Although, replacing the battery on the Fairphone is so much easier that 1000 cycles is acceptable.
Damn, yeah. My pixel will drain 50% or more in a day, in my pocket. Brutal
Sure but not everyone is tech savvy.
That’s rhe same with my iPhone 16, it just charges to 100 every so often
Can you follow a step-by-step guide?
Can you use a screwdriver to remove 5-10 identical screws?
Can you use spudgers of varying sizes?
Can you use a hair dryer?
Then you can change the battery on your Samsung phone.
I'm still on my pixel 3 with CalyxOS
About to upgrade but only because CalyxOS has stopped supporting the 3 after all these years.
But non-tech people aren't buying Faiphones, but whatever they're pushing at the Verizon store.
I had a Fold 3, and while I loved the form factor, the battery was shit.
The screen got broken, and I decided to upgrade to a Fold 6 so far I'm very impressed. I took it off the charger in my car at 100% on Wednesday night around 10pm, and put it back on the charger at 11:30pm Friday with 15% left.
48 hours with moderate usage (including some gaming and YouTube) is pretty good.
I guess the answer to at least one of those is no. Last time I tried a battery replacement, I broke the screen either during assembly or disassembly. I build my own desktop PCs, and have fixed laptop monitors and drives, but every time I attempt hardware repair on something phone-ish, I make it worse (even going back to when I owned an OpenMoko).
You haven't had to touch the screen on a Samsung phone since like the S6, every model after that opens from the back.
try a magnetic charger. it may look a bit off leaving the usb-c part plugged into the phone, but there's way less wear or lint
it's well worth it and quite easy with the WebUSB installer
The Pixel line is comparable to the Samsung S line, you got a budget phone before
Or wireless, I've used both for years
