  • How the US is turning into a mass techno-surveillance state
    403 Stimmen
    57 Beiträge
    X
    Seems like a personal attack. Not a xenophobic comment when I’ve observed on social media that yankee is rarely used by a native English speaker. I stand by my opinion and all the downvotes tell me I’m onto something true.
  • There's no chance he signs it but I still hope he does
    36 Stimmen
    15 Beiträge
    2 Aufrufe
    E
    And they've been doing it more blatantly and for longer than most tech companies.
  • 133 Stimmen
    80 Beiträge
    5 Aufrufe
    glizzyguzzler@lemmy.blahaj.zoneG
    Indeed I did not, we’re at a stalemate because you and I do not believe what the other is saying! So we can’t move anywhere since it’s two walls. Buuuut Tim Apple got my back for once, just saw this now!: https://lemmy.blahaj.zone/post/27197259 I’ll leave it at that, as thanks to that white paper I win! Yay internet points!
  • 168 Stimmen
    11 Beiträge
    Law enforcement officer
  • UK government withholding details of Palantir contract
    15 Stimmen
    2 Aufrufe
    Of all the partners you could have picked. Eek.
    3 Aufrufe
    I think the principle could be applied to scan outside of the machine. It is making requests to 127.0.0.1:{port} - effectively using your computer as a "server" in a sort of reverse-SSRF attack. There's no reason it can't make requests to 10.10.10.1:{port} as well. Of course you'd need to guess the netmask of the network address range first, but this isn't that hard. In fact, if you consider that at least as far as the desktop site goes, most people will be browsing the web behind a standard consumer router left on defaults where it will be the first device in the DHCP range (e.g. 192.168.0.1 or 10.10.10.1), which tends to have a web UI on the LAN interface (port 8080, 80 or 443), then you'd only realistically need to scan a few addresses to determine the network address range. If you want to keep noise even lower, using just 192.168.0.1:80 and 192.168.1.1:80 I'd wager would cover 99% of consumer routers. From there you could assume that it's a /24 netmask and scan IPs to your heart's content. You could do top 10 most common ports type scans and go in-depth on anything you get a result on. I haven't tested this, but I don't see why it wouldn't work, when I was testing 13ft.io - a self-hosted 12ft.io paywall remover, an SSRF flaw like this absolutely let you perform any network request to any LAN address in range.
  • [paper] Evidence of a social evaluation penalty for using AI
    28 Stimmen
    10 Beiträge
    9 Aufrufe
    vendetta9076@sh.itjust.worksV
    I'm specifically talking about toil when it comes to my job as a software developer. I already know I need an if statement and a for loop all wrapped in a try catch. Rather then spending a couple minutes coding that I have cursor do it for me instantly then fill out the actual code. Or, ive written something in python and it needs to be converted to JavaScript. I can ask Claude to convert it one to one for me and test it, which comes back with either no errors or a very simple error I need to fix. It takes a minute. Instead I could have taken 15min to rewrite it myself and maybe make more mistakes that take longer.
  • *deleted by creator*
    1 Aufrufe
