Dyson Has Killed Its Bizarre Zone Air-Purifying Headphones
  • AI Leaves Digital Fingerprints in 13.5% of Scientific Papers
    23 Stimmen
  • 113 Stimmen
    10 Beiträge
    30 Aufrufe
    I admire your positivity. I do not share it though, because from what I have seen, because even if there are open weights, the one with the biggest datacenter will in the future hold the most intelligent and performance model. Very similar to how even if storage space is very cheap today, large companies are holding all the data anyway. AI will go the same way, and thus the megacorps will and in some extent already are owning not only our data, but our thoughts and the ability to modify them. I mean, sponsored prompt injection is just the first thought modifying thing, imagine Google search sponsored hits, but instead it's a hyperconvincing AI response that subtly nudges you to a certain brand or way of thinking. Absolutely terrifies me, especially with all the research Meta has done on how to manipulate people's mood and behaviour through which social media posts they are presented with
    7 Aufrufe
  • 264 Stimmen
    24 Beiträge
    67 Aufrufe
    glitchvid@lemmy.worldG
    Republicans are the biggest suckers there are. There's a reason as soon as the jig is up grifters pivot to conservative talking points.
  • How to "Reformat" a Hardrive the American way
    90 Stimmen
    25 Beiträge
    73 Aufrufe
    It really, really is. Like that scene from Office Space.
    11 Aufrufe
    6 Aufrufe
    If you're a developer, a startup founder, or part of a small team, you've poured countless hours into building your web application. You've perfected the UI, optimized the database, and shipped features your users love. But in the rush to build and deploy, a critical question often gets deferred: is your application secure? For many, the answer is a nervous "I hope so." The reality is that without a proper defense, your application is exposed to a barrage of automated attacks hitting the web every second. Threats like SQL Injection, Cross-Site Scripting (XSS), and Remote Code Execution are not just reserved for large enterprises; they are constant dangers for any application with a public IP address. The Security Barrier: When Cost and Complexity Get in the Way The standard recommendation is to place a Web Application Firewall (WAF) in front of your application. A WAF acts as a protective shield, inspecting incoming traffic and filtering out malicious requests before they can do any damage. It’s a foundational piece of modern web security. So, why doesn't everyone have one? Historically, robust WAFs have been complex and expensive. They required significant budgets, specialized knowledge to configure, and ongoing maintenance, putting them out of reach for students, solo developers, non-profits, and early-stage startups. This has created a dangerous security divide, leaving the most innovative and resource-constrained projects the most vulnerable. But that is changing. Democratizing Security: The Power of a Community WAF Security should be a right, not a privilege. Recognizing this, the landscape is shifting towards more accessible, community-driven tools. The goal is to provide powerful, enterprise-grade protection to everyone, for free. This is the principle behind the HaltDos Community WAF. It's a no-cost, perpetually free Web Application Firewall designed specifically for the community that has been underserved for too long. It’s not a stripped-down trial version; it’s a powerful security tool designed to give you immediate and effective protection against the OWASP Top 10 and other critical web threats. What Can You Actually Do with It? With a community WAF, you can deploy a security layer in minutes that: Blocks Malicious Payloads: Get instant, out-of-the-box protection against common attack patterns like SQLi, XSS, RCE, and more. Stops Bad Bots: Prevent malicious bots from scraping your content, attempting credential stuffing, or spamming your forms. Gives You Visibility: A real-time dashboard shows you exactly who is trying to attack your application and what methods they are using, providing invaluable security intelligence. Allows Customization: You can add your own custom security rules to tailor the protection specifically to your application's logic and technology stack. The best part? It can be deployed virtually anywhere—on-premises, in a private cloud, or with any major cloud provider like AWS, Azure, or Google Cloud. Get Started in Minutes You don't need to be a security guru to use it. The setup is straightforward, and the value is immediate. Protecting the project, you've worked so hard on is no longer a question of budget. Download: Get the free Community WAF from the HaltDos site. Deploy: Follow the simple instructions to set it up with your web server (it’s compatible with Nginx, Apache, and others). Secure: Watch the dashboard as it begins to inspect your traffic and block threats in real-time. Security is a journey, but it must start somewhere. For developers, startups, and anyone running a web application on a tight budget, a community WAF is the perfect first step. It's powerful, it's easy, and it's completely free.
  • Affordable Assignments
    9 Aufrufe
