  • Welcome to the web we lost
    180 Stimmen
    22 Beiträge
    Is it though? Its always far easier to be loud and obnoxious than do something constructive, even with the internet and LLMs, in fact those things are amplifiers which if anything make the attention imbalance even more drastic and unrepresentative of actual human behaviour. In the time it takes me to write this comment some troll can write a dozen hateful ones, or a bot can write a thousand. Doesn't mean humans are shitty in a 1000/1 ratio, just means shitty people can now be a thousand times louder.
  • 73 Stimmen
    38 Beiträge
    F
    For sure they are! Meta more then the others though
  • 103 Stimmen
    102 Beiträge
    2 Aufrufe
    Lost In Stupid Parenthesis.
  • A Presence-sensing Drive For Securely Storing Secrets
    18 Stimmen
    9 Beiträge
    D
    Isn't that arguably the nature of encryption, though? If you lose the key, you're SOL by design.
  • WhatsApp is working on video and voice calls on the web
    6 Stimmen
    10 Beiträge
    2 Aufrufe
    Worked well for me. Although all the people I care about had already Signal, Element or Threema installed, so I am not a great pull factor. And those everyday moms from child care or from wherever can reach me via SMS, for the two messages/year.
  • 297 Stimmen
    24 Beiträge
    8 Aufrufe
    This is not a typical home or office printer, very specialized.
    3 Aufrufe
    I think the principle could be applied to scan outside of the machine. It is making requests to 127.0.0.1:{port} - effectively using your computer as a "server" in a sort of reverse-SSRF attack. There's no reason it can't make requests to 10.10.10.1:{port} as well. Of course you'd need to guess the netmask of the network address range first, but this isn't that hard. In fact, if you consider that at least as far as the desktop site goes, most people will be browsing the web behind a standard consumer router left on defaults where it will be the first device in the DHCP range (e.g. 192.168.0.1 or 10.10.10.1), which tends to have a web UI on the LAN interface (port 8080, 80 or 443), then you'd only realistically need to scan a few addresses to determine the network address range. If you want to keep noise even lower, using just 192.168.0.1:80 and 192.168.1.1:80 I'd wager would cover 99% of consumer routers. From there you could assume that it's a /24 netmask and scan IPs to your heart's content. You could do top 10 most common ports type scans and go in-depth on anything you get a result on. I haven't tested this, but I don't see why it wouldn't work, when I was testing 13ft.io - a self-hosted 12ft.io paywall remover, an SSRF flaw like this absolutely let you perform any network request to any LAN address in range.
    P
    I applaud this, but I still say it's not far enough. Adjusted, the amount might match, but 121.000 is still easier to cough up for a billionaire than 50 is for a single mother of two who can barely make ends meet
