A fake Facebook event disguised as a math problem has been one of its top posts for 6 months
  • For me it's the arguments when there is a parentheses but no operator (otherwise known as implied multiplication) in these baits e.g. 15 + 2(4 - 2)
    If you don't know operator orders I have given up long ago, but I have seen a few lengthy discussions about this
    For me it’s the arguments when there is a parentheses but no operator (otherwise known as implied multiplication)
    No, it's known as Factorised Terms/Products, solved via The Distributive Law, a(b+c)=(ab+ac). "implied multiplication" is a made up rule by people who have forgotten the actual rules, and often they get it wrong (because, having wrongly called it "multiplication", they then wrongly give it the precedence of multiplication, not brackets).
  • Oh yeah, that's a fun one.
    Where I live, this would be considered juxtaposition, at least by uni professors and scientific community, so 2(4-2) isn't the same as 2×(4-2), even though on their own they're equal.
    This way, equations such as 15/2(4-2) end up with a definite solution.
    So,
    15/2(4-2) = 3.75
    While
    15/2×(4-2) = 15
    Usually, however, it is obvious even without assuming juxtaposition because you can look at previous operations. Not to mention that it's most common with variables (Eg. "2x/3y").
    Not just where you live, everywhere, in Maths textbooks. Adults forgetting the rules (and unqualified U.S. teachers not teaching what's in the textbooks) is another matter altogether.
  • I never understood how people couldn’t understand basic PEMDAS/BEDMAS/Whatever-the-fuck-your-country-calls-it.
    There's no "whatever-the-fuck-your-country-calls-it", the US is the only country using it, and only up to high school. At least I'm not seeing any papers coming out of the US relying on it so at some point they're dropping it and do what everyone else is doing: Write equations such that you don't need a left-to-right rule to disambiguate things. Also, using multiplication by juxtaposition (2x + 4x^2^).
    There’s no “whatever-the-fuck-your-country-calls-it”
    Yes there is. BEDMAS, BODMAS, and BIDMAS
    No they're not.
    at some point they’re dropping it
    No, at no point do the order of operations rules ever get dropped
    using multiplication by juxtaposition (2x + 4x2)
    They're called Terms/Products.
  • "Hey, this is Presh Talwalkar.
    Discussion of a brief history of this viral math problem, followed by explanations of common incorrect answers. Ultimately followed by brief discussion on the order of operations, concluding in a final example that equals 11
    And that's the answer. Thank you so much for making us one of the best communities on YouTube, where we solve the world's problems, one video at a time."
    Person who has forgotten about The Distributive Law and lied about 1917.
    Including lying about 1917
    But forgets about Terms and The Distributive Law.
    And that’s the answer
    Now watch his other ones, where he screws it up royally. Dude has no idea how to handle brackets. Should be avoided at all costs.
  • So order of operations is hard?
    Not for students it isn't. Adults who've forgotten the rules on the other hand...
  • The issue normally with these "trick" questions is the ambiguous nature of that division sign (not so much a problem here) or people not knowing to just go left to right when all operators are of the same priority. A common mistake is to think division is prioritised above multiplication, when it actually has the same priority. Someone should have included some parenthesis in PEDMAS aka. PE(DM)(AS) 😄
    The issue normally with these “trick” questions
    There's no "trick" - it's a straight-out test of Maths knowledge.
    Nothing ambiguous about it. The Term of the left divided by the Term on the right.
    It's not a mistake. You can do them in any order you want.
    Which means you can do them in any order
  • So let's try out some different prioritization systems.
    Left to right:
    (((6 * 4) / 2) * 3) / 9
    ((24 / 2) * 3) / 9
    (12 * 3) / 9
    36 / 9 = 4
    Right to left:
    6 * (4 / (2 * (3 / 9)))
    6 * (4 / (2 * 0.333...))
    6 * (4 / 0.666...)
    6 * 6 = 36
    Multiplication first:
    (6 * 4) / (2 * 3) / 9
    24 / 6 / 9
    Here the path divides again, we can do the left division or right division first.
    Left first:
    (24 / 6) / 9
    4 / 9 = 0.444...
    Right side first:
    24 / (6 / 9)
    24 / 0.666... = 36
    And finally division first:
    6 * (4 / 2) * (3 / 9)
    6 * 2 * 0.333...
    12 * 0.333.. = 4
    It's ambiguous which one of these is correct. Hence the best method we have for "correct" is left to right.
