Isn't one plus one of the brands that has their own fast charging tech, that's extra fast?
Yes, but...
edit: clarity
Apparently not
Yes, but...
edit: clarity
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones. -
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones.When you do the initial setup it asks if you'd like to optimize for battery health and most people say yes. Most recently it wouldn't even tell you that it was only charging to 80%.It would still charge to a hundred but that would actually be eighty percent. Around a year ago they changed it so now it says eighty percent when you're at full charge if you have the battery health turned on.
Is piefed an instance?
With heavy usage all my Samsung phones barely made it through a full day. I've never considered throttling the battery for the sake of longevity or been encouraged to by my phones.It's all up to where you live and how you use the phone.
Meta said it supports proposals for an EU-wide age of digital adulthood, below which minors would need parental consent to use social media
eSafety boss wants YouTube included in the social media ban. But AI raises even more concerns for kids
Rebecca Shaw: I knew one day I’d have to watch powerful men burn the world down. But I didn't expect them to be such losers.
