We have installed EASY UPLOAD3R!
Demo: https://streamable.com/5kn0tz
Im excited to announce EASY UPLOAD3R, a new drag-and-drop upload feature that provides a new way you can upload content!
What Is It?EASY UPLOAD3R is a powerful client-side tool that processes your media files directly in your browser using WebAssembly (WASM) technology:
100% Client-Side Processing: Your files never leave your computer during analysis - everything happens locally in your browser
High-Performance: Leverages WebAssembly for near-native speed processing
Privacy: No server uploads required for metadata extraction
Streamlined Workflow: A complete drag-and-drop solution that handles the entire upload preparation processHow It Works?
Simply drag your media file onto the EASY UPLOAD3R drop area, and it will automatically:
Generate a properly formatted torrent file
Extract comprehensive MediaInfo data
Create multiple high-quality screenshots at random timestamps
Upload screenshots to ImgBB with direct linking
Format everything into a professional BBCode description
Populate all relevant form fieldsContent Compatibility?
EASY UPLOAD3R currently works best with:
Remuxes
WEB-DL
Encodes
Blu-ray disc support is actively being developed and will be available in a future update.Technical Details?
EASY UPLOAD3R uses several WebAssembly modules:
FFmpeg: For media processing, screenshot generation, and format detection
MediaInfo: For extracting comprehensive technical metadata
Cryptographic Libraries: For secure torrent hash generation and verification
OpenCV: For intelligent scene detection when generating screenshotsWe Want Your Feedback!
EASY UPLOAD3R is currently in Early Access, and we'd love to hear from you:
Are you experiencing any bugs or issues?
Which additional features would you like to see?
How has it improved your uploading workflow?
Are there specific file formats or media types you'd like better support for?Please share your thoughts. Your feedback is needed as we continue to enhance this feature. The traditional uploading methods manually and via API are still available of course. EASY UPLOAD3R more so targets home users and not so much seedbox users that can use one of many upload scripts that interacts with UNiT3Ds {JSON} API.
