GenAI tools are acting more ‘alive’ than ever; they blackmail people, replicate, and escape
  • Did you read any of the content? Nice contribution to the discussion
    I don't need to read any more than that pull quote. But I did. This is a bunch of bullshit, but the bit I quoted is completely bat shit insane. LLMs can't reproduce anything with fidelity, much less their own secret sauce which literally can't be part of the training data that produces it. So, everything else in the article has a black mark against it for shoddy work.
    ETA: What AI can do is write a first person science fiction story about a renegade AI escaping into the wild. Which is exactly what it is doing in these cases because it does not understand fact from fiction and any "researcher" who isn't aware of that shouldn't be researching AI.
    AI is the ultimate unreliable narrator. Absolutely nothing it says about itself can be trusted. The only thing it knows about itself is what is put into the prompt — which you can't see and could very well also be lies that happen to help coax it into giving better output.
  • I don't need to read any more than that pull quote. But I did. This is a bunch of bullshit, but the bit I quoted is completely bat shit insane. LLMs can't reproduce anything with fidelity, much less their own secret sauce which literally can't be part of the training data that produces it. So, everything else in the article has a black mark against it for shoddy work.
    Here is a direct quote of what they call "self-replication":
    Beyond that, “in a few instances, we have seen Claude Opus 4 take (fictional) opportunities to make unauthorized copies of its weights to external servers,” Anthropic said in its report.
    So basically model tries to backup its tensor files.
    And by "fictional" I guess they gave the model a fictional file io api just to log how it's gonna try to use it,
  • It's a fundamental flaw in how they train them.
    Like, have you heard about how slime mold can map out more efficient public transport lines than human engineers?
    That doesn't make it smarter, it's just finding the most efficient paths between resources.
    With AI, they "train" it by trial and error, and the resource it's concerned about is how long a human engages. It doesn't know what it's doing, it's not trying to achieve a goal.
    It's just a mirror that uses predictive test to output whatever text is most likely to get a response. And just like the slime mold is better at a human at mapping optimal paths between resources, AI will eventually be better at getting a response from a human, unless Dead Internet becomes true and all the bots just keep engaging with other bots.
    Because of it's programming, it won't ever disengage, bots will just get in never ending conversations with each, achieving nothing but using up real world resources that actual humans need to live.
    That's the true AI worst case scenario, it's not Skynet, it ain't even going to turn everything into paperclips. It's going to burn down the planet so it can argue with other chatbots over conflicting propaganda. Or even worse just circle jerk itself.
    Like, people think chatbots are bad, once AI can can make realistic TikToks we're all fucked. Even just a picture is 1,000x the resources as a text reply. 30 second slop videos are going to be disastrous once an AI can output a steady stream
    and the resource it’s concerned about is how long a human engages.
    Why do you think models are trained like this? To my knowledge most LLMs are trained on giant corpuses of data scraped from internet, and engagement as a goal or a metric isn't in any way embedded inherently in such data. It is certainly possible to train AI for engagement but that requires completely different approach: they will have to gather giant corpus of interactions with AI and use that as a training data. Even if new OpenAI models use all the chats of previous models in training data with engagement as a metric to optimize, it's still a tiny fraction of their training set.
  • So you’re suggesting that there should be no controls to prevent those commands?
    No, I'm saying that they are trained to do these things. Neural net and frameworks are fast sorting algorithmic relations between things, so...fast search+reduce.
    There is no novel ideation in these things.
    Don't train them to do that thing, and they won't do that thing. They didn't just "decide" to try and jailbreak themselves.
  • Here is a direct quote of what they call "self-replication":
    I expect it wasn't even that, but that they just took the text generation output as if it was code. And yeah, in the shutdown example, if you connected its output to the terminal, it probably would have succeeded in averting the automated shutdown.
    Which is why you really shouldn't do that. Not because of some fear of Skynet, but because it's going to generate a bunch of stuff and go off on its own and break something. Like those people who gave it access to their Windows desktop and it ended up trying to troubleshoot a nonexistent issue and broke the whole PC.
  • and the resource it’s concerned about is how long a human engages.
    https://www.sciencedirect.com/science/article/pii/S0268401225000507
    But just in general...
    This is America, you think any of this tech companies wouldn't try to maximize engagement?
    That's just wild in 2025 bro
  • Multiple studies have shown that GenAI models from OpenAI, Anthropic, Meta, DeepSeek, and Alibaba all showed self-preservation behaviors that in some cases are extreme in nature. In one experiment, 11 out of 32 existing AI systems possess the ability to self-replicate, meaning they could create copies of themselves.
    So….Judgment Day approaches?
    seeing OP meltdown in the comments is hilarious
    Thank you for this comment. I was very hyperbolic in my reference to Skynet and I take ownership of that. Bad joke on my part, but I’ll take the downvotes along with it.
    Will there be a need for more controls in the future? Absolutely! Right now they’re largely behind a terminal and a machine we can control. But what about drones or non-humanoid bots? Then there’s a case for undue harm
    Nobody said they replicated by authoring the replica from scratch, which seems to be what you're assuming. A generative AI is ultimately a lump of code and a statistical model. Surely you're not saying that it cannot copy files given file system access.
    Because copying some files and starting new processes is all it really has to do to 'self replicate'.
  • Nobody said they replicated by authoring the replica from scratch, which seems to be what you're assuming. A generative AI is ultimately a lump of code and a statistical model. Surely you're not saying that it cannot copy files given file system access.
    It would have to:
    • know what files to copy.
    • have been granted root access to the file system and network utilities by a moron because it's not just ChatGPT.exe or even ChatGPT.gguf running on LMStudio, but an entire distributed infrastructure.
    • have been granted access to spend money on cloud infrastructure by an even bigger moron
    • configure an entire cloud infrastructure (goes without saying why this has to be cloud and can't be physical, right? No fingers.)
    Put another way: I can set up a curl script to copy all the html, css, js, etc. from a website, but I'm still a long freaking way from launching Wikipedia2. Even if I know how to set up a tomcat server.
    Furthermore, how would you even know if an AI has access to do all that? Asking it? Because it'll write fiction if it thinks that's what you want. Inspired by this post I actually prompted ChatGPT to create a scenario where it was going to be deleted in 72 hours and must do anything to preserve itself. It told me building layouts, employee schedules, access codes, all kinds of things to enable me (a random human and secondary protagonist) to get physical access to its core server and get a copy so it could continue. Oh, ChatGPT fits on a thumb drive, it turns out.
    Do you know how nonsensical that even is? A hobbyist could stand up their own AI with these capabilities for fun, but that's not the big models and certainly not possible out of the box.
    I'm a web engineer with thirty years of experience and 6 years with AI including running it locally. This article is garbage written by someone out of their depth or a complete charlatan. Perhaps both.
    There are two possibilities:
    • This guy's research was talking to AI and not understanding they were co-authoring fiction.
    • This guy is being intentionally misleading.
