235 140 5.3k
    There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Telegram, I think, Atleast in my country is the second most popular thing behind WhatsApp but in it's default state, it's less secure and one needs to enable e2e encryption(read : secret chats).
    I am willing to move to almost any service ( I mean, I still use IRC, so..) but the main point is would anyone I know be on them? I once gave Signal a try but quickly wound uninstalling it because there was no one I knew there.
    I dislike WhatsApp as well (it's desktop variant is so slow and takes such a long time to sync messages plus Telegram has better inline support for images for example compared to Meta's version). It doesn't help that it's status page also promotes useless channels and that it is a hub of misinformation.
    After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    It's still an American company, so it's not ideal. But it's still significantly better better than letting a tech giant like Facebook have control over the most commonly used chat app.
    WhatsApp needs to go and Signal is the most likely way in which we can achieve that. We can worry about the American elephant in the room later.
    It's ethical because it runs on donations and has a non-profit business model.
    Meta likely spends at least $1 billion a year running WhatsApp.
    Please donate to Signal if you use it.
  • There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Signal used to be the best answer to this conundrum, since it would use its own internal protocols if it could or fall back to SMS if it couldn't, unfortunately they decided to drop SMS support a few years ago, citing users that sent sensitive information not realizing they were using SMS (that always felt kinda flimsy). I really disliked this change, because it raised the difficulty of adoption, from just getting people to replace their default app with Signal to making them manage multiple apps.
    Now though, you basically need to advocate socially for the change you want to see in the world. Anecdotally, I started using Signal when they still supported SMS to talk with 1 friend group, and eventually convinced most of my closest family groups to also use it, many after SMS support was dropped. Apart from 1 tech illiterate elderly couple and 1 extended family member, I haven't received any personal (non-company related) text messages in like 5 months.
  • Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    The problem is that it was easier to get people to move to Telegram since it had an abundance of features compared to WhatsApp which was compelling for the average person that doesn't care about encryption. Signal doesn't have any of these features that make it enticing for the person.
  • After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    Sadly many still don't want to switch. My most active chats are in signal now but the large majority of chats are still on whatsapp
    For now anyways lol
  • If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Quickly as in I had it for multiple months. Just like I did with Threema and Briar and XMPP apps and what not. Nobody ever showed up. There was a time when I was carrying more chat apps than folks I used to chat with
    There is technically one phonebook contact of mine on Signal but he primarily uses Telegram as primary chat thingy.
    It then occurred to me that IRL most folks don't care about chat apps. They care about chatting. The most I have seen folks are on Whatsapp, Telegram and Snapchat (last of which is really bad).
    Edit: there was/is Session as well. It started as a fork of Signal before moving to its own standard. It doesn't require even a phone number for verification. I think I once installed it for talking to a random stranger on the internet.
    There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    Unfortunately the source code is not open (even though they do get annual audits with public reports), and the client costs 3 EUR or something (once).
  • There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    They also offer Threema Libre on F-Droid for all us folks who degoogled their phone
    How about matrix?
    Yeah, but Threema has basically no momentum behind it at all at this point.
    I'm putting my social capital behind the option that currently stands the most chance of beating out Whatsapp
  • For now anyways lol
    What does this mean
  • How about matrix?
  • Yeah, but Threema has basically no momentum behind it at all at this point.
    Threema has a pretty big momentum in some countries.
    A few friends of mine use Threema, because they care about privacy and are more than happy to pay to have it. Signal comes third, behind Telegram, even.
    And Switzerlands records in terms of privacy sadly is far worse than most people think - even with the last attack being repelled.
    Matrix (preferably on a non-matrix.org instance) currently is the preferable non US and privacy friendly way.
  • 16 Stimmen
    12 Beiträge
    lime@feddit.nuL
    you should probably also check out beaker browser then, it's also trying to blur the line. personally i don't know if there is an actual benefit. most people seem content not producing things in fields they're not interested in. we'll never be able to get everyone on board with making websites no matter how simple the interface, just like we'll never be able to get everyone on board with gardening or carpentry. if you want to do it, you will learn. if you don't the learning curve is not the problem.
  • 136 Stimmen
    W
    Such interesting videos on such nostalgic pieces of technology too. I could listen to him ramble about this stuff all day (and I have).
  • China is rushing to develop its AI-powered censorship system
    39 Stimmen
    33 Aufrufe
    why0y@lemmy.mlW
    This concept is the enemy of the a centuries old idealistic societal pillar of the West: Liberté, Libertas... this has blessed so many of us in the West, and I beg that it doesn't leave. Something beautiful and as sacred as the freedom from forced labor and the freedom to choose your trade, is the concept of the free and unbounded innocence of voices asking their leaders and each other these questions, to determine amongst ourselves what is fair and not, for our own betterment and the beauty of free enterprise. It's not so much that the Chinese state is an awful power to behold (it is and fuck Poohhead)... but this same politic is on the rise in the West and it leads to war. It always leads to war. And now the most automated form of state and corporate propaganda the world has ever seen is in the hands of a ruthless ruling class that can, has, and will steal bread from children's hands, and literally take the medicine from the sick to pad their pockets. Such is the twisted fate of society and likely always will be. We need to fight and not with prayers; this moment is God forsaking us to behold how the spirit breaks and what the people want to fight for as ruthlessly as the others do to steal our bread.
  • You're not alone: This email from Google's Gemini team is concerning
    837 Stimmen
    298 Beiträge
    4k Aufrufe
    My understanding is that, in broad strokes... Aurora acts like a proxy or mirror that doesn't require you to sign in to get Google Play Store apps. It doesn't provide any other software besides what you specifically download from it, and it doesn't include any telemetry/tracking like normal Google Play Store would. microG is a reimplementation of Google Play services (the suite of proprietary background services that Google runs on normal Android phones). MicroG doesn't have the bloat and tracking and other closed source functionality, but rather acts as a stand-in that other apps can talk to (when they'd normally be talking to Google Play services). This has to be installed and configured and I would refer to the microG github or other documentation. GrapheneOS has its own sandboxed Google Play Services which is basically unmodified Google Play Services, crammed into its own sandbox with no special permissions, and a compatibility layer that retains some functionality while keeping it from being able to access app data with high level permissions like it would normally do on a vanilla Android phone.
  • Building a slow web
    175 Stimmen
    37 Beiträge
    509 Aufrufe
    I
    Realistically, you don't need security, NAT alone is enough since the packets have nowhere to go without port forwarding. But IF you really want to build front end security here is my plan. ISP bridge -> WAN port of openwrt capable router with DSA supported switch (that is almost all of them) Set all ports of the switch to VLAN mirroring mode bridge WAN and LAN sides Fail2Ban IP block list in the bridge LAN PORT 1 toward -> OpenWRT running inside Proxmox LXC (NAT lives here) -> top of rack switch LAN PORT 2 toward -> Snort IDS LAN PORT 3 toward -> combined honeypot and traffic analyzer Port 2&3 detect malicious internet hosts and add them to the block list (and then multiple other openwrt LXCs running many many VPN ports as alternative gateways, I switch LAN host's internet address by changing their default gateway) I run no internal VLAN, all one LAN because convenience is more important than security in my case.
  • 79 Stimmen
    14 Beiträge
    120 Aufrufe
    B
    Didn’t he pay a hitman to murder a couple of people?
  • 471 Stimmen
    99 Beiträge
    J
    Copyright law is messy. Thank you for the elaboration.
  • Uploading The Human Mind Could Become a Reality, Expert Says
    6 Stimmen
    12 Beiträge
    118 Aufrufe
    r3d4ct3d@midwest.socialR
    what mustard is best for the human body?
