A fake Facebook event disguised as a math problem has been one of its top posts for 6 months
  • "Hey, this is Presh Talwalkar.
    Discussion of a brief history of this viral math problem, followed by explanations of common incorrect answers. Ultimately followed by brief discussion on the order of operations, concluding in a final example that equals 11
    And that's the answer. Thank you so much for making us one of the best communities on YouTube, where we solve the world's problems, one video at a time."
    Person who has forgotten about The Distributive Law and lied about 1917.
    Including lying about 1917
    But forgets about Terms and The Distributive Law.
    And that’s the answer
    Now watch his other ones, where he screws it up royally. Dude has no idea how to handle brackets. Should be avoided at all costs.
  • So order of operations is hard?
    Not for students it isn't. Adults who've forgotten the rules on the other hand...
  • The issue normally with these "trick" questions is the ambiguous nature of that division sign (not so much a problem here) or people not knowing to just go left to right when all operators are of the same priority. A common mistake is to think division is prioritised above multiplication, when it actually has the same priority. Someone should have included some parenthesis in PEDMAS aka. PE(DM)(AS) 😄
    The issue normally with these “trick” questions
    There's no "trick" - it's a straight-out test of Maths knowledge.
    Nothing ambiguous about it. The Term of the left divided by the Term on the right.
    It's not a mistake. You can do them in any order you want.
    Which means you can do them in any order
  • So let's try out some different prioritization systems.
    Left to right:
    (((6 * 4) / 2) * 3) / 9
    ((24 / 2) * 3) / 9
    (12 * 3) / 9
    36 / 9 = 4
    Right to left:
    6 * (4 / (2 * (3 / 9)))
    6 * (4 / (2 * 0.333...))
    6 * (4 / 0.666...)
    6 * 6 = 36
    Multiplication first:
    (6 * 4) / (2 * 3) / 9
    24 / 6 / 9
    Here the path divides again, we can do the left division or right division first.
    Left first:
    (24 / 6) / 9
    4 / 9 = 0.444...
    Right side first:
    24 / (6 / 9)
    24 / 0.666... = 36
    And finally division first:
    6 * (4 / 2) * (3 / 9)
    6 * 2 * 0.333...
    12 * 0.333.. = 4
    It's ambiguous which one of these is correct. Hence the best method we have for "correct" is left to right.
    Right to left:
    Nope! 6 × 4 ÷ 2 × 3 ÷ 9 =4 right to left is 6 ÷ 9 x 3 ÷ 2 × 4 =4. You disobeyed the rule of Left Associativity, and your answer is wrong
    Multiplication first: (6 * 4) / (2 * 3) / 9
    Also nope. Multiplication first is 6 x 4 x 3 ÷ 2 ÷ 9 =4
    Left first: (24 / 6) / 9
    Still nope. 6 × 4 x 3 ÷ 2 ÷ 9 =4
    Right side first: 24 / (6 / 9)
    Still nope. 6 × 4 x 3 ÷ 9 ÷ 2 =4
    And finally division first: 6 * (4 / 2) * (3 / 9)
    And finally still nope. 6 ÷ 9 ÷ 2 x 4 x 3 =4
    Hint: note that I never once added any brackets. You did, hence your multiple wrong answers.
    It’s ambiguous which one of these is correct
    No it isn't. Only 4 is correct, as I have just shown repeatedly.
    Hence the best method we have for “correct” is left to right
    It's because students don't make mistakes with signs if you don't change the order. I just showed you can still get the correct answer with different orders, but you have to make sure you obey Left Associativity at every step.
  • I stand corrected
    I stand corrected
    No, you weren't. Most of their answers were wrong. You were right. See my reply. 4 is the only correct answer, and if you don't get 4 then you did something wrong, as they did repeatedly (kept adding brackets and thus changing the Associativity).
  • Maybe I'm wrong but the way I explain it is until the ambiguity is removed by adding in extra information to make it more specific then all those answers are correct.
    "I saw her duck"
    Until the author gives me clarity then that sentence has multiple meanings. With math, it doesn't click for people that the equation is incomplete. In an English sentence, ambiguity makes more sense and the common sense approach would be to clarify what the meaning is
    There isn't any ambiguity.
    No, only 1 answer is correct, and all the others are wrong.
    Maths isn't English and doesn't have multiple meanings. It has rules. Obey the rules and you always get the right answer.
    it doesn’t click for people that the equation is incomplete.
