    2.322261] usb usb6: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524 ohci_hcd
    [    2.341046] usb usb6: SerialNumber: fe3a0000.usb
    [    2.361476] hub 6-0:1.0: USB hub found
    [    2.461390] usb 3-1: new high-speed USB device number 2 using xhci-hcd
    [    2.667220] usb 3-1: New USB device found, idVendor=090c, idProduct=1000
    [    2.667226] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.667230] usb 3-1: Product: USB Flash Disk
    [    2.667234] usb 3-1: Manufacturer: General
    [    2.667238] usb 3-1: SerialNumber: 042NR6E8C5MLE2GT
    [    2.712883] usb 3-1: ep 0x81 - rounding interval to 128 microframes, ep desc says 255 microframes
    [    2.719848] usb 3-1: ep 0x2 - rounding interval to 128 microframes, ep desc says 255 microframes
    [    3.080440] usb-storage 3-1:1.0: USB Mass Storage device detected
    [    3.081243] scsi host0: usb-storage 3-1:1.0
    [    3.081460] usbcore: registered new interface driver usb-storage
    [    3.082140] usbcore: registered new interface driver uas
    [    4.215095] scsi 0:0:0:0: Direct-Access     General  USB Flash Disk   1100 PQ: 0 ANSI: 4
    Das System läuft. Das Logfile -> https://pastebin.com/FimTdZc3
    Nun wollen wir mal schauen, was der andere Stick so auswirft. Den Corsair Voyager GTX eingesteckt und Los!
    USB3-Stick am USB3-Port
    Log
     =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2018.09.20 09:12:03 =~=~=~=~=~=~=~=~=~=~=~=
     DDR Version 1.13 20180801
     In
     Channel 0: LPDDR4,50MHz
     CS = 0
     MR0=0x98
     MR4=0x3
     MR5=0xFF
     MR8=0x8
     MR12=0x4D
     MR14=0x4D
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x3
     MR5=0xFF
     MR8=0x8
     MR12=0x4D
     MR14=0x4D
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
     Channel 1: LPDDR4,50MHz
     CS = 0
     MR0=0x98
     MR4=0x3
     MR5=0xFF
     MR8=0x8
     MR12=0x4D
     MR14=0x4D
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x1
     MR5=0xFF
     MR8=0x8
     MR12=0x4D
     MR14=0x4D
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     256B stride
     channel 0
     CS = 0
     MR0=0x98
     MR4=0x81
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x81
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     channel 1
     CS = 0
     MR0=0x98
     MR4=0x3
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x1
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     channel 0 training pass!
     channel 1 training pass!
     change freq to 400MHz 0,1
     channel 0
     CS = 0
     MR0=0x98
     MR4=0x1
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x1
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     channel 1
     CS = 0
     MR0=0x98
     MR4=0x81
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     CS = 1
     MR0=0x18
     MR4=0x1
     MR5=0xFF
     MR8=0x8
     MR12=0x72
     MR14=0x72
     MR18=0x0
     MR19=0x0
     MR24=0x8
     MR25=0x0
     change freq to 800MHz 1,0
     ch 0 ddrconfig = 0x101, ddrsize = 0x2020
     ch 1 ddrconfig = 0x101, ddrsize = 0x2020
     pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
     OUT
     U-Boot SPL board init
     U-Boot SPL 2017.09-rockchip-ayufan-1033-gdf02018479 (Aug 06 2018 - 22:29:15)
     booted from SPI flash
     Trying to boot from SPI
     NOTICE:  BL31: v1.3(debug):65aa5ce
     NOTICE:  BL31: Built : 10:47:37, Jun 19 2018
     NOTICE:  BL31: Rockchip release version: v1.1
     INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
     INFO:    Using opteed sec cpu_context!
