Taco Bell rethinks AI drive-through after man orders 18,000 waters
  • "This Website is Served from Nine Neovim Buffers on My Old ThinkPad"
    59 Stimmen
    13 Beiträge
    50 Aufrufe
    N
    that is so interesting, did you publish the code somewhere?
    9 Aufrufe
  • 531 Stimmen
    165 Beiträge
    5k Aufrufe
    mousepotatodoesstuff@lemmy.worldM
    The Trump administration is just a straight-up Captain Planet villain at this point.
    22 Aufrufe
  • Using Signal groups for activism
    204 Stimmen
    37 Beiträge
    429 Aufrufe
    ulrich@feddit.orgU
    You're using a messaging app that was built with the express intent of being private and encrypted. Yes. You're asking why you can't have a right to privacy when you use your real name as your display handle in order to hide your phone number. I didn't ask anything. I stated it definitively. If you then use personal details as your screen name, you can't get mad at the app for not hiding your personal details. I've already explained this. I am not mad. I am telling you why it's a bad product for activism. Chatting with your friends and clients isn't what this app is for. That's...exactly what it's for. And I don't know where you got the idea that it's not. It's absurd. Certainly Snowden never said anything of the sort. Signal themselves never said anything of the sort. There are other apps for that. Of course there are. They're varying degrees of not private, secure, or easy to use.
  • 19 Stimmen
    24 Aufrufe
  • Building a slow web
    175 Stimmen
    37 Beiträge
    558 Aufrufe
    I
    Realistically, you don't need security, NAT alone is enough since the packets have nowhere to go without port forwarding. But IF you really want to build front end security here is my plan. ISP bridge -> WAN port of openwrt capable router with DSA supported switch (that is almost all of them) Set all ports of the switch to VLAN mirroring mode bridge WAN and LAN sides Fail2Ban IP block list in the bridge LAN PORT 1 toward -> OpenWRT running inside Proxmox LXC (NAT lives here) -> top of rack switch LAN PORT 2 toward -> Snort IDS LAN PORT 3 toward -> combined honeypot and traffic analyzer Port 2&3 detect malicious internet hosts and add them to the block list (and then multiple other openwrt LXCs running many many VPN ports as alternative gateways, I switch LAN host's internet address by changing their default gateway) I run no internal VLAN, all one LAN because convenience is more important than security in my case.
  • 2 Stimmen
    87 Aufrufe
    F
    IMO stuff like that is why a good trainer is important. IMO it's stronger evidence that proper user-centered design should be done and a usable and intuitive UX and set of APIs developed. But because the buyer of this heap of shit is some C-level, there is no incentive to actually make it usable for the unfortunate peons who are forced to interact with it. See also SFDC and every ERP solution in existence.
