OpenAI supremo Sam Altman says he 'doesn't know how' he would have taken care of his baby without the help of ChatGPT
  • 119 Stimmen
    14 Aufrufe
    wizardbeard@lemmy.dbzer0.comW
    Most still are/can be. Enough that I find it hard to believe people are missing out without podcasts through these paid services.
    11 Aufrufe
  • 56 Stimmen
    13 Beiträge
    58 Aufrufe
    P
    I tried before, but I made my life hell on earth. I only have whatsapp now because its mandatory. Since 2022, I only have lemmy, mastodon and unfortunately whatsapp as social media.
  • 371 Stimmen
    26 Beiträge
    99 Aufrufe
    hollownaught@lemmy.worldH
    Bit misleading. Tumour-associated antigens can very easily be detected very early. Problem is, these are only associated with cancer, and provide a very high rate of false positives They're better used as a stepping stone for further testing, or just seeing how advanced a cancer is That is to say, I'm assuming that's what this is about, as i didnt rwad the article. It's the first thing I thought of when I heard "cancer in bloodstream", as the other options tend to be a bit more bleak Edit: they're talking about cancer "shedding genetic material", which I hate how general they're being. Probably talking about proto oncogenes from dead tumour debris, but seems different to what I was expecting
  • 210 Stimmen
    31 Beiträge
    121 Aufrufe
    In 2025 it would be anything above 3.6 million. It's a ton of money but here's a list of a few people that hit it. https://aflcio.org/paywatch/highest-paid-ceos Now if they added in a progressive tax rate for corporate taxes as well.... Say anything over 500 million in net profit is taxed at a 90+% rate. That would solve all sorts of issues. Suddenly investors of all these mega corps would be pushing hard to divide up the companies into smaller entities. Wealth tax in the modern age could be an inheritance tax. Anything over the median life earnings of individuals could be taxed at 100%. So median earnings in my area is $65K * 45 years (20-65k) = $2.93 million.
  • 490 Stimmen
    18 Beiträge
    68 Aufrufe
    Pretty confident that's the intention of that name
    37 Aufrufe
    I think the principle could be applied to scan outside of the machine. It is making requests to 127.0.0.1:{port} - effectively using your computer as a "server" in a sort of reverse-SSRF attack. There's no reason it can't make requests to 10.10.10.1:{port} as well. Of course you'd need to guess the netmask of the network address range first, but this isn't that hard. In fact, if you consider that at least as far as the desktop site goes, most people will be browsing the web behind a standard consumer router left on defaults where it will be the first device in the DHCP range (e.g. 192.168.0.1 or 10.10.10.1), which tends to have a web UI on the LAN interface (port 8080, 80 or 443), then you'd only realistically need to scan a few addresses to determine the network address range. If you want to keep noise even lower, using just 192.168.0.1:80 and 192.168.1.1:80 I'd wager would cover 99% of consumer routers. From there you could assume that it's a /24 netmask and scan IPs to your heart's content. You could do top 10 most common ports type scans and go in-depth on anything you get a result on. I haven't tested this, but I don't see why it wouldn't work, when I was testing 13ft.io - a self-hosted 12ft.io paywall remover, an SSRF flaw like this absolutely let you perform any network request to any LAN address in range.
    9 Aufrufe
    Wow, that's really concerning! It's crazy how these breaches can lead to such massive losses. If anyone's dealing with crypto fraud, I’ve heard Segev LLP is a solid firm that helps people and companies navigate these situations. Stay safe, everyone!
