If we go by that logic, some worker from your supermarket should be able to do surgeries
Doctors have to learns this much so they can handle most really unusual stuff, not because they have to know this for a standard surgery.
At some point in a not very distant future, you will probably be better off with the robot/AI. As it will have wider knowledge of how to handle fringe cases than a human surgeon.
We are not there yet, but maybe in 10 years or maybe 20?I'd bet on at least twenty years before it's in general use, since this is a radical change and it makes sense to be cautious about new technology in medicine. Initial clinical trials for some common, simple surgeries within ten years, though.
We are not there yet, but maybe in 10 years or maybe 20?Fringe cases yes, like rare conditions. It almost certainly won't be able to handle something completely unexpected.
it'll definitely get the greenlight in countries like China before anywhere in the west, I believe
realistic surgery
lifelike patient
I wonder how doctors could compare this simulation to a real surgery. I’m willing to bet it’s “realistic and lifelike” in the way a 4D movie is.
Biological creatures don’t follow perfect patterns you have all sorts of unexpected things happen. I was just reading an article about someone whose entire organs are mirrored from the average person.
Nothing about humans is “standard”.
Right I'm sure a bunch of arm chair docs on lemme are totally more knowledgeable and have more understanding of all this and their needed procedures than actual licensed doctors.
My son's surgeon told me about the evolution of one particular cardiac procedure. Most of the "good" doctors were laying many stitches in a tight fashion while the "lazy" doctors laid down fewer stitches a bit looser. Turns out that the patients of the "lazy" doctors had a better recovery rate so now that's the standard procedure.
Sometimes divergent behaviors can actually lead to better behavior. An AI surgeon that is "lazy" probably wouldn't exist and engineers would probably stamp out that behavior before it even got to the OR.
That’s ridiculous. Everyone knows that for a robot to perform an operation like this safely, it needs human-written code and a LiDAR.
We are not there yet, but maybe in 10 years or maybe 20?I doubt it. It simply would be enough, if the AI could understand and say when it reaches its limits and hand over to a human. But that is even hard for humans as Dunning & Kruger discovered.
thank you for removing my gallbladder robot, but i had a brain tumor
Really hope they tried it on a grape first at least.
Good, now add jailtime for the ceo if something goes wrong, then we'll have a very safe tech.
know what? let's just skip the middleman and have the CEO undergo the same operation. you know like the taser company that tasers their employees.
can't have trust in a product unless you use the product.
Hold on 3P0...you gotta little piece of human stuff stuck on your right end effector clamp top hinge pin. There, all good! Continue!
Eliminating room for error, not to say AI is flawless but that is the goal in most cases, is a good way to never learn anything new. I don't completely dislike this idea but I'm sure it will be driven towards cutting costs, not saving lives.
Nah, just a thorough reproduction of the consequences of that wrong.
Not specifically but I think the guidance is applicable to most incisions of the heart. I think the fact that it's a muscular and constantly moving organ makes it differently than something like an epidermal stitch.
And my post isn't to say "all mistakes are good" but that invariablity can lead to stagnation. AI doesn't do things the same way every single time but it also doesn't aim to "experiment" as a way to grow or to self-reflect on its own efficacy (which could lead to model collapse). That's almost at the level of sentience.
That’s a different thing indeed. In your case the AI
goes wild, will strip dance and tell poor jokes (while flirting with the ventilation machine)
Microsoft Came to Bargain: Use OneDrive for Device Backup, Opt into Loyalty Program and Use Their Products Till You Earn 1000 Points or Pay $30 and They Might Give You Security Updates till Oct 2026.
Hong Kong workers strike against the algorithmic exploitation of Keeta, a food delivery platform
