The Trump Administration is Building a National Citizenship Data System; State and county election officials can now check the citizenship status of their entire voter lists.
The Trump administration has, for the first time ever, built a searchable national citizenship data system.
The tool, which is being rolled out in phases, is designed to be used by state and local election officials to give them an easier way to ensure only citizens are voting. But it was developed rapidly without a public process, and some of those officials are already worrying about what else it could be used for.
NPR is the first news organization to report the details of the new system.
For decades, voting officials have noted that there was no national citizenship list to compare their state lists to, so to verify citizenship for their voters, they either needed to ask people to provide a birth certificate or a passport — something that could disenfranchise millions — or use a complex patchwork of disparate data sources.
Is it built on top of a Palantir database?
My money's on it
Where I live we have something called the electoral roll, which is a nationwide database of registered voters.
It's weird the states don't also have this already.
I'm fairly sure we already do, but they are administered state by state, and not centralized.
This must be opposed by all state authorities
Sounds very 1930's German like.
Person from outside the US here. Please explain me why this is a problem?
In the EU only citizens can vote in national elections, for local elections non-citizens can vote only if they are residents.
Because they want to use the data for more nefarious purposes to displace non-white American voters.
Every region in the world has its way of doing things. When new layers of control are added, it makes some people nervous.
When the new controls are perhaps mismanaged and corrupt, promising to do more than advertised, it makes some people angry. Especially during an increase of lawlessness and corruption of the central government. Especially when it uses the same messaging which has already harmed many
I think in most cases where this administration seems to have a good idea it's important to remember that it's likely designed to keep them in power.
A national database that the trump admin controls will 100% be exploited for their own gain, just like every other aspect of government is being exploited for their gain now.
The ONLY People who Are WORRIED about This are STUPID LIBRULS trying to ILLEGALLY Vote! Everyone else is TOTALLY Fine with this because there's NO WAY a Database like This can be Misused by a Government Deporting LEGAL CITIZENS and trying to Make GAY AND TRANS PEOPLE ILLEGAL!
The US is generally the same where some local elections allow non-citizen residents to vote for local issues.
The issue with this is was not created publicly. We don't know what kind of data is being uses to determine someone's status. If someone is private enough to not have any data collected by its source, then they could be denied voting rights despite being legally able to vote.
It also could end up bring used as the sole source for verifying someone's status, despite having documents to prove otherwise.
What happens if someone is illegitimately removed from this database? How can you show whether it was a glitch, or deliberate? How do you know if the information they have about you is even right, or get it changed if you need to? Where's the accountability?
See the UK Post Office accounting scandal, in which a persistent computer error went unfixed for decades and caused hundreds of post office employees to be fired and dragged through courts for corruption that never happened. A good chunk of them committed suicide. The government and the software company both knew about the bug causing the issue, too, but prosecutions continued. "If the computer says it, it must be right", sort of danger.
I would imagine it's based on social security numbers.
Same fucking way americans correct issues with SSA, DHS, and the IRS: paperwork. Come the fuck on with this slippery slope bullshit. Ever had a job? The I-9 employment authorization paperwork... just shut up
no no, it's an input to a Palantir database
The database is the least important part of the system: the organizational structure, rules, and procedures are way more important, because they actively help or harm people.
Yes I think you missed the point.
If you are purged you can't vote. That becomes a problem on election day.
You might get a feel-good provisional ballot but no real way to track that it got counted.
This is what happened last year, except by a bunch of randos claiming that so-and-so wasn't a legal voter, with no proof or recourse.
So now they can just check against RNC registered voters and "disable" 10% of people who aren't registered RNC and no way to prove or possibly even know until after the election passes.
No thanks.
Not to mention they could run this against the voter rolls, so you show as eligible if you check your registration status, but have your ballot tossed (or get turned around at the polling place) because you're not on this other database.
So, states already have their list of registered voters, this is about culling people from that list the state doesn't think should really be there (but really specifically those supporting the opposition of the party in power, typically Republicans removing minority groups).
The reason removing people is a real thing that needs to happen is that people aren't permanent citizens of a state, they're just residents, and what state they are a resident of for voting purposes is extremely easy to change, and doesn't really require notifying the state you're leaving, just the one you now want to be a resident of.
The reason this specific thing is bullshit is that every time anyone does any kind of check for non-citizens voting, it's basically non-existent. Instead, they're going to use the pretense of checking citizenship to check other information, which they'll selectively find other discrepancies in to remove people who are registered, but are likely to support their opposition. Likely with little time before an election, so hopefully they don't find out until it's too late or other frictions cause them to forgo voting voluntarily.
NO KINGS! Tomorrow on Trump's birthday, we protest across the entire nation. Check the website for No Kings events near you!
Pope Betting Odds: Bettors Lose Millions Predicting the New Pope as Polymarket Edge Fizzles Out
“No Apple tax means we will lower prices” - Proton announces lower prices for users by up to 30% after US ruling against Apple fees
