How push notification works?
hello,
I can't quite figure out how push notifications work since I can't see/activate them even here at community.nodebb.org.I am using NodeBB 4.4.4.
I see that in the settings there is and active "Push Notifications (via Push API) but nowhere and nowhere do I ever get a suggestion to enable browser notifications.
Is there something I don't understand that needs to be enabled that I don't see or do they work differently than I imagine?
Thanks!
S support@community.nodebb.org shared this topic
ska there should be a user setting page for push notifications, and they are activated on a per-device level.
Does the toggle activate for you?
julian thanks for the answer.
I see in F12 console this error:
service-worker.js:31 Uncaught NetworkError: Failed to execute 'importScripts' on 'WorkerGlobalScope': The script at 'https://citiverse.it/assets/plugins/nodebb-plugin-web-push/static/web-push.js' failed to load. at service-worker.js:31:1 (anonymous) @ service-worker.js:31 An unknown error occurred when fetching the script.
But the web-push plugin is active and I even tried uninstalling -> deleting it and reinstalling it.
on NodeBB I see:
2025-07-01T12:09:00.698Z [4567/47620] - info: [plugins/web-push] VAPID keys OK. 2025-07-01T12:09:00.765Z [4567/47620] - info: [api] Adding 8 route(s) to `api/v3/plugins` 2025-07-01T12:09:00.799Z [4567/47620] - info: [router] Routes added 2025-07-01T12:09:00.843Z [4567/47620] - info: 🎉 NodeBB Ready 2025-07-01T12:09:00.845Z [4567/47620] - info: 🤝 Enabling 'trust proxy' 2025-07-01T12:09:00.857Z [4567/47620] - info: 📡 NodeBB is now listening on: 0.0.0.0:4567 2025-07-01T12:09:00.858Z [4567/47620] - info: 🔗 Canonical URL: https://citiverse.it
edit: I understand that the problem is with the “PEACE” theme.
Do you know if there is a patch for it?
ska the push notifications are now working again on the regular theme?
julian yep on "Harmony" works but It seems not to go only with the “Peace” theme.
ska I published web-push@0.7.5, let me know if that works on peace theme.
baris Thank you it seems to be working now.
I still have problems on Brave but maybe it's just a cache issue because on Firefox and Edge it's not giving me problems, I'll try again later from another computer.
ska me, but I have deprecated that plugin in favour of web-push
julian ah ok, I didn't realize that and didn't know that.
So it's basically abandoned and there will be no particular updates I guess, is it recommended to leave only web-push?
