Article 5
Article 6
Where can you see charge cycles?
Yeah I've got a P7 Pro and the battery is still fine. Adaptive charging enabled to help batter life.
around 38C
around 38C
It's rare for me to get that low, even while charging to 80%.
I do like the trend chart, although, the battery health on that actually went UP 5% between March and May
I don't see that menu option. I do see Settings -> Battery but it does not count cycles.
Pixel 4a Android 14
Article 5
Article 6
They also say this:
So I remain hopeful.