    It isn't incomplete.
  • 100% with you. "Left to right" as far as I can tell only exists to make otherwise "unsolvable" problems a kind of official solution. I personally feel like it is a bodge, and I would rather the correct solution for such a problem to be undefined.
    100% with you. “Left to right” as far as I can tell only exists to make otherwise “unsolvable” problems a kind of official solution
    It's not a rule, it's a convention, and it exists so as to avoid making mistakes with signs, mistakes you made in almost every example you gave where you disobeyed left to right.
  • It's so we don't have to spam brackets everywhere
    9+2-1+6-4+7-3+5=
    Becomes
    ((((((9+2)-1)+6)-4)+7)-3)+5=
    That's just clutter for no good reason when we can just say if it doesn't have parentheses it's left to right. Having a default evaluation order makes sense and means we only need parentheses when we want to deviate from the norm.
    It’s so we don’t have to spam brackets everywhere
    No it isn't. The order of operations rules were around for several centuries before we even started using Brackets in Maths.
    It was literally never written like that
    That has always been the case
  • It’s ambiguous which one of these is correct. Hence the best method we have for “correct” is left to right.
    The solution accepted anywhere but in the US school system range from "Bloody use parenthesis, then" over "Why is there more than one division in this formula why didn't you re-arrange everything to be less confusing" to "50 Hertz, in base units, are 50s^-1^".
    More practically speaking: Ultimately, you'll want to do algebra with these things. If you rely on "left to right" type of precedence rules re-arranging formulas becomes way harder because now you have to contend with that kind of implicit constraint. It makes everything harder for no reason whatsoever so no actual mathematician, or other people using maths in earnest, use that kind of notation.
    The solution accepted anywhere but in the US school system range from “Bloody use parenthesis, then” over “Why is there more than one division in this formula why didn’t you re-arrange everything to be less confusing” to “50 Hertz, in base units, are 50s-1”.
    No, the solution is learn the rules of Maths. You can find them in Maths textbooks, even in U.S. Maths textbooks.
    Yes we do, and it's what we teach students to do.
  • Another person already replied using your equation, but I felt the need to reply with a simpler one as well that shows it:
    9-1+3=?
    Subtraction first:
    8+3=11
    Addition first:
    9-4=5
    Addition first:
    9-4=5
    Nope. Addition first is 9+3-1=12-1=11. You did 9-(1+3), incorrectly adding brackets and changing the answer (thus a wrong answer)
  • Except it does matter. I left some examples for another post with multiplication and division, I'll give you some addition and subtraction to see order matter with those operations as well.
    Let's take:
    1 + 2 - 3 + 4
    Addition first:
    (1 + 2) - (3 + 4)
    3 - 7 = -4
    Subtraction first:
    1 + (2 - 3) + 4
    1 + (-1) + 4 = 4
    Right to left:
    1 + (2 - (3 + 4))
    1 + (2 - 7)
    1 + (-5) = -4
    Left to right:
    ((1 + 2) - 3) + 4
    (3 - 3) + 4 = 4
    Edit:
    You can argue that, for example, the addition first could be (1 + 2) + (-3 + 4) in which case it does end up as 4, but in my opinion that's another ambiguous case.
    No it doesn't. You disobeying the rules and getting lots of wrong answers in your examples doesn't change that.
    Which you did wrong.
    I’ll give you some addition and subtraction to see order matter with those operations as well
    And I'll show you it doesn't matter when you do it correctly
    Subtraction first:
    1 + (2 - 3) + 4
    1 + (-1) + 4 = 4
    Nope. Right answer for wrong reason - you only co-incidentally got the answer right. -3+1+2+4=-3+7=4
    Right to left:
    1 + (2 - (3 + 4))
    1 + (2 - 7)
    1 + (-5) = -4
    Nope. 4-3+2+1=1+2+1=3+1=4
    Edit: You can argue that, for example, the addition first could be (1 + 2) + (-3 + 4)
    Or you could just do it correctly in the first place, always obeying Left Associativity and never adding Brackets
    in my opinion that’s another ambiguous case
    There aren't ANY ambiguous cases. In every case it's equal to 4. If you didn't get 4, then you made a mistake and got a wrong answer.
  • Oh, but of course the statement changes if you add parentheses. Basically, you’re changing the effective numbers that are being used, because the parentheses act as containers with a given value (you even showed the effective numbers in your examples).
