The "standard" car charger is usually overkill—but your electrician might not know that [32:26]
134 66 1.8k
  • One thing I really don't get in the discussion around EVs and charging is, why are people so afraid of tripping the main breaker? If you have a total of e.g. 17 kW available and happen to go over, just reset the main breaker (or replace it in case it's still a traditional one). It's there precisely so that you wouldn't need to care about overloading the connection.
    In my experience people get by with a 3x25A (17 kW available, matches approximately a 70A service in the US) while using the available power to
    • heat/cool a single family home (in -20 °C weather mind you)
    • run all appliances (including the oven, stove, dryer etc.)
    • heat up a sauna
    • charge an EV
    • whatever else you typically would want to plug in, kettles and such
    While it's true you can trip the main breaker if you have everything on at the same time, typically it never happens even if there are no lockouts in place preventing overuse. And it's not like tripping it causes any permanent harm.
    Why is an electrical service upgrade constantly brought up as a solution when any home with >15 kW of available power won't need it? Is it against code to purposefully overcommit your mains in the US or something?
    Edit: there were valid concerns raised over how long-lived the breakers are (probably won't be rated for tens of fault-condition related trips), also that these smaller service specs aren't as common as I've gathered from the media. That might have something to do with this at least. Thanks for the replies – it's been an interesting discussion.
    The way that it works in most countries is that the breakers are per circuit in your wall. The breakers trip in order to prevent that single circuit from overheating and starting a fire in your walls.
    Let’s say you have a wire that’s rated for 16amps. More than that and it becomes a fire risk just threw overheating. @230v that gives you 3680w per circuit.
    If you have your industrial microwave, water heater, and car charger all going at the same time on that same circuit. This will draw way more than 3680w and thus would go over that 16a limit.
    The breakers trips once you go over that 16a limit for safety. It’s a good thing. This all being said no sane electrician would put those three things on the same circuit. lol.
    Circuit breakers are actually what enable you to safely over provision. Without them fires would just be a matter of time.
    I know it works this way in the U.S. and Germany at least.
  • Yep – US also doesn't generally do residential three-phase unlike many countries in the EU. A lot of garages around here have 3x16A 230V, not (only) due to the power requirements but because having three phases allows for simplest induction motors for things like blowers and circular saws. When you have three phases having a proper outlet in the garage starts making sense.
    Around here (Finland more specifically) we have three-phase even in most apartments. My two bedroom apartment has a 3x25A main breaker, and two devices on 3x16A circuit's – the sauna stove and oven+stovetop. Most single-family homes have 3x25A or 3x36A as well.
    US households are missing out on a lot of things due to their split-phase system.
    Ohh! I spent some time in the U.S. and there are 230v mains available. They just have special plugs. All homes have 230v. It’s just not available through the shocked face plug.
  • Ohh! I spent some time in the U.S. and there are 230v mains available. They just have special plugs. All homes have 230v. It’s just not available through the shocked face plug.
    I might've been unclear, I don't mean 230 V by itself, but three-phase distribution. The standard socket is labeled either 3x16A 230V alternatively labeled 380V 16A. Typically uses an IEC 60309 plug that looks like this:
    (Source: https://www.plugsocketmuseum.nl/IEC60309_2.html)
    Three phase has other benefits besides just more power, the US has it with their lower voltage as well, but typically reserved just for larger buildings.
  • The way that it works in most countries is that the breakers are per circuit in your wall. The breakers trip in order to prevent that single circuit from overheating and starting a fire in your walls.
    Not talking about the circuits, but the main electrical connection to the grid. To me it often seems like there's reluctance in overcommitting overprovisioning that capacity: as an example, four 16A circuits on a 25A main breaker. Here that's quite common, but even in Tech connections videos I've seen him bring up smart electric cabinets or automatic load monitoring when putting enough capacity on the mains to possibly go over.
    What I'm asking is, why bother? If you trip the mains by having too much load, just reset the breaker and be done with it. No need to automate things to not run into that situation, one will learn to not have the oven on while charging the car full blast. No need to gimp the charger amperage since you're running a new circuit anyway, and it's not like it's much different running a 20A circuit vs a 40A one. If that's 70% of your total available capacity, it doesn't matter – worst you have to do is walk downstairs and flip a switch.
  • My wife had to try charging on a 120V outlet last winter. The plug couldn't even keep up with the battery heating requirements to actually start charging; the battery percentage was going DOWN while plugged in. It was -25°C outside though, so it's a specific situation, but it's actually why she had to try to charge; it's a trip we can easily do without charging in the summer.
    Car specific maybe? I was able to charge at -30C outside from a 120V outlet last winter.
