235 140 5.3k
    There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Telegram, I think, Atleast in my country is the second most popular thing behind WhatsApp but in it's default state, it's less secure and one needs to enable e2e encryption(read : secret chats).
    I am willing to move to almost any service ( I mean, I still use IRC, so..) but the main point is would anyone I know be on them? I once gave Signal a try but quickly wound uninstalling it because there was no one I knew there.
    I dislike WhatsApp as well (it's desktop variant is so slow and takes such a long time to sync messages plus Telegram has better inline support for images for example compared to Meta's version). It doesn't help that it's status page also promotes useless channels and that it is a hub of misinformation.
    After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    It's still an American company, so it's not ideal. But it's still significantly better better than letting a tech giant like Facebook have control over the most commonly used chat app.
    WhatsApp needs to go and Signal is the most likely way in which we can achieve that. We can worry about the American elephant in the room later.
    It's ethical because it runs on donations and has a non-profit business model.
    Meta likely spends at least $1 billion a year running WhatsApp.
    Please donate to Signal if you use it.
  • There are many such apps. The page links to EFF one which ranked some messaging apps and included stuff like Threema (though good luck getting anyone to use it because it's a paid version). Then, there is Briar, available on F Droid as well, which runs on a decentralised model but I don't think I know anyone IRL who has even heard of it.
    Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Signal used to be the best answer to this conundrum, since it would use its own internal protocols if it could or fall back to SMS if it couldn't, unfortunately they decided to drop SMS support a few years ago, citing users that sent sensitive information not realizing they were using SMS (that always felt kinda flimsy). I really disliked this change, because it raised the difficulty of adoption, from just getting people to replace their default app with Signal to making them manage multiple apps.
    Now though, you basically need to advocate socially for the change you want to see in the world. Anecdotally, I started using Signal when they still supported SMS to talk with 1 friend group, and eventually convinced most of my closest family groups to also use it, many after SMS support was dropped. Apart from 1 tech illiterate elderly couple and 1 extended family member, I haven't received any personal (non-company related) text messages in like 5 months.
  • Signal has been a good option because you can get "normal" people to use it, which hasn't been true for many of the alternatives (except Telegram, but that's a mess).
    The problem is that it was easier to get people to move to Telegram since it had an abundance of features compared to WhatsApp which was compelling for the average person that doesn't care about encryption. Signal doesn't have any of these features that make it enticing for the person.
  • After Trump was elected and inaugurated, Signal has finally been gaining some steam here in the Netherlands.
    Sadly many still don't want to switch. My most active chats are in signal now but the large majority of chats are still on whatsapp
    For now anyways lol
  • If you quickly uninstall it because you don’t know anyone using it it sounds like you’re part of the problem. If someone you know installs it to try it out that’s one less person they see as well. Personally I got the vast majority of my friend group to move to it years ago by just saying like “hey Facebook sucks we should move to signal”. If you don’t want to do that should at least leave it installed it’s not like it’s taking up much space
    Quickly as in I had it for multiple months. Just like I did with Threema and Briar and XMPP apps and what not. Nobody ever showed up. There was a time when I was carrying more chat apps than folks I used to chat with
    There is technically one phonebook contact of mine on Signal but he primarily uses Telegram as primary chat thingy.
    It then occurred to me that IRL most folks don't care about chat apps. They care about chatting. The most I have seen folks are on Whatsapp, Telegram and Snapchat (last of which is really bad).
    Edit: there was/is Session as well. It started as a fork of Signal before moving to its own standard. It doesn't require even a phone number for verification. I think I once installed it for talking to a random stranger on the internet.
    There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    Unfortunately the source code is not open (even though they do get annual audits with public reports), and the client costs 3 EUR or something (once).
  • There is threema, a Swiss messenger that gained some popularity earlier since they had end to end encryption before whatsapp.
    They also offer Threema Libre on F-Droid for all us folks who degoogled their phone
    How about matrix?
    Yeah, but Threema has basically no momentum behind it at all at this point.
    I'm putting my social capital behind the option that currently stands the most chance of beating out Whatsapp
  • For now anyways lol
    What does this mean
  • How about matrix?
  • Yeah, but Threema has basically no momentum behind it at all at this point.
    Threema has a pretty big momentum in some countries.
    A few friends of mine use Threema, because they care about privacy and are more than happy to pay to have it. Signal comes third, behind Telegram, even.
    And Switzerlands records in terms of privacy sadly is far worse than most people think - even with the last attack being repelled.
    Matrix (preferably on a non-matrix.org instance) currently is the preferable non US and privacy friendly way.
  • Bluesky is rolling out age verification in the UK
    165 Stimmen
    40 Beiträge
    596 Aufrufe
    3dcadmin@lemmy.relayeasy.com3
    you know that the new online safety act mandates age verification for pretty much anything don't you?
