and on the opposite side don’t turn on your emergency lights while driving in bad weather. you’re only causing confusion by making it seem like you have turn signals on if i can’t see both blinkers.
The hazards also override your turn signals so I now have no idea when you are going to attempt lane change.
How would you do that so it isn’t ugly as hell
same way we do with lights now, design them attractively. It is not always successful and that's on the manufacturers.
and isn’t prone to misunderstanding?
what about it is confusing? green = not coming at you so it's okay to turn left (or whatever).
This wouldn’t really be helpful to those who are colorblind.
Personally I just want front turn signals to be visible from the opposite side again
Not sure if I read that correctly, but I don't think this has ever been the case?
And also like, used at all.
Somebody better tell traffic light designers
I'd rather see mandatory rear running lights. The amount of people who can't be arsed to turn on their lights in bad visibility conditions is too damn high.
I don't understand this at all. Why do I, as a person in front of a vehicle, care whether or not it's braking?
This will lead to people braking momentarily to slow down, and others turning in front of slowing down traffic.
Little benefit, but the cost of adding front brake lights would be passed on to the car buyers.
Couldn't we just use the point system from 5th element? The car noticed you did something illegal and dedicated from your point pool.
Would speed up crosswalks a lot too. Whenever I cross a crosswalk with my dog I don't want to risk me misjudging the braking of cars so I tend to really wait until I'm sure they're stopping.
Sounds like it can help oncoming traffic as well as traffic to either side of the vehicle
I've always heard it as "PICNIC"
Problem In Chair, Not In Computer
Oh, you think I need a new chair? Will the Internet come back then?
Thats more an issue of using the same lamp for rear lights and turn signal
My main thoughts instantly come to someone in the opposing left turn lane, if they are not applying the brakes they are likely starting to turn and if they do it right in front of you, you have more of a heads up than just them starting to turn and can set yourself in a better position to hopefully stop in time. Driving is all about judgment calls and having more info quicker is important to those calls.
I mean when a car is coming at me from a cross street, I want to be able to tell if they're turning or just an asshole not using their signal. On some cars, the turn signal is mounted so far to the side that if they're approaching from my right and turning right onto the same street as me, I can't see that turn signal. Sometimes combined with the roundness of the nose exacerbating the problem.
Risk Compension predicts that drivers would simply use this new information to drive more aggressively, negating any possible safety benefits.
i don't think that was ever required in the US. it is elsewhere though.
From Book Bans to Internet Bans: Wyoming Lets Parents Control the Whole State’s Access to The Internet
RDX for Reddit developer here: I have made OffChess a tracking free, no BS, 100K+ Offline Chess Puzzles App that you might like
People Are Being Involuntarily Committed, Jailed After Spiraling Into "ChatGPT Psychosis"
More than $35 million has been stolen from over 150 victims since December — ‘nearly every victim’ was a LastPass user
