This is stupid
It is to colorblind people. You could use something else of course, just saying...
It's doesn't matter, since the absence or presence of light would still be perceived by colour blind people. It doesn't change how they would drive, as they are already driving with the knowledge of colour blindness in mind when looking at tail lights.
Theres a saying in computer stuff that applies nicely here. PEBKAC, problem exists between keyboard and computer...turn signals have to be turned on, no amount of engineering can fix bad driving.
it's forbidden to use rear fog lights under rain (it's more confusing than helpful)
if you live somewhere dry, that's not a concern. But here it rains 1 day in 3
Using your vehicle lights to see and be seen
About the new vehicle lighting standard for cars in 2021 and tips on how to use your lights safely now.
Transport Canada (tc.canada.ca)
Tail lights being red is fine if you live with the most common forms of colorblindness which fall into what we call “red-green colorblind.” It is still a different color than headlights.
Now put those same red-green lights on the front, and we have a problem.
By signaling to oncoming traffic and vehicles approaching from the side, a front brake light provides an essential visual cue that a car is slowing down or preparing to stop. When the light is extinguished, it indicates that a stationary vehicle might initiate movement. According to Tomasch, this visual feedback can significantly truncate the reaction time for other road users, leading to shorter stopping distances and consequently diminishing the likelihood of accidents.
Sounds reasonable. Personally I just want front turn signals to be visible from the opposite side again.
So it sounds like you're checking to see when the light turns off, to know that the car is going.
Sounds like what we actually need is a green accelerator light on the front of the car.
Not selling tanks as cars could also help. Especially with fatality rates
But why? Again, the perception would be absence or presence of light on a standardized indicator.
FYI signal lights are much more strictly regulated in Europe, such as position, colour, shape and strength.
This study is from Austria.
They could use traffic light green. There's not any problems identifying those even in places with the lights mounted horizontally. There's enough difference in saturation you can tell the difference even with colorblindness.
Cars with lane-keep assist with vibrate the steering wheel and beep at you. It's at least something but I think most people turn it off if it gets annoying
If anything I think they would have to use a green light that turns on when accelerating/not braking. It would be way more dangerous in the future when people are trained with "No green = braking" but older cars don't have the light at all.
It's important to consider how a transition like this would even work. I personally think this is a little too drastic of a change, and is incompatible with existing vehicles and habits. -
I don't think they illuminate the brake lights, hence my comment. Technology connections has talked about this, although IDK which video it was.
I was curious if anyone had actually tested it or not, and I found the video above where they get right into it, without any intros or family history or begging to like & subscribe... just a short video where they test it and find that, YES!, the brake lights do come on when you use the steering wheel paddle brake or when you're in L gear and take your foot off the accelerator.
The brakes aren’t engaged? The light turns on before there’s pressure on the brake. They probably don’t even know their lights are on since they aren’t decelerating.
Flashing blue would be neat.
Again, if you're too stupid to make sure the multiton hunk of metal is coming to a stop by all the other obvious visual markers, including watching it's speed compared to stationary objects like signs and lamp posts, then this won't do shit. People need more aweness of their surroundings, not a bunch of lights and horns because people won't pay attention.
You enter the road when it's safe, not jump in and play frogger with lights hoping to get across.
Yup, this is a moronic idea.
Germany's Federal Cartel Office warns Amazon that its marketplace retailer price controls likely violate national and EU laws, in its preliminary assessment
Rebecca Shaw: I knew one day I’d have to watch powerful men burn the world down. But I didn't expect them to be such losers.
