    There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Telegram, I think, Atleast in my country is the second most popular thing behind WhatsApp but in it's default state, it's less secure and one needs to enable e2e encryption(read : secret chats).
    I am willing to move to almost any service ( I mean, I still use IRC, so..) but the main point is would anyone I know be on them? I once gave Signal a try but quickly wound uninstalling it because there was no one I knew there.
    I dislike WhatsApp as well (it's desktop variant is so slow and takes such a long time to sync messages plus Telegram has better inline support for images for example compared to Meta's version). It doesn't help that it's status page also promotes useless channels and that it is a hub of misinformation.
    After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    It's still an American company, so it's not ideal. But it's still significantly better better than letting a tech giant like Facebook have control over the most commonly used chat app.
    WhatsApp needs to go and Signal is the most likely way in which we can achieve that. We can worry about the American elephant in the room later.
    It's ethical because it runs on donations and has a non-profit business model.
    Meta likely spends at least $1 billion a year running WhatsApp.
    Please donate to Signal if you use it.
  • There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Signal used to be the best answer to this conundrum, since it would use its own internal protocols if it could or fall back to SMS if it couldn't, unfortunately they decided to drop SMS support a few years ago, citing users that sent sensitive information not realizing they were using SMS (that always felt kinda flimsy). I really disliked this change, because it raised the difficulty of adoption, from just getting people to replace their default app with Signal to making them manage multiple apps.
    Now though, you basically need to advocate socially for the change you want to see in the world. Anecdotally, I started using Signal when they still supported SMS to talk with 1 friend group, and eventually convinced most of my closest family groups to also use it, many after SMS support was dropped. Apart from 1 tech illiterate elderly couple and 1 extended family member, I haven't received any personal (non-company related) text messages in like 5 months.
  • Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    The problem is that it was easier to get people to move to Telegram since it had an abundance of features compared to WhatsApp which was compelling for the average person that doesn't care about encryption. Signal doesn't have any of these features that make it enticing for the person.
  • After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    Sadly many still don't want to switch. My most active chats are in signal now but the large majority of chats are still on whatsapp
    For now anyways lol
  • If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Quickly as in I had it for multiple months. Just like I did with Threema and Briar and XMPP apps and what not. Nobody ever showed up. There was a time when I was carrying more chat apps than folks I used to chat with
    There is technically one phonebook contact of mine on Signal but he primarily uses Telegram as primary chat thingy.
    It then occurred to me that IRL most folks don't care about chat apps. They care about chatting. The most I have seen folks are on Whatsapp, Telegram and Snapchat (last of which is really bad).
    Edit: there was/is Session as well. It started as a fork of Signal before moving to its own standard. It doesn't require even a phone number for verification. I think I once installed it for talking to a random stranger on the internet.
    There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    Unfortunately the source code is not open (even though they do get annual audits with public reports), and the client costs 3 EUR or something (once).
  • There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    They also offer Threema Libre on F-Droid for all us folks who degoogled their phone
    How about matrix?
    Yeah, but Threema has basically no momentum behind it at all at this point.
    I'm putting my social capital behind the option that currently stands the most chance of beating out Whatsapp
  • For now anyways lol
    What does this mean
  • How about matrix?
  • Yeah, but Threema has basically no momentum behind it at all at this point.
    Threema has a pretty big momentum in some countries.
    A few friends of mine use Threema, because they care about privacy and are more than happy to pay to have it. Signal comes third, behind Telegram, even.
    And Switzerlands records in terms of privacy sadly is far worse than most people think - even with the last attack being repelled.
    Matrix (preferably on a non-matrix.org instance) currently is the preferable non US and privacy friendly way.
  • It is OutfinityGift project better then all NFTs?
  • The Trump Mobile T1 Phone looks both bad and impossible
    140 Stimmen
    42 Beiträge
    4 Aufrufe
    "Components" means in this case the phone and the sticker.
  • Founder of 23andMe buys back company out of bankruptcy auction
    350 Stimmen
    60 Beiträge
    Come on up to Canada, we still got that garlic bomb. I can still taste the one from last week
  • 149 Stimmen
    33 Beiträge
    13 Aufrufe
    B
    That’s not the right analogy here. The better analogy would be something like: Your scary mafia-related neighbor shows up with a document saying your house belongs to his land. You said no way, you have connections with someone important that assured you your house is yours only and they’ll help you with another mafia if they want to invade your house. The whole neighborhood gets scared of an upcoming bloodbath that might drag everyone into it. But now your son says he actually agrees that your house belongs to your neighbor, and he’s likely waiting until you’re old enough to possibly give it up to him.
  • AI model collapse is not what we paid for
    84 Stimmen
    20 Beiträge
    5 Aufrufe
    I share your frustration. I went nuts about this the other day. It was in the context of searching on a discord server, rather than Google, but it was so aggravating because of the how the "I know better than you" is everywhere nowadays in tech. The discord server was a reading group, and I was searching for discussion regarding a recent book they'd studied, by someone named "Copi". At first, I didn't use quotation marks, and I found my results were swamped with messages that included the word "copy". At this point I was fairly chill and just added quotation marks to my query to emphasise that it definitely was "Copi" I wanted. I still was swamped with messages with "copy", and it drove me mad because there is literally no way to say "fucking use the terms I give you and not the ones you think I want". The software example you give is a great example of when it would be real great to be able to have this ability. TL;DR: Solidarity in rage
  • The silent force behind online echo chambers? Your Google search
    171 Stimmen
    21 Beiträge
    11 Aufrufe
    silentknightowl@slrpnk.netS
    Same on all counts.
  • How the Signal Knockoff App TeleMessage Got Hacked in 20 Minutes
    188 Stimmen
    31 Beiträge
    9 Aufrufe
    P
    Not to mention TeleMessage violated the terms of the GPL. Signal is under gpl and I can't find TeleMessage's code anywhere. Edit: it appears it is online somewhere just not in a github repo or anything https://micahflee.com/heres-the-source-code-for-the-unofficial-signal-app-used-by-trump-officials/
  • 4 Stimmen
    3 Aufrufe
    Epic is a piece of shit company. The only reason they are fighting this fight with Apple is because they want some of Apple’s platform fees for themselves. Period. The fact that they managed to convince a bunch of simpletons that they are somehow Robin Hood coming to free them from the tyrant (who was actually protecting all those users all along) is laughable. Apple created the platform, Apple managed it, curated it, and controlled it. That gives them the right to profit from it. You might dislike that but — guess what? Nobody forced you to buy it. Buy Android if Fortnight is so important to you. Seriously. Please. We won’t miss you. Epic thinks they have a right to profit from Apple’s platform and not pay them for all the work they did to get it to be over 1 billion users. That is simply wrong. They should build their own platform and their own App Store and convince 1 billion people to use it. The reason they aren’t doing that is because they know they will never be as successful as Apple has been.
