It would also help to know whether or not I'm going to get smushed.
Every couple weeks or so I seem to find myself behind someone that’s always either accelerating, or braking, with the brake lights repeatedly flashing on momentarily for no apparent reason.
In many EVs and Hybrids the "letting off the accelerator" engages the regeneration drag which slows the car. A number of vehicle makers with particularly aggressive drag (which gets higher regen rates) automatically illuminate the brake lights. So if you're behind one of these it will look like they are braking when they may have no foot on any pedal (brake or accelerator).
thanks for this information. Next time i see this I won't be confused
Possibly, and I'd be interested in some sort of 360° LED on top of a vehicle to indicate to pedestrians and other drivers alike of its (de)acceleration.
But jamming some non standard colours in what is a long term understanding on the front of a vehicle I can't really get with and would like to see the impact to people with partial / colour blindness with using such a system.
Like, does the average pedestrian know what the green and red lights mean on an aircraft? I bet not.
Well you should educate yourself on the rules of the method of travel no matter.
If you were to go up in the air and you didn’t educate yourself on what the lights mean, you’re going to ruin everyone else’s day in your incredibly dangerous ignorance.
You don’t take a paddle boat onto the water without understanding some basic principles of water navigation… why would roads in this specific cause be any different? We already do with most land methods, this one is gonna be hinge? Nah. Ignorance isn’t an excuse.
Theres a saying in computer stuff that applies nicely here. PEBKAC, problem exists between keyboard and computer...turn signals have to be turned on, no amount of engineering can fix bad driving.
I've always heard it as "PICNIC"
Problem In Chair, Not In Computer
and on the opposite side don’t turn on your emergency lights while driving in bad weather. you’re only causing confusion by making it seem like you have turn signals on if i can’t see both blinkers.
The hazards also override your turn signals so I now have no idea when you are going to attempt lane change.
How would you do that so it isn’t ugly as hell
same way we do with lights now, design them attractively. It is not always successful and that's on the manufacturers.
and isn’t prone to misunderstanding?
what about it is confusing? green = not coming at you so it's okay to turn left (or whatever).
This wouldn’t really be helpful to those who are colorblind.
Personally I just want front turn signals to be visible from the opposite side again
Not sure if I read that correctly, but I don't think this has ever been the case?
And also like, used at all.
Somebody better tell traffic light designers
I'd rather see mandatory rear running lights. The amount of people who can't be arsed to turn on their lights in bad visibility conditions is too damn high.
I don't understand this at all. Why do I, as a person in front of a vehicle, care whether or not it's braking?
This will lead to people braking momentarily to slow down, and others turning in front of slowing down traffic.
Little benefit, but the cost of adding front brake lights would be passed on to the car buyers.
Couldn't we just use the point system from 5th element? The car noticed you did something illegal and dedicated from your point pool.
Would speed up crosswalks a lot too. Whenever I cross a crosswalk with my dog I don't want to risk me misjudging the braking of cars so I tend to really wait until I'm sure they're stopping.
Sounds like it can help oncoming traffic as well as traffic to either side of the vehicle
Oh, you think I need a new chair? Will the Internet come back then?
Thats more an issue of using the same lamp for rear lights and turn signal
My main thoughts instantly come to someone in the opposing left turn lane, if they are not applying the brakes they are likely starting to turn and if they do it right in front of you, you have more of a heads up than just them starting to turn and can set yourself in a better position to hopefully stop in time. Driving is all about judgment calls and having more info quicker is important to those calls.
Google Play’s latest security change may break many Android apps for some power users. The Play Integrity API uses hardware-backed signals that are trickier for rooted devices and custom ROMs to pass.
Most of us will leave behind a large ‘digital legacy’ when we die. Here’s how to plan what happens to it