     INFO:    boot cpu mask: 0
     INFO:    plat_rockchip_pmu_init(1151): pd status 3e
     INFO:    BL31: Initializing runtime services
     WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
     ERROR:   Error initializing runtime service opteed_fast
     INFO:    BL31: Preparing for EL3 exit to normal world
     INFO:    Entry point address = 0x200000
     INFO:    SPSR = 0x3c9
     U-Boot 2017.09-rockchip-ayufan-1033-gdf02018479 (Aug 06 2018 - 22:29:23 +0000)
     Model: Pine64 RockPro64
     DRAM:  3.9 GiB
     DCDC_REG1@vdd_center: ; enabling
     DCDC_REG2@vdd_cpu_l: ; enabling
     DCDC_REG3@vcc_ddr: ; enabling (ret: -38)
     DCDC_REG4@vcc_1v8: set 1800000 uV; enabling
     LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling
     LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling
     LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling
     LDO_REG4@vcc_sd: set 3300000 uV; enabling
     LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling
     LDO_REG6@vcc_1v5: set 1500000 uV; enabling
     LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling
     LDO_REG8@vcc_3v0: set 3000000 uV; enabling
     SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)
     SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)
     vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)
     dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)
     vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)
     vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)
     vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)
     vdd-log@vdd_log: ; enabling (ret: -38)
     MMC:   sdhci@fe330000: 0, dwmmc@fe320000: 1
     SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
     *** Warning - bad CRC, using default environment
     In:    serial@ff1a0000
     Out:   serial@ff1a0000
     Err:   serial@ff1a0000
     Net:   eth0: ethernet@fe300000
     Hit any key to stop autoboot:  0
     Card did not respond to voltage select!
     mmc_init: -95, time 20
     mmc_init: -95, time 9
     starting USB...
     USB0:   USB EHCI 1.00
     USB1:   USB EHCI 1.00
     USB2:   Register 2000140 NbrPorts 2
     Starting the controller
     USB XHCI 1.10
     USB3:   Register 2000140 NbrPorts 2
     USB XHCI 1.10
     scanning bus 0 for devices... 1 USB Device(s) found
     scanning bus 1 for devices... 1 USB Device(s) found
     scanning bus 2 for devices... 1 USB Device(s) found
     scanning bus 3 for devices... 1 USB Device(s) found
            scanning usb for storage devices... 0 Storage Device(s) found
     Device 0: unknown device
     Speed: 1000, full duplex
     BOOTP broadcast 1
     BOOTP broadcast 2
     BOOTP broadcast 3
     DHCP client bound to address 192.168.3.15 (1007 ms)
     *** Warning: no boot file name; using 'C0A8030F.img'
     Using ethernet@fe300000 device
     TFTP from server 0.0.0.0; our IP address is 192.168.3.15; sending through gateway 192.168.3.1
     Filename 'C0A8030F.img'.
     Load address: 0x800800
     Loading: *T T
    Es ist alles gleich zum anderen Log. Aber beim Scannen vom USB3-Bus wird der Stick nicht erkannt. Hmm???
    Der selbe Stick am USB2-Port.
