Every car needs proximity chat so traffic becomes like a COD lobby.
Now there's a Black Mirror episode with true horror!
Plenty of cars flash their brake lights when ABS(/ESP?) engages, which is reasonable and should be a legal requirement IMO.
There's lots of room to give additional info in between that and "brake light is on because the driver doesn't understand that they can do mild adjustments by letting off the gas / stupid bitch-ass VW PHEV computer thinks using cruise control downhill with electric regen requires the motherfucking brake lights". It's like no-one realizes or cares that brake lights lose all purpose if they're on when the car isn't meaningfully decelerating. ARGH.
There's a programmable flasher relay that does exactly this. It's specific to certain Toyota/Lexus and Subarus from the 2000s to mid-2010s, but it's something. I have one in my 2008 Sienna - the "emergency flasher" part is programmed to strobe, kinda like a tow truck. I like it.
probably because thats a terrible way to do it. It would be noticeable if a car started braking and then started braking much harder, but if they slam on the brakes you don't see anything change, just a normal brake light.
Seems much more complicated than having the brake lights rapidly flash during hard braking. But of course we couldn't do that in the US because our turn signals/hazard lights are red
Using your vehicle lights to see and be seen
About the new vehicle lighting standard for cars in 2021 and tips on how to use your lights safely now.
Transport Canada (tc.canada.ca)
II. - Le ou les feux arrière de brouillard ne peuvent être utilisés qu'en cas de brouillard ou de chute de neige. ☞ https://www.legifrance.gouv.fr/codes/article_lc/LEGIARTI000006842263
Feux de brouillard arrière : ils sont indiqués uniquement en cas de brouillard ou de chute de neige (mais jamais sous la pluie en raison de leur trop grande intensité) ☞ https://public.codesrousseau.fr/conseils-pratiques/909-feux-de-brouillard-avant-et-arriere-quand-les-utiliser.html
Ça c'est de l'osti de merde comme on dit ici.
Turn signals can be either red or amber in the US.
yeah, but they shouldn't be allowed to be red to begin with.
Not selling tanks as cars could also help. Especially with fatality rates
People don't even need car tbh. Motorbikes everywhere please. Zip zip, less traffic, everyone pays attention to road or falls and dies.
90% of the things that Japan introduced according to comment sections on the internet never happened (or never made it past the prototype stage) and the rest was actually introduced in Korea, not in Japan.
The Japanophilia is strong with a lot of people on the internet.
Yeah I mean I've been commuting 2 hrs a day in Japan for almost 10 years now-- you'd think I would've seen these brake lights by now
You are looking for war
If a car is braking it rides differently from one that isn't. A car is normally rather level and leans "forward" when braking.
Besides that, YOU SHOULDNT GET IN FRONT OF ANYTHING YOU ARENT SURE IS STOPPING. If it's moving fast enough that you need this, you shouldn't be trying to get in front anyways.
This, exactly. This "plan" sounds terrible to me.
No, I'm not braking to turn at the intersection you're sitting in. I'm turning into a driveway just past that intersection. If you pull in front of the green light the government says I have to have on my vehicle, I'm going to t-bone you.
Say you're a pedestrian and a car is coming toward you as you're entering a crosswalk. Being able to see if they are braking or not could save your life.
Ah. I see. They are emitting a green light, so I know they're braking, and it's OK to cross.
But, it turns out that they're planning on turning into a driveway past the intersection, and not into the intersection I am crossing.
That's OK. I can check "impersonate a hood ornament" off my bucket list.
We already have this problem with turn signals: there are circumstances where it would be confusing and dangerous to use them in the manner prescribed by law, and to avoid dangerous ambiguity, they should actually be used much later than the law specifies.
CB radios often had a "PA" switch that sent your microphone audio to a loudspeaker under the hood.
I'd prefer a "FlameThrower" button next to the horn.
Road rage 5000 initiate
Good luck transporting a couch on a motorbike.
I get what you're saying — so it's about the subconscious awareness of the state change that happens after the driver decided to go, but before the car starts moving. I can see some amount of value in that.
I still can't help but think it's going to be interpreted by many as a sign that it's safe to proceed and ignore the car rather than be prepared for any eventuality, though.
I agree that that would be a real danger, yes.
Rent a truck for cheap
That's why I bought mine!
Deep in Mordor where the shadows lie: Dystopian tales of that time when I sold out to Google – elilla & friends’ very occasional blog thing
In North Korea, your phone secretly takes screenshots every 5 minutes for government surveillance
A fake Facebook event disguised as a math problem has been one of its top posts for 6 months
