235 140 1.2k
  • Authors petition publishers to curtail their use of AI
    74 Stimmen
    23 Aufrufe
    I’m sure publishers are all ears /s
  • Apple sued by shareholders for allegedly overstating AI progress
    500 Stimmen
    75 Beiträge
    394 Aufrufe
    finishingdutch@lemmy.worldF
    For this comment, I want to be absolutely clear that I do not give a shit about AI, and that it in no way factored into my decision to buy this iPhone 16 Pro Max. With that disclaimer out of the way: I very much look forward to a class action lawsuit. Apple advertised specific features as coming ‘very soon’ and gave short timeframes when asked directly. And they basically did not deliver on those advertising promises. Basically, I think there’s a good case to be made here that Apple knowingly engaged in false advertising in order to sell a phone that otherwise would not have sold as well. Those promised AI features WERE a deciding factor for a lot of people to upgrade to an iPhone 16. So, I’ll be looking forward to some form of compensation. It’s the principle of it.
  • 311 Stimmen
    37 Beiträge
    166 Aufrufe
    Same, especially when searching technical or niche topics. Since there aren't a ton of results specific to the topic, mostly semi-related results will appear in the first page or two of a regular (non-Gemini) Google search, just due to the higher popularity of those webpages compared to the relevant webpages. Even the relevant webpages will have lots of non-relevant or semi-relevant information surrounding the answer I'm looking for. I don't know enough about it to be sure, but Gemini is probably just scraping a handful of websites on the first page, and since most of those are only semi-related, the resulting summary is a classic example of garbage in, garbage out. I also think there's probably something in the code that looks for information that is shared across multiple sources and prioritizing that over something that's only on one particular page (possibly the sole result with the information you need). Then, it phrases the summary as a direct answer to your query, misrepresenting the actual information on the pages they scraped. At least Gemini gives sources, I guess. The thing that gets on my nerves the most is how often I see people quote the summary as proof of something without checking the sources. It was bad before the rollout of Gemini, but at least back then Google was mostly scraping text and presenting it with little modification, along with a direct link to the webpage. Now, it's an LLM generating text phrased as a direct answer to a question (that was also AI-generated from your search query) using AI-summarized data points scraped from multiple webpages. It's obfuscating the source material further, but I also can't help but feel like it exposes a little of the behind-the-scenes fuckery Google has been doing for years before Gemini. How it bastardizes your query by interpreting it into a question, and then prioritizes homogeneous results that agree on the "answer" to your "question". For years they've been doing this to a certain extent, they just didn't share how they interpreted your query.
  • 403 Stimmen
    143 Beiträge
    323 Aufrufe
    If anyone ever tells you they can't hire enough of blank they are lying to you. People have been running excellent 911 service all over the country for longer than I've been alive maybe they should ask someone?
  • 44 Stimmen
    9 Beiträge
    54 Aufrufe
    This will be a privacy nightmare.
  • 85 Stimmen
    12 Beiträge
    63 Aufrufe
    cupcakezealot@lemmy.blahaj.zoneC
    i like how ask photos is not just a dumb idea but it's also a dumb name
    15 Beiträge
    76 Aufrufe
    G
    I’m in the EU and PII definitely IS “a thing” here, Then let me be more clear: It is not a thing in EU law. With due respect, the level of intellectual functioning, in this case reading comprehension, you display is incompatible with being an IT professional in any country. If you are not trolling, then you should consult a physician.
    22 Aufrufe
    B
    ... robo chomo?
