Right to Repair Gains Traction as John Deere Faces Trial
  • AMD warns of new Meltdown, Spectre-like bugs affecting CPUs
    190 Stimmen
    9 Beiträge
    anyoldname3@lemmy.worldA
    This isn't really the same kind of bug. Those bugs made instructions emit the wrong answer, which is obviously really bad, and they're really rare. The bugs in the article make instructions take different amounts of time depending on what else the CPU has done recently, which isn't something anyone would notice except that by asking the kernel to do something and measuring the time to execute affected instructions, an attacker that only had usermode access could learn secrets that should only be available to the kernel.
  • 148 Stimmen
    8 Aufrufe
    czardestructo@lemmy.worldC
    Likely. The coils only job is to ignite the lamp by whacking it with high voltage to strip some barium elections off the coil to induce plasma and therefore electrical flow. The plasma then excites the phosphorus to make light. After that the coils could just be stubs of wire so long as current keeps flowing through the excited plasma. If you did it inductively it would achieve the same means but I don't think the plasma would be as dense so the lamp not as bright. My theory anyways.
  • First Tesla Robotaxi Ride
    37 Stimmen
    14 Beiträge
    57 Aufrufe
    How do you heil a Tesla cab?....you don't. Unless you want to end up rotting in a concentration camp in El Salvador. Fuck face is exactly the type who would rape you in the morning and then walk outside the room into the balcony and shoot an innocent bystander for no reason. See "Schindler's list". So you don't.
  • 75 Stimmen
    3 Aufrufe
  • Firefox is dead to me – and I'm not the only one who is fed up
    45 Stimmen
    55 Beiträge
    168 Aufrufe
    F
    Never had issue with Firefox in my day to day use, sites load fine, uBlock stops all the annoyances and thankfully youtube works well for me.
  • Is Matrix cooked?
    100 Stimmen
    54 Beiträge
    177 Aufrufe
    W
    Didn't know it only applied to UWP apps on Windows. That does seem like a pretty big problem then. it is mostly for compatibility reasons. no win32 programs are equipped to handle such granular permissions and sandboxing, they are all made with the assumption that they have access to whatever they need (other than other users' resources and things that require elevation). if Microsoft would have made that limitation to every kind of software, that Windows version would have probably been a failure in popularity because lots of software would have broken. I think S editions of windows is how they tried to go in that direction, with a more drastic way of simply just dropping support for 3rd party win32 programs. I don't still have a Mac readily available to test with but afaik it is any application that uses Apple's packaging format. ok, so if you run linux or windows utils in a compatibility layer, they still have less of a limited access? by which I mean graphical utilities. just tried with firefox, for macos it wanted to give me an .iso file (???) if so, it seems apple is doing roughly the same as microsoft with uwp and the appx format, and linux with flatpak: it's a choice for the user
  • Ai Code Commits
    164 Stimmen
    37 Beiträge
    144 Aufrufe
    From what I know, those agents can be absolutely fantastic as long as they run under strict guidance of a senior developer who really knows how to use them. Fully autonomous agents sound like a terrible idea.
  • 133 Stimmen
    80 Beiträge
    266 Aufrufe
    glizzyguzzler@lemmy.blahaj.zoneG
    Indeed I did not, we’re at a stalemate because you and I do not believe what the other is saying! So we can’t move anywhere since it’s two walls. Buuuut Tim Apple got my back for once, just saw this now!: https://lemmy.blahaj.zone/post/27197259 I’ll leave it at that, as thanks to that white paper I win! Yay internet points!
