  • Building a slow web
    160 Stimmen
    33 Beiträge
    I
    Hi, The internal port will also be the same as the external port 80 and 443. If the router is running in bridge mode, that would mean that your dhcp, dns and nat is happening on the upstream router. That means you will have to go to the upstream router to setup the port forwarding. Also depending on how it works internally with the VPN. It might try to port forward the ports on the VPN's ip address Which none of the VPN I tried allowed to port forward port 80 and 443 With a linux or openwrt router this could be as easy as the following iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j DNAT --to-destination 192.168.1.199:80 iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 443 -j DNAT --to-destination 192.168.1.199:443 But the problem with store bought router is that every one of them has a different way of doing the things so it gets confusing really fast. All of this confusion about port forwarding was engineered to discourage ordinary people from using their internet to host their own files and instead because cloud-dependant techno-serfs. Another way, would be to go on the forum low end talk and obtain a VPS, and host your apache server there. That would work, but you would be back to renting someone else's computer (aka cloud bull) but it's still better than paying squarespace about it. Keep at it, you'll figure it out, it's actually very easy once you know all the complicated bits, I do it all the time.
  • Pimax: one more brand exposed for promoting "positive reviews".
    55 Stimmen
    3 Aufrufe
    moose@moose.bestM
    This doesn't really surprise me, I've gotten weird vibes from Pimax for years. Not so much to do with their hardware, but how their sales / promo team operates. A while back at my old workplace we randomly got contacted by Pimax trying to have us carry their headset, which was weird since we didn't sell VR stuff or computers even, just other electronics. It was a very out of place request which we basically said we wouldn't consider it until we can verify the quality of the headset, after which they never replied.
  • 154 Stimmen
    137 Beiträge
    4 Aufrufe
    brewchin@lemmy.worldB
    If you're after text, there are a number of options. If you're after group voice, there are a number of options. You could mix and match both, but "where everyone else is" will also likely be a factor in that kind of decision. If you want both together, then there's probably just Element (Matrix + voice)? Not sure of other options that aren't centralised, where you're the product, or otherwise at obvious risk of enshittifying. (And Element has the smell of the latter to me, but that's another topic). I've prepared for Discord's inevitable "final straw" moment by setting up a Matrix room and maintaining a self-hosted Mumble server in Docker for my gaming buddies. It's worked when Discord has been down, so I know it works. Yet to convince them to test Element...
  • 17 Stimmen
  • Moon missions: How to avoid a puncture on the Moon
    14 Stimmen
    2 Aufrufe
    2 Aufrufe
    V
    Just downloaded it, thanks for the info!
  • How I use Mastodon in 2025 - fredrocha.net
    11 Beiträge
    2 Aufrufe
    J
    Sure. Efficiency isn't everything, though. At the end of the article there are a few people to get you started. Then you can go to your favorites in that list, and follow some of the people THEY are following. Rinse and repeat, follow boosted folks. You'll have 100 souls in no time.
