My main thoughts instantly come to someone in the opposing left turn lane, if they are not applying the brakes they are likely starting to turn and if they do it right in front of you, you have more of a heads up than just them starting to turn and can set yourself in a better position to hopefully stop in time. Driving is all about judgment calls and having more info quicker is important to those calls.
But isn't that exactly the situation we're in now? If there's a car in the opposing left turn lane, they might start to turn in front of you.
The only thing the light does is say "right now, they're braking". It doesn't say whether they're moving or stationary any more than the headlights, and it doesn't say anything about their intentions or whether it's safe to enter the intersection.
Struggled with this for a second, then I figured it out...
The brake light coming ON isn't the important part, like the rear brake lights... it's the brake lights turning OFF that's important in the front.
So maybe, now hear me out, MAYBE we need to invert that. Have front brake lights that are on ALL the time, and pressing the brake turns them off to indicate safety?
I don't understand this at all. Why do I, as a person in front of a vehicle, care whether or not it's braking?
Yeah, and then you have the distraction of people looking in the mirror because of lights behind them. Especially seeing lights behind you at night thinking it’s a police car
And never forget about the I-D ten T error.
ID10T for those who didn't get it.
First of all, this would be illegal in many countries.
Second of all: we can differentiate cars by: has red lights, back.
If we lose this option we can no longer differentiate easily if there is a car coming towards us or driving away from us.
Say you're a pedestrian and a car is coming toward you as you're entering a crosswalk. Being able to see if they are braking or not could save your life.
Isn't that the case for pretty much everything? Newer cars alternate blinking their headlights and the signal indicator, and even cars w/ the turn signal on the side will have some light bleed through since it's all one assembly. In the majority of cars, I can see their turn signals when they're perpendicular to me. The larger issue is that most people in my area don't bother to use their signals in the first place.
How would you do that so it isn't ugly as hell and isn't prone to misunderstanding?
Yea, that's part of why I don't know for sure if they make cars the way the guy at the top of this thread is describing.
Can we do this in the same bill as the popup spikes that take out your tires if you stop across the crosswalk? The guided RPGs replacing red light cams can wait a little longer.
I get what you're saying — so it's about the subconscious awareness of the state change that happens after the driver decided to go, but before the car starts moving. I can see some amount of value in that.
I still can't help but think it's going to be interpreted by many as a sign that it's safe to proceed and ignore the car rather than be prepared for any eventuality, though.
It is to colorblind people. You could use something else of course, just saying...
If a car is braking it rides differently from one that isn't. A car is normally rather level and leans "forward" when braking.
Besides that, YOU SHOULDNT GET IN FRONT OF ANYTHING YOU ARENT SURE IS STOPPING. If it's moving fast enough that you need this, you shouldn't be trying to get in front anyways.
I feel that in my area the driving culture has become so toxic that there’s a better than average chance that indicating a lane change (which I always do) will lead to the vehicle in the lane you’re attempting to change into accelerating to prevent you from ‘getting in front of them.’
It’s so frustrating (and dangerous!). It seems that a lot of folks feel entitled to the road, or the patch of road in front of their car fro as long as the eye can see, and are willing to behave irrationally regarding it.I feel that telegraphing that your vehicle is slowing down (for any purpose) will lead to overconfidence or even willful misunderstanding by other drivers. A careful slow-down will turn to panic as they try to take advantage of the situation. I also think that drivers will focus on the vehicles too much, and will not focus on things like pedestrians or perhaps why your car is slowing down, and wind up contributing to the problem.
For normal people, yes. This is to prevent accidents.
This sure riled people up.
Layer 0 obfuscation error.
The Debian project is proud to release Debian 13 "Trixie", a major update that brings new features, updated components, and numerous other improvements
Pervasive Surveillance of People is Being Used to Access, Monetise, Coerce, and Control: Computer Vision Research Feeds Surveillance Tech as Patent Links Spike 5×
