JD Vance gets suspended from Bluesky 'just 12 minutes after first post': reports
  • Here’s What Mark Zuckerberg Is Offering Top AI Talent
    11 Stimmen
    26 Aufrufe
    K
    Is it virtual legs or can't figure those out still?
    10 Aufrufe
  • Whatever happened to cheap eReaders? – Terence Eden’s Blog
    126 Stimmen
    72 Beiträge
    231 Aufrufe
    This is a weirdly aggressive take without considering variables. Almost petulant seeming. 6” readers are relatively cheap no matter the brand, but cost goes up with size. $250 to $300 is what a 7.8” or 8” reader costs, but there’s not a single one I know of at 6” at that price. There’s 10” and 13” models. Are you saying they should cost the same as a Kindle? Not to mention, regarding Kindle, Amazon spent years building the brand but selling either at cost or possibly even taking a loss on the devices as they make money on the book sales. Companies who can’t do that tend to charge more. Lastly, it’s not “feature creep” to improve the devices over time, many changes are quality of life. Larger displays for those that want them. Frontlit displays, and later the addition of warm lighting. Displays essentially doubled their resolution allowing for crisper fonts and custom fonts to render well. Higher contrast displays with darker blacks for text. More recently color displays as an option. This is all progress, but it’s not free. Also, inflation is a thing and generally happens at a rate of 2% to 3% annually or thereabouts during “normal” times, and we’ve hardly been living in normal times over the last decade and a half.
  • 278 Stimmen
    100 Beiträge
    290 Aufrufe
    F
    It's not just skills, it's also capital investment.
  • 87 Stimmen
    10 Beiträge
    44 Aufrufe
    If you want to stay on the bleeding edge you've got to be a reversal of Europe, which means allowing innovation and competition. Hence why VT is nearly 70% US.
  • 360 Stimmen
    24 Beiträge
    94 Aufrufe
    F
    If only they didn’t fake it to get their desired result, then maybe it could have been useful. I agree that LiDAR and other technologies should be used in conjunction with regular cameras. I don’t know why anyone would be against that unless they have vested interests. For various reasons though I understand that it isn’t always possible - price being a big one.
  • Apple Watch Shipments’ Continuous Decline
    22 Stimmen
    10 Beiträge
    43 Aufrufe
    i mean as a core feature of a watch/smartwatch in general. garmin is going above and beyond compared to the competition in that area, and that's great. But that doesn't mean every other smartwatch manufacturer arbitrarily locking traditional watch features behind paywalls. and yeah apple does fitness themed commercials for apple watch because it does help with fitness a ton out of the box. just not specifically guided workouts.
    26 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