    Get this : + 1 - 1 + 1 - 1 + 1 - 1 + 1
    You can change the result several times by choosing where you want to put the parentheses. However, the order of operations of same priority inside a container (parentheses) does not change the resulting value of the container.
    In the example, there were no parentheses, so no ambiguity (there wouldn’t be any ambiguity with parentheses either, the correct way of calculating would just change), and I don’t think you can add “ambiguity” by adding parentheses — you’re just changing the effective expression to be evaluated.
    By the way, this is the reason why I absolutely overuse parentheses in my engineering code. It can be redundant, but at least I am SURE that it is going to follow the order that I wanted.
    It sure does, but they don't seem to understand that.
  • Another common issue is thinking "parentheses go first" and then beginning by solving the operation beside them (mostly multiplication). The point being that what's inside the parentheses goes first, not what's beside them.
    Another common issue is thinking “parentheses go first”
    There's no "think" - it's an absolute rule.
    a(b) isn't an operation - it's a Product. a(b)=(axb) per The Distributive Law.
    NOT Multiplication, a Product/Term.
    The point being that what’s inside the parentheses goes first, not what’s beside them
    Nope, it's the WHOLE Bracketed Term. a/bxc=ac/b, but a/b( c )=a/(bxc). Inside is only a "rule" in Elementary School, when there isn't ANYTHING next to them (students aren't taught this until High School, in Algebra), and it's not even really a rule then, it's just that there isn't anything ELSE involved in the Brackets step than what is inside (since they're never given anything on the outside).
  • ÷ could be a minus sign
    No it couldn't.
    Did you check the reference? It says % can be used as a minus sign, not the obelus. Welcome to what happens when you're next-door neighbour Joe Blow can edit Wikipedia.
  • Yes, it is. The division of a by b in the set of real numbers and the set of rational numbers (which are, de facto, the default sets used in most professions) is defined as the multiplication of a by the multiplicative inverse of b. Alternative definitions are also based on a multiplication.
    That's why divisions are called an auxilliary operation.
    Yes, it is
    No it isn't.
    No it isn't. The Quotient is defined as the number obtained when you divide the Dividend by the Divisor. Here it is straight out of Euler...
    Emphasis on "alternative", not actual.
  • Hey, this is Presh Talwalkar
    I've seen many of his videos and haven't noticed any obvious errors. Could you please link to the specific video(s) that you are referencing in regards to errors he has made, especially those related to the distributive law and what you reference to as "1917," as well as any explanation as to what is incorrect/misleading/lying?
  • Yes, it is
    No it isn't.
    No it isn't.
    Yes, it is.
    I'm defining the division operation, not the quotient. Yes, the quotient is obtained by dividing... Now define dividing.
    The actual is the one I gave. I did not give the alternative definitions. That's why I said they are also defined based on a multiplication, implying the non-alternative one (understand, the actual one) was the one I gave.
    Feel free to send your entire Euler document rather than screenshotting the one part you thought makes you right.
    Note, by the way, that Euler isn't the only mathematician who contributed to the modern definitions in algebra and arithmetics.
  • No it isn't.
    Yes, it is.
    I’m defining the division operation, not the quotient
    Yep, the quotient is the result of Division. It's right there in the definition in Euler. Dividend / Divisor = Quotient <= no reference to multiplication anywhere
    Yes, the quotient is obtained by dividing… Now define dividing.
    You not able to read the direct quote from Euler defining Division? Doesn't mention Multiplication at all.
    No, you gave an alternative (and also you gave no citation for it anyway - just something you made up by the look of it). The actual definition is in Euler.
    That’s why I said they are also defined based on a multiplication
    Again, emphasis on "alternative", not actual.
    The one you gave bears no resemblance at all to what is in Euler, nor was given with a citation.
    The name of the PDF is in the top-left. Not too observant I see
    That's the one and only actual definition of Division. Not sure what you think is in the rest of the book, but he doesn't spend the whole time talking about Division, but feel free to go ahead and download the whole thing and read it from cover to cover to be sure! 😂
    Note, by the way, that Euler isn’t the only mathematician who contributed to the modern definitions in algebra and arithmetics.
    And none of the definitions you have given have come from a Mathematician. Saying "most professions", and the lack of a citation, was a dead giveaway! 😂
  • 6 + 4 / 2 is 8 instead of 5?
    The fundamental property of Maths that you have to solve binary operators before unary operators or you end up with wrong answers.
