Jobs figured everything out a long time ago. Why are you desecrating his memory?
What are you talking about? The article doesn't mention him.
Figured what out?
Doctors are using unapproved AI software to record patient meetings, investigation reveals
Millions of Americans Who Have Waited Decades for Fast Internet Connections Will Keep Waiting After the Trump Administration Threw a $42 Billion High-Speed Internet Program Into Disarray.
Why does digital violence against LGBTI people in Thailand and Taiwan continue even after marriage equality?