  • Why This Python Performance Trick Doesn’t Matter Anymore
    68 Stimmen
    56 Aufrufe
    I'm surprised about the module lookup thing, since I assumed it was just syntax sugar to do from ... import .... We do the from syntax almost everywhere, but I've been replacing huge import blocks with a module import (e.g. constants) just to clean up the imports a bit and git conflicts. Looks like I'll need to keep this in mind until we upgrade to 3.13.
    16 Aufrufe
  • Uber, Lyft oppose some bills that aim to prevent assaults during rides
    94 Stimmen
    12 Beiträge
    125 Aufrufe
    F
    California is not Colorado nor is it federal No shit, did you even read my comment? Regulations already exist in every state that ride share companies operate in, including any state where taxis operate. People are already not supposed to sexually assault their passengers. Will adding another regulation saying they shouldn’t do that, even when one already exists, suddenly stop it from happening? No. Have you even looked at the regulations in Colorado for ride share drivers and companies? I’m guessing not. Here are the ones that were made in 2014: https://law.justia.com/codes/colorado/2021/title-40/article-10-1/part-6/section-40-10-1-605/#%3A~%3Atext=§+40-10.1-605.+Operational+Requirements+A+driver+shall+not%2Ca+ride%2C+otherwise+known+as+a+“street+hail”. Here’s just one little but relevant section: Before a person is permitted to act as a driver through use of a transportation network company's digital network, the person shall: Obtain a criminal history record check pursuant to the procedures set forth in section 40-10.1-110 as supplemented by the commission's rules promulgated under section 40-10.1-110 or through a privately administered national criminal history record check, including the national sex offender database; and If a privately administered national criminal history record check is used, provide a copy of the criminal history record check to the transportation network company. A driver shall obtain a criminal history record check in accordance with subparagraph (I) of paragraph (a) of this subsection (3) every five years while serving as a driver. A person who has been convicted of or pled guilty or nolo contendere to driving under the influence of drugs or alcohol in the previous seven years before applying to become a driver shall not serve as a driver. If the criminal history record check reveals that the person has ever been convicted of or pled guilty or nolo contendere to any of the following felony offenses, the person shall not serve as a driver: (c) (I) A person who has been convicted of or pled guilty or nolo contendere to driving under the influence of drugs or alcohol in the previous seven years before applying to become a driver shall not serve as a driver. If the criminal history record check reveals that the person has ever been convicted of or pled guilty or nolo contendere to any of the following felony offenses, the person shall not serve as a driver: An offense involving fraud, as described in article 5 of title 18, C.R.S.; An offense involving unlawful sexual behavior, as defined in section 16-22-102 (9), C.R.S.; An offense against property, as described in article 4 of title 18, C.R.S.; or A crime of violence, as described in section 18-1.3-406, C.R.S. A person who has been convicted of a comparable offense to the offenses listed in subparagraph (I) of this paragraph (c) in another state or in the United States shall not serve as a driver. A transportation network company or a third party shall retain true and accurate results of the criminal history record check for each driver that provides services for the transportation network company for at least five years after the criminal history record check was conducted. A person who has, within the immediately preceding five years, been convicted of or pled guilty or nolo contendere to a felony shall not serve as a driver. Before permitting an individual to act as a driver on its digital network, a transportation network company shall obtain and review a driving history research report for the individual. An individual with the following moving violations shall not serve as a driver: More than three moving violations in the three-year period preceding the individual's application to serve as a driver; or A major moving violation in the three-year period preceding the individual's application to serve as a driver, whether committed in this state, another state, or the United States, including vehicular eluding, as described in section 18-9-116.5, C.R.S., reckless driving, as described in section 42-4-1401, C.R.S., and driving under restraint, as described in section 42-2-138, C.R.S. A transportation network company or a third party shall retain true and accurate results of the driving history research report for each driver that provides services for the transportation network company for at least three years. So all sorts of criminal history, driving record, etc checks have been required since 2014. Colorado were actually the first state in the USA to implement rules like this for ride share companies lol.
  • life trip
    13 Aufrufe
  • 106 Stimmen
    25 Beiträge
    367 Aufrufe
    tryenjer@lemmy.worldT
    In short, we will need an open-source alternative to these implants, of course.
  • What was Radiant AI, anyway?
    20 Stimmen
    70 Aufrufe
    In fact Daggerfall was almost nothing but quests and other content like that.
  • 3 Stimmen
    19 Beiträge
    174 Aufrufe
    Are most people in "the west" worse off today than they were 150 years ago? Are there fewer well functioning democracies than there were then? Has no minority group seen any improvement in their freedom? Has there been no improvement in how people interact with each other? No improvement in poverty?
