And never forget about the I-D ten T error.
ID10T for those who didn't get it.
First of all, this would be illegal in many countries.
Second of all: we can differentiate cars by: has red lights, back.
If we lose this option we can no longer differentiate easily if there is a car coming towards us or driving away from us.
I don't understand this at all. Why do I, as a person in front of a vehicle, care whether or not it's braking?
Say you're a pedestrian and a car is coming toward you as you're entering a crosswalk. Being able to see if they are braking or not could save your life.
Isn't that the case for pretty much everything? Newer cars alternate blinking their headlights and the signal indicator, and even cars w/ the turn signal on the side will have some light bleed through since it's all one assembly. In the majority of cars, I can see their turn signals when they're perpendicular to me. The larger issue is that most people in my area don't bother to use their signals in the first place.
How would you do that so it isn't ugly as hell and isn't prone to misunderstanding?
Yea, that's part of why I don't know for sure if they make cars the way the guy at the top of this thread is describing.
Can we do this in the same bill as the popup spikes that take out your tires if you stop across the crosswalk? The guided RPGs replacing red light cams can wait a little longer.
I get what you're saying — so it's about the subconscious awareness of the state change that happens after the driver decided to go, but before the car starts moving. I can see some amount of value in that.
I still can't help but think it's going to be interpreted by many as a sign that it's safe to proceed and ignore the car rather than be prepared for any eventuality, though.
It is to colorblind people. You could use something else of course, just saying...
If a car is braking it rides differently from one that isn't. A car is normally rather level and leans "forward" when braking.
Besides that, YOU SHOULDNT GET IN FRONT OF ANYTHING YOU ARENT SURE IS STOPPING. If it's moving fast enough that you need this, you shouldn't be trying to get in front anyways.
I feel that in my area the driving culture has become so toxic that there’s a better than average chance that indicating a lane change (which I always do) will lead to the vehicle in the lane you’re attempting to change into accelerating to prevent you from ‘getting in front of them.’
It’s so frustrating (and dangerous!). It seems that a lot of folks feel entitled to the road, or the patch of road in front of their car fro as long as the eye can see, and are willing to behave irrationally regarding it.I feel that telegraphing that your vehicle is slowing down (for any purpose) will lead to overconfidence or even willful misunderstanding by other drivers. A careful slow-down will turn to panic as they try to take advantage of the situation. I also think that drivers will focus on the vehicles too much, and will not focus on things like pedestrians or perhaps why your car is slowing down, and wind up contributing to the problem.
For normal people, yes. This is to prevent accidents.
This sure riled people up.
Layer 0 obfuscation error.
Perhaps a short paragraph of text elaborating on the driver's intentions
Now that's taking things too far.
But the slow down thing can actually catch drivers by surprise, especially with electric vehicles.
I just got a Chevy Volt and when I let up off the accelerator it will start the regen and significantly decrease my speed. I assume that my brake lights are coming on because so far no one has rear-ended me or yelled at me for not having brake lights. I wish there was a good way to tell for sure though. I think it's Hyundai that does not engage the brake lights for situations like this, as I've about hit one before.
I don't think they illuminate the brake lights, hence my comment. Technology connections has talked about this, although IDK which video it was.
Brake light activates before the brakes engages, so they could just be resting their foot on the brake while coasting. Pretty normal defensive driving technique. People tend to do it in heavier traffic or when people are tailgating them. Gives a way faster brake response.
