Fair. There is Molly on fdroid if you like.
Molly is great.
That's a risk, and a reason I'd like to see something federated succeed in this space. Unfortunately neither Matrix nor XMPP has managed to achieve quite the level of UX necessary for mainstream adoption, nor have the average person's tech skills and comfort level improved.
Signal's status as a well-funded nonprofit gives me hope that the current situation is reasonably stable.
Be careful with that ol' Chestnut. Circumstances may dictate perfection, where less than such may be catastrophic.
In that case it wouldn't be "good enough". But I don't think this is such an all-or-nothing situation.
You can use Molly from F-Droid. They even have a full FOSS version that you can set up a self hosted notification socket for, to avoid Google Firebase.
It may not be the holy grail, but moving away from Meta-owned Whatsapp is already a pretty significant improvementI agree and it would be much better if people would use Signal instead of WhatsApp, but I think there's still one problem.
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again. -
Signal is very actively and directly working to pioneer a new financial model for long term software business stability that does not rely on surveillance capitalism. Your experience with young companies enshittifying into monsters is the natural cycle for the surveillance economy, and if Signal does eventually go that way it will be a profound disappointment, but I expect the foundation would rather die first. Check out this interview from last year with the president of the Signal Foundation for more depth on that.
Like Matrix.
I don't know, the GrapheneOS folks say that F-Droid is a potential security catastrophe.
You can find Molly from Accrescent (and apparently also from F-Droid if you must use that), which is not so much a security catastrophe.
That blog post was my reason to double down on Matrix.
It may not be the holy grail, but moving away from Meta-owned Whatsapp is already a pretty significant improvementWhy not Signal?
A few essays on communism
essays (dessalines.github.io)
telegram much better
This makes switching very hard even for a nerd like me, because if Signal is not "perfect" it means that I will have to switch again at some point and lose everything again.I've been using Signal for years and my database was getting really bloated with media, attachments, etc but I didn't want to delete it all. I used this and it's incredible:
GitHub - bepaald/signalbackup-tools: Tool to work with Signal Backup files.
Tool to work with Signal Backup files. Contribute to bepaald/signalbackup-tools development by creating an account on GitHub.
GitHub (github.com)
Just make a backup from within signal, copy that backup file to your PC, then run this tool. The commands I used make an HTML webpage that looks just like the signal messenger, along with a way of searching your messages. You can choose different commands to export however you like.
I used:
signalbackup-tools [input] [passphrase] --exporthtml [directory] --split --searchpage --originalfilenames
So while this doesn't help you move off your current messenger, you don't have to worry that your data/messages will be lost in Signal.
Basically Signal but without the weakness of a phone number & runs on a Tor-like network. It's still a work-in-progress thing but you CAN use it to send messages
Nah, that would be Matrix, XMPP, DeltaChat or SimpleX
Ya it’d be better if it didn’t require a phone number but it’s a solid start as it’s build up a user base over the past decade. Matrix is good but I know far less people that use it and it’ll be a long time of growing with nerdy/geeky communities before it starts getting more mainstream users
Have a look here: https://www.messenger-matrix.de/messenger-matrix-en.html
I like the comparison and prefer simplex as an replacement to Signal in the Future.
Self hosted Matrix Servers are a good idea aswell if you have the money and knowledge.
This chair in the form of a Rubik's cube will allow you to sit, only if you solve a puzzle
China New Internet ID System a Threat to Online Expression: Netizens will require IDs to go on the internet. For now this is voluntary, but there are signs it will not remain that way for long.
Bill Atkinson, visionary engineer behind the Apple Macintosh operating system, dies at 74
“Treat Online Abuse Like Spam”: New Report Urges Social Media Platforms to Fight Online Abuse with Tools Users Can Control
