around 38C
It's rare for me to get that low, even while charging to 80%.
I do like the trend chart, although, the battery health on that actually went UP 5% between March and May
I don't see that menu option. I do see Settings -> Battery but it does not count cycles.
Pixel 4a Android 14
Article 5
Article 6
They also say this:
So I remain hopeful.
I'm on pixel 6a. There is no battery info there
Although, replacing the battery on the Fairphone is so much easier that 1000 cycles is acceptable.
Engineers Introduce Berkeley Humanoid Lite, Open-Source, Customizable, 3D-Printed Robot for Tech Newbies.
AI learns math reasoning by playing Snake and Tetris-like games rather than using math datasets
Reddit sues Anthropic, alleging its bots accessed Reddit more than 100,000 times since last July
Why does digital violence against LGBTI people in Thailand and Taiwan continue even after marriage equality?
