Millions of Americans Who Have Waited Decades for Fast Internet Connections Will Keep Waiting After the Trump Administration Threw a $42 Billion High-Speed Internet Program Into Disarray.
  • Here's your first look at the rebooted Digg | TechCrunch
    107 Stimmen
    59 Beiträge
    Digg has been basically dead for 15 years.
  • How to store data on paper?
    44 Stimmen
    9 Beiträge
    U
    This has to be a shitpost. Transportation of paper-stored data You can take the sheets with you, send them by post, or even attach them to homing pigeons
  • 179 Stimmen
    13 Beiträge
    2 Aufrufe
    I will be there. I will be armed. I will carry a gas mask. I will carry water and medical for my compatriots. I will not start shit. I will fight back if it comes to it.
  • 559 Stimmen
    99 Beiträge
    15 Aufrufe
    N
    In this year of 2025? No. But it still is basically setting oneself for failure from the perspective of Graphene, IMO. Like, the strongest protection in the world (assuming Graphene even is, which is quite a tall order statement) is useless if it only works on the mornings of a Tuesday that falls in a prime number day that has a blue moon and where there are no ATP tennis matches going on. Everyone else is, like, living in the real world, and the uniqueness of your scenario is going to go down the drain once your users get presented with a $5 wrench, or even cheaper: a waterboard. Because cops, let alone ICE, are not going to stop to ask you if they can make you more comfortable with your privacy being violated.
  • Welcome to the web we lost
    182 Stimmen
    22 Beiträge
    8 Aufrufe
    Is it though? Its always far easier to be loud and obnoxious than do something constructive, even with the internet and LLMs, in fact those things are amplifiers which if anything make the attention imbalance even more drastic and unrepresentative of actual human behaviour. In the time it takes me to write this comment some troll can write a dozen hateful ones, or a bot can write a thousand. Doesn't mean humans are shitty in a 1000/1 ratio, just means shitty people can now be a thousand times louder.
  • Building a slow web
    175 Stimmen
    37 Beiträge
    16 Aufrufe
    I
    Realistically, you don't need security, NAT alone is enough since the packets have nowhere to go without port forwarding. But IF you really want to build front end security here is my plan. ISP bridge -> WAN port of openwrt capable router with DSA supported switch (that is almost all of them) Set all ports of the switch to VLAN mirroring mode bridge WAN and LAN sides Fail2Ban IP block list in the bridge LAN PORT 1 toward -> OpenWRT running inside Proxmox LXC (NAT lives here) -> top of rack switch LAN PORT 2 toward -> Snort IDS LAN PORT 3 toward -> combined honeypot and traffic analyzer Port 2&3 detect malicious internet hosts and add them to the block list (and then multiple other openwrt LXCs running many many VPN ports as alternative gateways, I switch LAN host's internet address by changing their default gateway) I run no internal VLAN, all one LAN because convenience is more important than security in my case.
  • 109 Stimmen
    22 Beiträge
    5 Aufrufe
    I
    Their previous GPU used an old AMD GPU design if I recall correctly. I wonder if they have in-house stuff now.
  • 374 Stimmen
    69 Beiträge
    9 Aufrufe
    In those situations I usually enable 1.5x.