    Right to left:
    Nope! 6 × 4 ÷ 2 × 3 ÷ 9 =4 right to left is 6 ÷ 9 x 3 ÷ 2 × 4 =4. You disobeyed the rule of Left Associativity, and your answer is wrong
    Multiplication first: (6 * 4) / (2 * 3) / 9
    Also nope. Multiplication first is 6 x 4 x 3 ÷ 2 ÷ 9 =4
    Left first: (24 / 6) / 9
    Still nope. 6 × 4 x 3 ÷ 2 ÷ 9 =4
    Right side first: 24 / (6 / 9)
    Still nope. 6 × 4 x 3 ÷ 9 ÷ 2 =4
    And finally division first: 6 * (4 / 2) * (3 / 9)
    And finally still nope. 6 ÷ 9 ÷ 2 x 4 x 3 =4
    Hint: note that I never once added any brackets. You did, hence your multiple wrong answers.
    It’s ambiguous which one of these is correct
    No it isn't. Only 4 is correct, as I have just shown repeatedly.
    Hence the best method we have for “correct” is left to right
    It's because students don't make mistakes with signs if you don't change the order. I just showed you can still get the correct answer with different orders, but you have to make sure you obey Left Associativity at every step.
  • I stand corrected
    I stand corrected
    No, you weren't. Most of their answers were wrong. You were right. See my reply. 4 is the only correct answer, and if you don't get 4 then you did something wrong, as they did repeatedly (kept adding brackets and thus changing the Associativity).
  • Maybe I'm wrong but the way I explain it is until the ambiguity is removed by adding in extra information to make it more specific then all those answers are correct.
    "I saw her duck"
    Until the author gives me clarity then that sentence has multiple meanings. With math, it doesn't click for people that the equation is incomplete. In an English sentence, ambiguity makes more sense and the common sense approach would be to clarify what the meaning is
    There isn't any ambiguity.
    No, only 1 answer is correct, and all the others are wrong.
    Maths isn't English and doesn't have multiple meanings. It has rules. Obey the rules and you always get the right answer.
    it doesn’t click for people that the equation is incomplete.
    It isn't incomplete.
  • 100% with you. "Left to right" as far as I can tell only exists to make otherwise "unsolvable" problems a kind of official solution. I personally feel like it is a bodge, and I would rather the correct solution for such a problem to be undefined.
    100% with you. “Left to right” as far as I can tell only exists to make otherwise “unsolvable” problems a kind of official solution
    It's not a rule, it's a convention, and it exists so as to avoid making mistakes with signs, mistakes you made in almost every example you gave where you disobeyed left to right.
  • It's so we don't have to spam brackets everywhere
    9+2-1+6-4+7-3+5=
    Becomes
    ((((((9+2)-1)+6)-4)+7)-3)+5=
    That's just clutter for no good reason when we can just say if it doesn't have parentheses it's left to right. Having a default evaluation order makes sense and means we only need parentheses when we want to deviate from the norm.
    It’s so we don’t have to spam brackets everywhere
    No it isn't. The order of operations rules were around for several centuries before we even started using Brackets in Maths.
    It was literally never written like that
    That has always been the case
  • It’s ambiguous which one of these is correct. Hence the best method we have for “correct” is left to right.
    The solution accepted anywhere but in the US school system range from "Bloody use parenthesis, then" over "Why is there more than one division in this formula why didn't you re-arrange everything to be less confusing" to "50 Hertz, in base units, are 50s^-1^".
    More practically speaking: Ultimately, you'll want to do algebra with these things. If you rely on "left to right" type of precedence rules re-arranging formulas becomes way harder because now you have to contend with that kind of implicit constraint. It makes everything harder for no reason whatsoever so no actual mathematician, or other people using maths in earnest, use that kind of notation.
    The solution accepted anywhere but in the US school system range from “Bloody use parenthesis, then” over “Why is there more than one division in this formula why didn’t you re-arrange everything to be less confusing” to “50 Hertz, in base units, are 50s-1”.
    No, the solution is learn the rules of Maths. You can find them in Maths textbooks, even in U.S. Maths textbooks.
    Yes we do, and it's what we teach students to do.
  • Another person already replied using your equation, but I felt the need to reply with a simpler one as well that shows it:
    9-1+3=?
    Subtraction first:
    8+3=11
    Addition first:
    9-4=5
    Addition first:
    9-4=5
    Nope. Addition first is 9+3-1=12-1=11. You did 9-(1+3), incorrectly adding brackets and changing the answer (thus a wrong answer)
  • Except it does matter. I left some examples for another post with multiplication and division, I'll give you some addition and subtraction to see order matter with those operations as well.
