337 165 9.7k
  • Zebra Crossing: An easy-to-use digital safety checklist
    23 Stimmen
    14 Aufrufe
    pro@programming.devP
    If you feel that the guide lacks anything or if you think the guide can be improved further, you can reach out to them on GitHub, to improve this guide.
  • EnteAuth (and a bunch of other FOSS) take Microsoft's "free" money
    47 Stimmen
    13 Beiträge
    29 Aufrufe
    https://en.m.wikipedia.org/wiki/Embrace,_extend,_and_extinguish OP has a reasonable concern, Microsoft has had a troubling past history, and embrace extend extinguish hasn't gone away, just look at the office file standards shenanigans. It's certainly the case that the purchase of github is intended to create a platform that has network effects (making it hard to leave). Microsoft has proven many times that their participation in FOSS tends to come with a catch or an intent to subvert.
  • 34 Stimmen
    19 Beiträge
    50 Aufrufe
    O
    She didn’t call herself a libertarian and explicitly said she isn’t And North Korea calls its self democratic. Yet we don't call it a democracy. No, we define these categories by what they are/do/believe in/etc... and like it or not, Ayn Rand's Objectivism is 100% a component of libertarian ideology, Ayn Rand's beliefs are very much a core component of Libertarianism, and i'm sorry to inform you that many on that list of yours ARE libertarians, such as Milei. In the same way the Marx&Hegel were a cornerstone of communism. But you are correct about Zelenskyy, he is not libertarian. Bullshit. You might also want to think who’s “we” and what externalia does giving that “we” an ability to “put limits on these things” possess. Standard Libertarian response that basically ignores the existence of anything outside the individual Also, from the person who you believe isn't a Libertarian: The source of the government's authority is "the consent of the governed." This means that the government is not the ruler, but the servant or agent of the citizens; it means that the government as such has no rights except the rights delegated to it by the citizens for a specific purpose. -Ayn Rand, Galt's Speech. A government is large scale organized violence and warlords. Spoken just like Rand herself! "Only a government holds that power. The nature of governmental action is: coercive action. The nature of political power is: the power to force obedience under threat of physical injury—the threat of property expropriation, imprisonment, or death." The Virtue of Selfishness "The Nature of Government," The Virtue of Selfishness, again Ayn Rand. Lastly, on privatization: https://www.aeaweb.org/articles?id=10.1257%2Fjep.20.3.187
  • Getting Started with Ebitengine (Go game engine)
    15 Stimmen
    25 Aufrufe
    R
    This video complements the text tutorial at https://trevors-tutorials.com/0003-getting-started-with-ebitengine/ Trevors-Tutorials.com is where you can find free programming tutorials. The focus is on Go and Ebitengine game development. Watch the channel introduction for more info.
  • Forced E-Waste PCs And The Case Of Windows 11’s Trusted Platform
    316 Stimmen
    116 Beiträge
    K
    I was pretty lucky in university as most of my profs were either using cross platform stuff or Linux exclusive software. I had a single class that wanted me using windows stuff and I just dropped that one. Awesome that you're getting back into it, it's definitely the best it's ever been (and you're right that Steam cracked the code). It sounds like you probably know what you're doing if you're running Linux VMs and stuff, but feel free to shoot me a PM if you run into any questions or issues I might be able to point you in the right direction for.
  • 146 Stimmen
    37 Beiträge
    376 Aufrufe
    D
    Self hosted Sunshine and Moonlight is the way to go.
  • 131 Stimmen
    67 Beiträge
    687 Aufrufe
    I
    Arcing causes more fires, because over current caused all the fires until we tightened standards and dual-mode circuit breakers. Now fires are caused by loose connections arcing, and damaged wires arcing to flammable material. Breakers are specifically designed for a sustained current, but arcing is dangerous because it tends to cascade, light arcing damages contacts, leading to more arcing in a cycle. The real danger of arcing is that it can happen outside of view, and start fires that aren't caught till everything burns down.
    58 Aufrufe
    Forgive me for not explaining better. Here are the terms potentially needing explanation. Provisioning in this case is initial system setup, the kind of stuff you would do manually after a fresh install, but usually implies a regimented and repeatable process. Virtual Machine (VM) snapshots are like a save state in a game, and are often used to reset a virtual machine to a particular known-working condition. Preboot Execution Environment (PXE, aka ‘network boot’) is a network adapter feature that lets you boot a physical machine from a hosted network image rather than the usual installation on locally attached storage. It’s probably tucked away in your BIOS settings, but many computers have the feature since it’s a common requirement in commercial deployments. As with the VM snapshot described above, a PXE image is typically a known-working state that resets on each boot. Non-virtualized means not using hardware virtualization, and I meant specifically not running inside a virtual machine. Local-only means without a network or just not booting from a network-hosted image. Telemetry refers to data collecting functionality. Most software has it. Windows has a lot. Telemetry isn’t necessarily bad since it can, for example, help reveal and resolve bugs and usability problems, but it is easily (and has often been) abused by data-hungry corporations like MS, so disabling it is an advisable precaution. MS = Microsoft OSS = Open Source Software Group policies are administrative settings in Windows that control standards (for stuff like security, power management, licensing, file system and settings access, etc.) for user groups on a machine or network. Most users stick with the defaults but you can edit these yourself for a greater degree of control. Docker lets you run software inside “containers” to isolate them from the rest of the environment, exposing and/or virtualizing just the resources they need to run, and Compose is a related tool for defining one or more of these containers, how they interact, etc. To my knowledge there is no one-to-one equivalent for Windows. Obviously, many of these concepts relate to IT work, as are the use-cases I had in mind, but the software is simple enough for the average user if you just pick one of the premade playbooks. (The Atlas playbook is popular among gamers, for example.) Edit: added explanations for docker and telemetry