    But +, -, *, and / are all binary operators.
    As far as I know, the only reason multiplication and division come first is that we've all agreed to it. But it can't be derived in a vacuum as that other dude contends it should be.
  • until the ambiguity is removed
    Can you explain how that is? Like with an example?
    Math is exactly like English. It's a language. It's an abstraction to describe something. Ambiguity exists in math and in English. It impacts the validity of a statement. Hell the word statement is used in math and English for a reason.
  • 11 Stimmen
    20 Beiträge
    8 Aufrufe
    jimmydoreisalefty@lemmy.worldJ
    No, re-read. It is about technology.
  • No JS, No CSS, No HTML: online "clubs" celebrate plainer websites
    771 Stimmen
    205 Beiträge
    369 Aufrufe
    R
    Gemini is just a web replacement protocol. With basic things we remember from olden days Web, but with everything non-essential removed, for a client to be doable in a couple of days. I have my own Gemini viewer, LOL. This for me seems a completely different application from torrents. I was dreaming for a thing similar to torrent trackers for aggregating storage and computation and indexing and search, with search and aggregation and other services' responses being structured and standardized, and cryptographic identities, and some kind of market services to sell and buy storage and computation in unified and pooled, but transparent way (scripted by buyer\seller), similar to MMORPG markets, with the representation (what is a siloed service in modern web) being on the client native application, and those services allowing to build any kind of client-server huge system on them, that being global. But that's more of a global Facebook\Usenet\whatever, a killer of platforms. Their infrastructure is internal, while their representation is public on the Internet. I want to make infrastructure public on the Internet, and representation client-side, sharing it for many kinds of applications. Adding another layer to the OSI model, so to say, between transport and application layer. For this application: I think you could have some kind of Kademlia-based p2p with groups voluntarily joined (involving very huge groups) where nodes store replicas of partitions of group common data based on their pseudo-random identifiers and/or some kind of ring built from those identifiers, to balance storage and resilience. If a group has a creator, then you can have replication factor propagated signed by them, and membership too signed by them. But if having a creator (even with cryptographically delegated decisions) and propagating changes by them is not ok, then maybe just using whole data hash, or it's bittorrent-like info tree hash, as namespace with peers freely joining it can do. Then it may be better to partition not by parts of the whole piece, but by info tree? I guess making it exactly bittorrent-like is not a good idea, rather some kind of block tree, like for a filesystem, and a separate piece of information to lookup which file is in which blocks. If we are doing directory structure. Then, with freely joining it, there's no need in any owners or replication factors, I guess just pseudorandom distribution of hashes will do, and each node storing first partitions closest to its hash. Now thinking about it, such a system would be not that different from bittorrent and can even be interoperable with it. There's the issue of updates, yes, hence I've started with groups having hierarchy of creators, who can make or accept those updates. Having that and the ability to gradually store one group's data to another group, it should be possible to do forks of a certain state. But that line of thought makes reusing bittorrent only possible for part of the system. The whole database is guaranteed to be more than a normal HDD (1 TB? I dunno). Absolutely guaranteed, no doubt at all. 1 TB (for example) would be someone's collection of favorite stuff, and not too rich one.
  • Album 'D11-04' Out Now
    9 Aufrufe
  • Matrix.org is Introducing Premium Accounts
    225 Stimmen
    110 Beiträge
    170 Aufrufe
    F
    It's nice that this exists, but even for this I'd prefer to use an open source tool. And it of course helps with migration only if the old HS is still online.. I think most practically this migration function would be built inside some Matrix client (one that would support more than one server to start with), but I suppose a standalone tool would be a decent solution as well.
  • 809 Stimmen
    152 Beiträge
    56 Aufrufe
    Do you mean investors are trying to manipulate stocks by planting stories? Yeah, I think so. But intelligence agencies have whole training programs on how to manipulate narratives, and a very long track record of doing so. See: Israel's hasbara apparatus, GCHQ leaked documents on infiltrating and derailing socialist discussions, Church Committee Hearings, "The Cultural Cold War" by Frances Stonor Saunders.
  • 347 Stimmen
    91 Beiträge
    42 Aufrufe
    E
    It kinda seems like you don’t understand the actual technology.
  • The Universal Tech Tree
    21 Stimmen
    6 Aufrufe
  • UK government withholding details of Palantir contract
    15 Stimmen
    21 Aufrufe
    Of all the partners you could have picked. Eek.