    Let's take:
    1 + 2 - 3 + 4
    Addition first:
    (1 + 2) - (3 + 4)
    3 - 7 = -4
    Subtraction first:
    1 + (2 - 3) + 4
    1 + (-1) + 4 = 4
    Right to left:
    1 + (2 - (3 + 4))
    1 + (2 - 7)
    1 + (-5) = -4
    Left to right:
    ((1 + 2) - 3) + 4
    (3 - 3) + 4 = 4
    Edit:
    You can argue that, for example, the addition first could be (1 + 2) + (-3 + 4) in which case it does end up as 4, but in my opinion that's another ambiguous case.
    No it doesn't. You disobeying the rules and getting lots of wrong answers in your examples doesn't change that.
    Which you did wrong.
    I’ll give you some addition and subtraction to see order matter with those operations as well
    And I'll show you it doesn't matter when you do it correctly
    Subtraction first:
    1 + (2 - 3) + 4
    1 + (-1) + 4 = 4
    Nope. Right answer for wrong reason - you only co-incidentally got the answer right. -3+1+2+4=-3+7=4
    Right to left:
    1 + (2 - (3 + 4))
    1 + (2 - 7)
    1 + (-5) = -4
    Nope. 4-3+2+1=1+2+1=3+1=4
    Edit: You can argue that, for example, the addition first could be (1 + 2) + (-3 + 4)
    Or you could just do it correctly in the first place, always obeying Left Associativity and never adding Brackets
    in my opinion that’s another ambiguous case
    There aren't ANY ambiguous cases. In every case it's equal to 4. If you didn't get 4, then you made a mistake and got a wrong answer.
  • Oh, but of course the statement changes if you add parentheses. Basically, you’re changing the effective numbers that are being used, because the parentheses act as containers with a given value (you even showed the effective numbers in your examples).
    Get this : + 1 - 1 + 1 - 1 + 1 - 1 + 1
    You can change the result several times by choosing where you want to put the parentheses. However, the order of operations of same priority inside a container (parentheses) does not change the resulting value of the container.
    In the example, there were no parentheses, so no ambiguity (there wouldn’t be any ambiguity with parentheses either, the correct way of calculating would just change), and I don’t think you can add “ambiguity” by adding parentheses — you’re just changing the effective expression to be evaluated.
    By the way, this is the reason why I absolutely overuse parentheses in my engineering code. It can be redundant, but at least I am SURE that it is going to follow the order that I wanted.
    It sure does, but they don't seem to understand that.
  • Another common issue is thinking "parentheses go first" and then beginning by solving the operation beside them (mostly multiplication). The point being that what's inside the parentheses goes first, not what's beside them.
    Another common issue is thinking “parentheses go first”
    There's no "think" - it's an absolute rule.
    a(b) isn't an operation - it's a Product. a(b)=(axb) per The Distributive Law.
    NOT Multiplication, a Product/Term.
    The point being that what’s inside the parentheses goes first, not what’s beside them
    Nope, it's the WHOLE Bracketed Term. a/bxc=ac/b, but a/b( c )=a/(bxc). Inside is only a "rule" in Elementary School, when there isn't ANYTHING next to them (students aren't taught this until High School, in Algebra), and it's not even really a rule then, it's just that there isn't anything ELSE involved in the Brackets step than what is inside (since they're never given anything on the outside).
  • ÷ could be a minus sign
    No it couldn't.
    Did you check the reference? It says % can be used as a minus sign, not the obelus. Welcome to what happens when you're next-door neighbour Joe Blow can edit Wikipedia.
  • Yes, it is. The division of a by b in the set of real numbers and the set of rational numbers (which are, de facto, the default sets used in most professions) is defined as the multiplication of a by the multiplicative inverse of b. Alternative definitions are also based on a multiplication.
    That's why divisions are called an auxilliary operation.
    Yes, it is
    No it isn't.
    No it isn't. The Quotient is defined as the number obtained when you divide the Dividend by the Divisor. Here it is straight out of Euler...
    Emphasis on "alternative", not actual.
  • Hey, this is Presh Talwalkar
    I've seen many of his videos and haven't noticed any obvious errors. Could you please link to the specific video(s) that you are referencing in regards to errors he has made, especially those related to the distributive law and what you reference to as "1917," as well as any explanation as to what is incorrect/misleading/lying?
  • Yes, it is
    No it isn't.
    No it isn't.
    Yes, it is.
    I'm defining the division operation, not the quotient. Yes, the quotient is obtained by dividing... Now define dividing.
    The actual is the one I gave. I did not give the alternative definitions. That's why I said they are also defined based on a multiplication, implying the non-alternative one (understand, the actual one) was the one I gave.
    Feel free to send your entire Euler document rather than screenshotting the one part you thought makes you right.
    Note, by the way, that Euler isn't the only mathematician who contributed to the modern definitions in algebra and arithmetics.
