OpenAI supremo Sam Altman says he 'doesn't know how' he would have taken care of his baby without the help of ChatGPT
  • YouTube is getting rid of its Trending page and Trending Now list
    154 Stimmen
    48 Beiträge
    V
    Shorts are annoying, but now they started cluttering the subscription page with community posts. It's bad, but especially when you browse in landscape Mode on a phone. They get blown up so big you have to scroll like 3 pages for one post, and there's a lot of them. And they will stay on your page forever and wont go away. No option to click them away at all.
  • Grok, Elon Musk's AI chatbot, seems to get right-wing update
    182 Stimmen
    13 Beiträge
    63 Aufrufe
    Yep. Pretty sure that was deliberate on Musk's (or his cronies) part. Imagine working at X and being told by your boss "I'd like you to make the bot more racist please." "Can you convince it that conspiracy theories are real?"
    11 Aufrufe
  • Climate science
    138 Stimmen
    12 Beiträge
    59 Aufrufe
    Z
    What is the connection to technology here?
  • 61 Stimmen
    17 Beiträge
    67 Aufrufe
    anzo@programming.devA
    I’ll probably never trust anything they’ve touched until I’ve taken it apart and put it back together again. Me too. But the vast majority of users need guardrails, and have a different threat model. Even those that also care about privacy, if they just want a solution that comes by default, this adtech 'fake' or 'superficial' solution does provide something. And anything is more than nothing.
    14 Aufrufe
    If you're a developer, a startup founder, or part of a small team, you've poured countless hours into building your web application. You've perfected the UI, optimized the database, and shipped features your users love. But in the rush to build and deploy, a critical question often gets deferred: is your application secure? For many, the answer is a nervous "I hope so." The reality is that without a proper defense, your application is exposed to a barrage of automated attacks hitting the web every second. Threats like SQL Injection, Cross-Site Scripting (XSS), and Remote Code Execution are not just reserved for large enterprises; they are constant dangers for any application with a public IP address. The Security Barrier: When Cost and Complexity Get in the Way The standard recommendation is to place a Web Application Firewall (WAF) in front of your application. A WAF acts as a protective shield, inspecting incoming traffic and filtering out malicious requests before they can do any damage. It’s a foundational piece of modern web security. So, why doesn't everyone have one? Historically, robust WAFs have been complex and expensive. They required significant budgets, specialized knowledge to configure, and ongoing maintenance, putting them out of reach for students, solo developers, non-profits, and early-stage startups. This has created a dangerous security divide, leaving the most innovative and resource-constrained projects the most vulnerable. But that is changing. Democratizing Security: The Power of a Community WAF Security should be a right, not a privilege. Recognizing this, the landscape is shifting towards more accessible, community-driven tools. The goal is to provide powerful, enterprise-grade protection to everyone, for free. This is the principle behind the HaltDos Community WAF. It's a no-cost, perpetually free Web Application Firewall designed specifically for the community that has been underserved for too long. It’s not a stripped-down trial version; it’s a powerful security tool designed to give you immediate and effective protection against the OWASP Top 10 and other critical web threats. What Can You Actually Do with It? With a community WAF, you can deploy a security layer in minutes that: Blocks Malicious Payloads: Get instant, out-of-the-box protection against common attack patterns like SQLi, XSS, RCE, and more. Stops Bad Bots: Prevent malicious bots from scraping your content, attempting credential stuffing, or spamming your forms. Gives You Visibility: A real-time dashboard shows you exactly who is trying to attack your application and what methods they are using, providing invaluable security intelligence. Allows Customization: You can add your own custom security rules to tailor the protection specifically to your application's logic and technology stack. The best part? It can be deployed virtually anywhere—on-premises, in a private cloud, or with any major cloud provider like AWS, Azure, or Google Cloud. Get Started in Minutes You don't need to be a security guru to use it. The setup is straightforward, and the value is immediate. Protecting the project, you've worked so hard on is no longer a question of budget. Download: Get the free Community WAF from the HaltDos site. Deploy: Follow the simple instructions to set it up with your web server (it’s compatible with Nginx, Apache, and others). Secure: Watch the dashboard as it begins to inspect your traffic and block threats in real-time. Security is a journey, but it must start somewhere. For developers, startups, and anyone running a web application on a tight budget, a community WAF is the perfect first step. It's powerful, it's easy, and it's completely free.
  • 136 Stimmen
    16 Beiträge
    62 Aufrufe
    E
    I thought we were going to get our share of the damages
  • 50 Stimmen
    11 Beiträge
    52 Aufrufe
    G
    Anyone here use XING?
