    It's got to be a lie
    1,000 charge cycles: OnePlus 13
    Hmm. This one has newer silicone-carbon lithium-ion batteries, which should actually increase charge cycles, so what's happening here?
  • 1,000 charge cycles: OnePlus 13
    Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
  • Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
    Xiaomi has faast charge, and it (33watt) has worked both fast and reliable on my 4-5 year old note 9 pro phone. I just changed to a 13tp with 120 watt, let's see how that pans out 🔥😋
    Yes, but...
    edit: clarity
  • Wow. This is excellent for Samsung users.
    Apparently not
    Yes, but...
    edit: clarity
  • 241 Stimmen
    77 Beiträge
    159 Aufrufe
    jacksonlamb@lemmy.worldJ
    bizarre, dismal What's bizarre and dismal is that someone is so starved for dopamine and attention from corporations that this is how they perceive what life looks like when you are not being targetted. This is my normal view and it is far better.
  • Tesla customers in France sue over brand becoming 'extreme right'
    508 Stimmen
    32 Beiträge
    49 Aufrufe
    P
    sorry I meant it in a joking way, I should have worded that better
  • An earnest question about the AI/LLM hate
    73 Stimmen
    57 Beiträge
    50 Aufrufe
    ineedmana@lemmy.worldI
    It might be interesting to cross-post this question to !fuck_ai@lemmy.world but brace for impact
  • 324 Stimmen
    18 Beiträge
    22 Aufrufe
    D
    Do you think a plumber dreams about being a plumber?
  • 61 Stimmen
    12 Beiträge
    19 Aufrufe
    merde@sh.itjust.worksM
    is the linked article or the title edited? This was a post about VA GPT
  • Digg founder Kevin Rose offers to buy Pocket from Mozilla
    15 Aufrufe
    H
    IMO it was already shitty.
  • 148 Stimmen
    9 Aufrufe
    Whenever these things come up you always hear "then the company won't survive!" CEO and managers make bank somehow but it doesn't matter that the workers can't live on that wage. It's always so weird how when workers actually take a pay cut, that the businesses get used to it. When the CEOs get bonuses they have to get used to that too.
  • CrowdStrike Announces Layoffs Affecting 500 Employees
    242 Stimmen
    17 Aufrufe
    This is where the magic of near meaningless corpo-babble comes in. The layoffs are part of a plan to aspirationally acheive the goal of $10b revenue by EoY 2025. What they are actually doing is a significant restructuring of the company, refocusing by outside hiring some amount of new people to lead or be a part of departments or positions that haven't existed before, or are being refocused to other priorities... ... But this process also involves laying off 500 of the 'least productive' or 'least mission critical' employees. So, technically, they can, and are, arguing that their new organizational paradigm will be so succesful that it actually will result in increased revenue, not just lower expenses. Generally corpos call this something like 'right-sizing' or 'refocusing' or something like that. ... But of course... anyone with any actual experience with working at a place that does this... will tell you roughly this is what happens: Turns out all those 'grunts' you let go of, well they actually do a lot more work in a bunch of weird, esoteric, bandaid solutions to keep everything going, than upper management was aware of... because middle management doesn't acknowledge or often even understand that that work was being done, because they are generally self-aggrandizing narcissist petty tyrants who spend more time in meetings fluffing themselves up than actually doing any useful management. Then, also, you are now bringing on new, outside people who look great on paper, to lead new or modified apartments... but they of course also do not have any institutional knowledge, as they are new. So now, you have a whole bunch of undocumented work that was being done, processes which were being followed... which is no longer being done, which is not documented.... and the new guys, even if they have the best intentions, now have to spend a quarter or two or three figuring out just exactly how much pre-existing middle management has been bullshitting about, figuring out just how much things do not actually function as they ssid it did... So now your efficiency improving restructuring is actually a chaotic mess. ... Now, this 'right sizing' is not always apocalyptically extremely bad, but it is also essentially never totally free from hiccups... and it increases stress, workload, and tensions between basically everyone at the company, to some extent. Here's Forbes explanation of this phenomenon, if you prefer an explanation of right sizing in corpospeak: https://www.forbes.com/advisor/business/rightsizing/
