Ive not heard of this - were you on the standard Google OS? I wonder if that makes any difference.
I've been on custom ROM (CalyxOS) for most of the phone's life.
Same, got mine in early 2020 and the battery is still at 87% capacity.
Jobs figured everything out a long time ago. Why are you desecrating his memory?
Figured what out?
finally some good news for us Samsung victims/owners.
What are you talking about? The article doesn't mention him.
Figured what out?
