I see a lot of those on trucks here in the south. Good for when you are towing shit so people can see around all your junk in the trailer.
Colorblind person here. If we're talking about limited visibility differentiation of front and back, the color of light is way less noticeable than whether we're looking at headlights or not (based on intensity). There would be no issue telling whether we're looking at a front brake light or a back brake light so long as the front brake light has headlights around it.
https://www.youtube.com/watch?v=U0YW7x9U5TQYeah my electric 208 is kinda like that (if I remember the video well, watched it a while ago) but since it's Europe there actually is a regulation about how much a car can decelerate before break lights come on, so instead of making the system turn the lights on they throttle how much it can decelerate for recharge and still makes you use the break to use full regen (and eventually the actual brakes, of course). So it's not a real "one pedal driving".
Edit for consistency
I think some cars also turn on the hazards automatically if you really hammer the breaks.
Okay Verstappen calm down there
There's this idea I've been considering for a long time.
Imagine putting a remote controlled firework smoke bomb under the tailpipe, hidden from sight. At best a really stinky one that smells like burned rubber or something.
When someone follows to closely, just fake an engine issue or something by activating the smoke bomb and fill their AC air intake with the smell of burned rubber for weeks. Just to teach them to not follow too closely again.
90% of the things that Japan introduced according to comment sections on the internet never happened (or never made it past the prototype stage) and the rest was actually introduced in Korea, not in Japan.
The Japanophilia is strong with a lot of people on the internet.
That could probably be implemented in most existing vehicles, and at least it would provide more information.
I suspect because there's no consistency in the brightness of vehicle lights. But that's one of the reasons why I think an incremental light bar would be better, there's no variation between vehicles. You could even make it more informative by flashing the whole bar when you first brake, so someone behind you can more easily see how much of the bar is being lit up.
I suspect a lot of that has to do with the entitled way people are driving these days. If you leave a car length gap, some kid will wrecklessly attempt to cram their way in because your lane momentarily moved slightly faster.
Does your state not require good lights on the trailers? I just built a new trailer last year, I was required to have full working brake and turn signals along with running lights, but I went the extra step and included more brake/turn lights on the front and rear of the fenders, along with reverse lights plus four marker lights along each side. Trailers are hard enough to see, I didn't want to make it harder for anyone by just sticking with the bare minimum.
Counterpoint: the dumb people could have them as well.
Every car needs proximity chat so traffic becomes like a COD lobby.
Now there's a Black Mirror episode with true horror!
Plenty of cars flash their brake lights when ABS(/ESP?) engages, which is reasonable and should be a legal requirement IMO.
There's lots of room to give additional info in between that and "brake light is on because the driver doesn't understand that they can do mild adjustments by letting off the gas / stupid bitch-ass VW PHEV computer thinks using cruise control downhill with electric regen requires the motherfucking brake lights". It's like no-one realizes or cares that brake lights lose all purpose if they're on when the car isn't meaningfully decelerating. ARGH.
There's a programmable flasher relay that does exactly this. It's specific to certain Toyota/Lexus and Subarus from the 2000s to mid-2010s, but it's something. I have one in my 2008 Sienna - the "emergency flasher" part is programmed to strobe, kinda like a tow truck. I like it.
probably because thats a terrible way to do it. It would be noticeable if a car started braking and then started braking much harder, but if they slam on the brakes you don't see anything change, just a normal brake light.
Seems much more complicated than having the brake lights rapidly flash during hard braking. But of course we couldn't do that in the US because our turn signals/hazard lights are red
Using your vehicle lights to see and be seen
About the new vehicle lighting standard for cars in 2021 and tips on how to use your lights safely now.
Transport Canada (tc.canada.ca)
II. - Le ou les feux arrière de brouillard ne peuvent être utilisés qu'en cas de brouillard ou de chute de neige. ☞ https://www.legifrance.gouv.fr/codes/article_lc/LEGIARTI000006842263
Feux de brouillard arrière : ils sont indiqués uniquement en cas de brouillard ou de chute de neige (mais jamais sous la pluie en raison de leur trop grande intensité) ☞ https://public.codesrousseau.fr/conseils-pratiques/909-feux-de-brouillard-avant-et-arriere-quand-les-utiliser.html
Know-How and Expertise: European Companies Hoping to Take the Global Lead in Industrial AI
Japan sets new internet speed world record — 4 million times faster than average US speeds
Experts warn mobile sports betting could be gateway to gambling crisis for young men in New York
