Couldn't we just use the point system from 5th element? The car noticed you did something illegal and dedicated from your point pool.
Risk Compension predicts that drivers would simply use this new information to drive more aggressively, negating any possible safety benefits.
The classic example we already have of this is when you are stopped at a side road about to enter the main road, and a car coming towards you on the main road signals to turn in.
Many people take the fact the other car has their turn signal on as a guarantee that it's safe to emerge, but any good driving instructor will tell you to wait until the car actually begins to turn before you yourself emerge.
They had their signal on but that doesn't mean they're actually going to DO what the signal said they would.
Same with the front brake light. It would be like "Well their front brake light came on, so I assumed it was safe to step into the crosswalk" NO. They could have just tapped the brake a second, doesn't mean they saw you, or they will actually stop.
For normal people, yes. This is to prevent accidents.
Again, if you're too stupid to make sure the multiton hunk of metal is coming to a stop by all the other obvious visual markers, including watching it's speed compared to stationary objects like signs and lamp posts, then this won't do shit. People need more aweness of their surroundings, not a bunch of lights and horns because people won't pay attention.
You enter the road when it's safe, not jump in and play frogger with lights hoping to get across.
Edit for consistency
This is stupid
It is to colorblind people. You could use something else of course, just saying...
It's doesn't matter, since the absence or presence of light would still be perceived by colour blind people. It doesn't change how they would drive, as they are already driving with the knowledge of colour blindness in mind when looking at tail lights.
Theres a saying in computer stuff that applies nicely here. PEBKAC, problem exists between keyboard and computer...turn signals have to be turned on, no amount of engineering can fix bad driving.
it's forbidden to use rear fog lights under rain (it's more confusing than helpful)
if you live somewhere dry, that's not a concern. But here it rains 1 day in 3
Using your vehicle lights to see and be seen
About the new vehicle lighting standard for cars in 2021 and tips on how to use your lights safely now.
Transport Canada (tc.canada.ca)
Tail lights being red is fine if you live with the most common forms of colorblindness which fall into what we call “red-green colorblind.” It is still a different color than headlights.
Now put those same red-green lights on the front, and we have a problem.
By signaling to oncoming traffic and vehicles approaching from the side, a front brake light provides an essential visual cue that a car is slowing down or preparing to stop. When the light is extinguished, it indicates that a stationary vehicle might initiate movement. According to Tomasch, this visual feedback can significantly truncate the reaction time for other road users, leading to shorter stopping distances and consequently diminishing the likelihood of accidents.
Sounds reasonable. Personally I just want front turn signals to be visible from the opposite side again.
So it sounds like you're checking to see when the light turns off, to know that the car is going.
Sounds like what we actually need is a green accelerator light on the front of the car.
Not selling tanks as cars could also help. Especially with fatality rates
But why? Again, the perception would be absence or presence of light on a standardized indicator.
FYI signal lights are much more strictly regulated in Europe, such as position, colour, shape and strength.
This study is from Austria.
They could use traffic light green. There's not any problems identifying those even in places with the lights mounted horizontally. There's enough difference in saturation you can tell the difference even with colorblindness.
Cars with lane-keep assist with vibrate the steering wheel and beep at you. It's at least something but I think most people turn it off if it gets annoying
If anything I think they would have to use a green light that turns on when accelerating/not braking. It would be way more dangerous in the future when people are trained with "No green = braking" but older cars don't have the light at all.
It's important to consider how a transition like this would even work. I personally think this is a little too drastic of a change, and is incompatible with existing vehicles and habits.
Google Play’s latest security change may break many Android apps for some power users. The Play Integrity API uses hardware-backed signals that are trickier for rooted devices and custom ROMs to pass.
Keep the Future Human: How Unchecked Development of Smarter-Than-Human, Autonomous, General-Purpose AI Systems Will Almost Inevitably Lead to Human Replacement. But it Doesn't Have to.
Most of us will leave behind a large ‘digital legacy’ when we die. Here’s how to plan what happens to it