    USB3-Stick am USB2-Port
    Logfile
    dmesg
    rock64@rockpro64v_2_1:~$ sudo dmesg | grep -i usb
    [sudo] password for rock64:
    [    1.796818] usbcore: registered new interface driver usbfs
    [    1.797086] usbcore: registered new interface driver hub
    [    1.797427] usbcore: registered new device driver usb
    [    4.830911] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
    [    4.831796] usbcore: registered new interface driver pegasus
    [    4.832477] usbcore: registered new interface driver rtl8150
    [    4.833082] usbcore: registered new interface driver r8152
    [    4.833652] usbcore: registered new interface driver asix
    [    4.834204] usbcore: registered new interface driver ax88179_178a
    [    4.834898] usbcore: registered new interface driver cdc_ether
    [    4.835490] usbcore: registered new interface driver dm9601
    [    4.836060] usbcore: registered new interface driver CoreChips
    [    4.836666] usbcore: registered new interface driver smsc75xx
    [    4.837264] usbcore: registered new interface driver smsc95xx
    [    4.837838] usbcore: registered new interface driver net1080
    [    4.838495] usbcore: registered new interface driver plusb
    [    4.839063] usbcore: registered new interface driver cdc_subset
    [    4.839665] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
    [    4.840440] usbcore: registered new interface driver cdc_ncm
    [    4.862016] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port
    [    4.878662] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    4.882898] ehci-platform fe380000.usb: EHCI Host Controller
    [    4.883450] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
    [    4.886020] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
    [    4.902423] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
    [    4.904589] hub 1-0:1.0: USB hub found
    [    4.909185] ehci-platform fe3c0000.usb: EHCI Host Controller
    [    4.909739] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
    [    4.912468] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
    [    4.926391] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
    [    4.928201] hub 2-0:1.0: USB hub found
    [    4.931723] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    4.933894] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
    [    4.934653] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
    [    4.937294] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
    [    4.999723] hub 3-0:1.0: USB hub found
    [    5.001606] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
    [    5.002237] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
    [    5.003822] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
    [    5.067579] hub 4-0:1.0: USB hub found
    [    5.072347] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
    [    5.079373] hub 5-0:1.0: USB hub found
    [    5.081263] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
    [    5.081968] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0  SuperSpeed
    [    5.082776] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
    [    5.084532] hub 6-0:1.0: USB hub found
    [    5.086777] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 7
    [    5.164548] hub 7-0:1.0: USB hub found
    [    5.188617] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 8
    [    5.191985] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0  SuperSpeed
    [    5.197829] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
    [    5.227852] hub 8-0:1.0: USB hub found
    [    5.271464] usbcore: registered new interface driver usb-storage
    [    5.572499] usbcore: registered new interface driver usbhid
    [    5.573102] usbhid: USB HID core driver
    [    6.610333] usb 1-1: new high-speed USB device number 2 using ehci-platform
    [    6.786867] usbcore: registered new interface driver uas
    lsusb
    rock64@rockpro64v_2_1:~$ lsusb
       Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
       Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
       Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
       Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
       Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
       Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
       Bus 001 Device 002: ID 1b1c:1a0e Corsair
    Ich kann hier leider gar nichts erkennen, wo man auf das Problem schließen kann. Aber evt. hat Kamil ja eine Erklärung dafür. 😞
  • OpenWrt
    Images rockpro64
    230 Aufrufe
  • ROCKPro64 - PCIe SATA-Karte mit JMicron JMS585- Chip
    Angeheftet Hardware jms585 linux rockpro64
    13
    13 Beiträge
    Ich möchte das dann hier zum Abschluss bringen, das NAS ist heute zusammengebaut worden. Hier zwei Fotos. [image: 1587814588721-img_20200425_102156_ergebnis.jpg] [image: 1587814595011-img_20200425_102206_ergebnis.jpg]
  • ROCKPro64 - USB3
    ROCKPro64 rockpro64
    319 Aufrufe
  • Zwischenfazit April 2019
    Angeheftet ROCKPro64 rockpro64
    604 Aufrufe
  • Benchmark
    ROCKPro64 rockpro64
    481 Aufrufe
  • eMMC Modul
    Hardware hardware rockpro64
  • ROCKPro64 - Schaltplan v2.1 veröffentlicht
    ROCKPro64 rockpro64
    924 Aufrufe
  • Mainline Commits
    ROCKPro64 rockpro64
    788 Aufrufe
    Mal diesen alten Thread wieder ausgraben. Qualcomm Snapdragon 835 SoC support along with the HiSilicon Hi3670, many NVIDIA Tegra improvements, GTA04A5 phone support, and more. There is also now mainline ARM SBC support for the Orange Pi Zero Plus2, Orange Pi One Plus, Pine64 LTS, Banana Pi M2+ H5, 64-bit Banana Pi M2+ H3, ASUS Tinker Board S, RockPro64, Rock960, and ROC-RK-3399-PC. Quelle: https://www.phoronix.com/scan.php?page=article&item=linux-420-features&num=1 Im Pine64 Forum gefunden.