  • I agree with this youtube comment:
    As an electrician (in Australia), I agree with your basic premise. However, if you are asking me to install an EV charger, unless you tell me “I want it to charge slowly with a limited current capacity”, I am going to assume it is to charge an EV under ALL situations - fast to slow, for whoever may drive one today or in the future, even with a potential new homeowner. We generally do our work with the priority order (1) safety - nobody gets an electric shock and nothing catches fire; (2) avoidance of nuisance i.e. the thing you just installed doesn’t work and keeps tripping the breaker 😑 (3) avoiding needing replacement electrical work for at least 25 - 50 years
    Also I live in a townhouse with no garage. Our charger is between the neighborhood sidewalk and our parking spaces, so I'd prefer keeping it plugged in as little as possible to minimize any issues with foot traffic (neighbors, delivery people, garbage pickup, etc). I've seen other townhouse EV owners literally run an extension cable over the sidewalk to do an L1 charge for their EV and that's just asking for trouble.
    He did say that it's different if you don't own your own garage or live in a townhouse
  • Any AC load you can throw at an EV is effectively “slow charging”.
    My car supports a maximum of 9.6kw from an AC charger, but up to 150kw from DC fast chargers. Even with the fast charging, its not like a phone, it has active thermal management which will cool the battery and slow down the charging if it gets too hot. phones don’t really have that and is mainly why they degrade faster if quick charged.
    Can you source that?
  • What electric vehicle gets 5 miles/1.2kWh?
    Most of the small ones.
    You guys really should do some reading before you downvote things you don't understand
  • Not talking about the circuits, but the main electrical connection to the grid. To me it often seems like there's reluctance in overcommitting overprovisioning that capacity: as an example, four 16A circuits on a 25A main breaker. Here that's quite common, but even in Tech connections videos I've seen him bring up smart electric cabinets or automatic load monitoring when putting enough capacity on the mains to possibly go over.
    ADHD guy here.
    Wondering if these are reasons but need someone knowledgable to answer
    • does the mains breaker have a limited amount of resets / duty cycle?
    • is it bad for the whole house to trip sometimes? For me having to reset electronics, potential data loss etc makes it annoying.
    • is there a potential for surging when the mains is flicked back on from everything starting simultaneously?
  • Fuses sound antique compared to resettable circuit breakers. Though, if I remember correctly, your outlets have resettable breakers? Anyway, part of the wattage deficiency comes from the voltage being half of Europe's. The wires are similarly sized so they hit about the same max amperage (largely 15a for most circuits, 20a frequently in kitchens/garages/exterior outlets, 100-250a main breaker for the house) but halving the voltage halves the wattage available
    Here in Finland we don't have breakers on outlets themselves, they're all on electrical panel. But we have 'automatic fuses' which you can reset, they're just referred as 'fuse' almost always. Also, as our house is older, the 25A main fuses are actual porcelain ones, but new ones obviously have those automated too. Similarily, nearly all of the fault current protectors are on electrical panel instead of individual outlets.
    And in here nearly all fuses for lights, sockets and everything are either 10 or 16A with bigger main breakers, normally 3x25A for individual houses.
  • In recent test of a German auto club they found out that it‘s cheaper/ more effective to charger faster. You loose a lot of energy if you load slow over hours.
    This energy is taken by the electricity of the car. So, while charging the car is on and takes some Watts. There are just a few brands that have decoupled the charger circuit from the overall electric circuit of the car.
    Can’t find the article now, but I think charging a PHEV through a standard power plug had about 20% energy lost. It was clearly visible that a charger is a good choice.
    Edit: link https://www-adac-de.translate.goog/rund-ums-fahrzeug/elektromobilitaet/laden/ladeverluste-elektroauto-studie/?_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
    You‘ll loose
    • ~10-30% AC 2.3kw Standard Power Plug
    • ~ 5-10% DC 11kw Wallbox
    • Internal car electronics are crucial: Is the loading circuit de-coupled or the entire car On?
    • Temperature or pre-heating the battery before loading reduces losses at DC charging
    Watts/h
    Just watts, watts is already Joules per second.
  • This is not about me or you, this is "usually".
    That depends on what is meant by usually. You seem to think it means "most daily situations," but I think it means "most house installations." Yes, a usual day in a person's life does not require L2. But the usual person does require L2 if they want to use their car like most people prefer to use their car. Once a week I need L2 charging because of all the stuff I do that isn't commuting. That is 1 day in a 7 day week, so usually I don't need L2. But I would not be able to have an EV if I didn't have L2 unless I had a second car (which I don't have). I think most people fall into this category, so the usual person needs L2 even if they don't usually need L2.
