finally some good news for us Samsung victims/owners.
Jobs figured everything out a long time ago. Why are you desecrating his memory?
What are you talking about? The article doesn't mention him.
Figured what out?
[🇨🇭Switzerland] Google, X/Twitter and Other Online Services are Set to Pay Copyright Fees for Displaying Short Extracts From Newspaper Articles.
Deep in Mordor where the shadows lie: Dystopian tales of that time when I sold out to Google – elilla & friends’ very occasional blog thing
Trump says a 25% tariff "must be paid by Apple" on iPhones not made in the US, says he told Tim Cook long ago that iPhones sold in the US must be made in the US
Duolingo CEO says AI is a better teacher than humans—but schools will exist ‘because you still need childcare’
