  • Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
    Yes, but...
    edit: clarity
  • Wow. This is excellent for Samsung users.
    Apparently not
    Yes, but...
    edit: clarity
  • How so?
    Is piefed an instance?
  • Is piefed an instance?
  • How so?
  • Apparently not
    Article 5
    Article 6