    Which is really nice. No capacitors or other electronics needed. My old drill press has 750W 3-phase motor and it just works. Also having the power available gives options like running a 7kW log splitter with circular saw at the end of 20 meter long extension cord.
  • Car specific maybe? I was able to charge at -30C outside from a 120V outlet last winter.
    Maybe, I know Teslas are a bit power-hungry when parked.
  • ADHD guy here.
    one of us
    1. Hadn't considered that one TBH, no practical limits with actuations (rated in the thousands) but they're probably not rated for that many trips under a fault condition – now I'm curious, will have to dig up a spec sheet at some point
    2. Not really, unless you have equipment that's poorly designed everything should be fine. It's not much different from a brownout, and things should be configured to deal with that anyways if you don't have a UPS
    3. If there are a lot of reactive loads, then yes – e.g. electric motors, large capacitors. Those will have a large inrush when started again. Typically there isn't that much reactive loading in a residential home though, and it should be covered by the latency designed into the breaker.
    The first point is actually a really good one, and one I didn't really remember to consider. I'd guess it has at least something to do with that (and would explain why many homes around here are still configured with traditional fuses for the main connection – no need to worry about lifetime when you have to replace them anyways)
  • That depends on what is meant by usually. You seem to think it means "most daily situations," but I think it means "most house installations." Yes, a usual day in a person's life does not require L2. But the usual person does require L2 if they want to use their car like most people prefer to use their car. Once a week I need L2 charging because of all the stuff I do that isn't commuting. That is 1 day in a 7 day week, so usually I don't need L2. But I would not be able to have an EV if I didn't have L2 unless I had a second car (which I don't have). I think most people fall into this category, so the usual person needs L2 even if they don't usually need L2.
    That's the opposite of what I think.
    No you don't. You go and do those things, then plug it in and charge it up over the next 6 days until it's fully charged again. If that is insufficient then you are not a typical usecase.
  • I'm not sure what you mean by this. Any modern US house would have a similar capability, it's just older homes that would struggle since there would never be a need for such high power devices in a garage.
    Most older garages would only need enough power to run a single lightbulb, if it was slightly newer, maybe a low power automatic garage door opener.
    It's the same in any country with buildings over 100 years old.
    It’s the same in any country with buildings over 100 years old.
    In here 100+ year old houses are pretty common but practically all of them still have at least somewhat up to date electrics with that 3-phase input. It's been around for decades after all. My house is built originally 1928 and my mothers house is from 1909 and both of them have 3x25A main breakers with those 380V 16A CEE sockets around.
    And as garages commonly double as a work space with 3-phase induction motors on the tools it's still pretty common to have that 3x16A available as it's not that much more expensive to pull 5x2.5mm² cable to the garage compared to 3x2.5mm² for single phase 16A outlet.
  • Are they somehow more expensive in the US? 40A 230V rated ones cost something like 30-50 € around here which doesn't feel that expensive to me. I'll admit it's considerably more expensive (~4x the price) than a standard breaker, but it's still more like a rounding error in overall costs.
    Although EVSE's projection doesn't require you to periodically trip the GFCI so it doesn't get stuck, which is a major plus.
    Are they somehow more expensive in the US? 40A 230V rated ones cost something like 30-50 € around here which doesn’t feel that expensive to me.
    In my suggested hardwired 240V 20A EV charger the total parts cost is just the regular breaker on the left at about $18.
    The suggested solution you had of putting an outlet in would have parts cost of $119 + the cost of the GFCI breaker, the outlet and the receptacle cover. So that solution is 660% more expensive.
  • You seem to think it means "most daily situations," but I think it means "most house installations."
    So when I get home from a 200 mile round trip to the desert on Sunday night, I have roughly 20 miles of range on the Bolt. If I can add 40 miles of range to my car overnight (10 hours of charging at 4mph), that gives me 60 miles of range to do a 20 mile round trip commute. But what if I want to go to the Dodgers game after work? Or if I need to run a bunch of errands after work that I skipped while in the desert? People want their car to be able to go places when they want to go places.
    You are talking to me as if you think I didn't own multiple full EVs as my only car for over 6 years. I lived with a 90mile range Toyota Rav4 EV without DC fast charging and took it on road trips. I also lived with that car without L2 charging for a month. That month was miserable, and I would have never kept that car if I didn't upgrade to L2.
    If you have a second car, then you don't need a 300 mile range EV and also don't need L2. If you have a very short commute and don't do anything after work or on the weekends, then you don't need L2.
  • Are they somehow more expensive in the US? 40A 230V rated ones cost something like 30-50 € around here which doesn’t feel that expensive to me.
    Ok, so the US-style GFCI-breakers are indeed a lot more expensive than similarly rated DIN-rail alternatives. TIL
